View Full Version : Windstar
- Free At Last!!
- 95 Windstar Slipping Transmission
- Please Help 99 Windstar 3.8
- 96 winstar no air condition on rear
- Diagnosing ABS Light
- 98 GL radio dead after new battery
- tires & RIMS
- cluster replacement
- seat belt
- Tranmission 4th gear issue w/ P0743 an P0748 Error codes
- Whats the difference....??
- 2001 Windstar - Radio deos not shut off
- 1996 Windstar Speedometer Gone Crazy
- infamous windstar 3.8L intake gasket
- 98 Windstar ABS and Trac Light
- 2000 Windstar CD player?
- 00 Windstar Intake Manifold gaskets and insulators replaced @ 50K miles?
- Overheating problem
- '00 windstar code po171 and 174 intake manifold?
- 2000 Windstar power lock disable?
- Cruise Control question for the techs
- PowerWindows & Radio Stopped Working
- Speed Sensor
- #10 Fuse on 2000 Windstar
- cd/rom repair manuals
- Windstar leaking gas
- How Do I Replace Driving light?
- 98 Windstar starting problems
- 1999 ford windstar gas tank
- 2000 Windstar CD changer location
- Air intake manifold
- Back Brakes, help!!!!
- 2000 Windstar WON'T START! HELP!
- 99 windstar no heat in front...help!
- can't find the outer tie rod
- SALE; 15x7 Chrome 5 spoke wheels w/215) KY
- 96 windstar r.rotor/strut area vibration
- is it my ccrm
- Transmission Problem?
- Strut Bearing Problem
- How Much Damage???
- 2001 Windstar rear wiper motor
- 97 Windstar
- , a'99 Windstar heater box modsnyone here cut it?
- 1996 transmission 3rd gear wont shift at times
- 2000 windstar headlights come back on
- 96 Windstar brake problems
- fuse #29
- Code interpretation please for 2000 windstar
- injector testing
- 98 Windstar side door sensors/interior lights
- 1996 Windstar Driver Side Rear Vent Window
- How to front rotor when it seized on 95 Windstar?
- 99 winny ABS bleed
- 99 Windstar running rough intermittently
- 95 windstar abs engaging at wrong time
- 1999 Winstar, Coughing
- 99 Windstar Radio problems
- CEL codes P1537, P1538, P1450
- 99 windstar passenger side window won't go down
- 2000 Windstar Cam Syncro
- it squeaks (96 windstar)
- 98 Ford Windstar GL - Engine shuts off on occassion
- EGR bolt stuck
- Windstar wont start in cold
- 1996 Windstar radiator
- OK I'm going to do it unless you change my mind
- 2001 brake job
- 99 Windstar blowing #10 fuse
- 95 Cel P1131, P1151
- 2000 Windstar Anti Theft Problem
- 2003 passenger rear sliding door - will not shut
- Connecting windstar '96 to PC
- windstar intermittent start problem
- ABS light came on / loss of odometer / spedometer
- 2000 windstar emission light?
- Position of IMRC levers?
- Can the "Check Engine Light" be disconnected?
- looking to install aftermarket am/fm/cd
- Leaking 2003 Windstar
- Power Steeering Noise
- Windshield washer pumps
- 1995 Ford Windstar (requesting major HELP!!!)
- Update to P0171/P0174
- Excessive fuel consumption?
- 99 se
- 1999 windstar a c/ problems
- Strut change-'99 Windstar
- Ford 2002 Windstar engine light on
- 112 MPH fixes Track Off light blink and other problems?
- 98 3.8L windstar pcv valve
- Windstar 98
- 98 3.8L windstar! door open, and check engine light come on sometimes.
- How-to Stickys ?
- Radiator fan
- 2001 Parking sensors
- 95 Fuse #7 blowing...
- No tunes
- Vehicle speed sensor question
- 2002 WINDSTAR radio will not work
- 95 GL 3.8 starting problems
- 95 winstar vehicle speed sensor
- Coolant leak
- What maintenance should be done at 140,000 and beyond?
- 99+ Roof Beam?
- 98'CEL-NY State Inspection-drive cycle ?
- Strange starting problem
- 95, 3.8, 175K mi. P0500 VSS
- Instrument Panel Bulb Replacement
- Ladder racks?? do you have one???
- 01 Windstar Trans Problem - Need Help !!!!
- Serpentine belt replacement 2001
- No turn signals, no emergency signals
- '96 winny rough idle when warm
- Error message from Auto Zone..HELP!!
- '99 Timing Chain Replacement
- 99 Windstar SE owner intro and problems
- Mexicans Want to Buy My Windstar!!!
- Winstar woes(lack of power)
- Error codes
- Dropped Isolator Bolts-you know where
- Ford 2002 Windstar engine air filter change
- '99 Windstar Great Van/No Complaints
- What is that part????
- radio fuses
- Under Body Flush
- Replace 99 Windstar electric window regulator
- Misfire still
- 98 Windstar Power Locks Keep Cycling
- 96 with O/D light flashing, EPC solenoid?
- What is the RPM for a 3.8l at 100km/h or 60mph ?
- Transmission 1st gear doesn't engaged once stopped
- 1998 3.8 L P0302 error code.
- Start system problem - Key
- Starting Problem
- Windstar Design Flaw Trends
- rpm rev on 98 l windstar
- Misfire on #2 cylinder
- bad window job
- trans leak
- '98 3.8l Won't shift into 3rd gear
- Help please, 96 Windstar brake problem
- 95 Stock radio - headphones
- '03 Windstar
- Ford to stop making minivans
- Damaged Windstar -- 1998 LX
- 98 Windstar Taillights wont' go out
- Serpentine Belt - Belt Tensioner - Idler Pulley
- 98 Windstar 3.0
- 2001 Battery Replaced
- Roaring noise on the front end
- terence123cars
- rear brakes are driving me crazy help
- 96 Windstar transmission
- 1995 Rough Idle, need directions to spot please
- 98 Windstar code 181 Fuel Temp Sensor A
- 99 Windstar rear heat problem
- brake light
- 2000 windstar rear brake diagram?
- 99 Windstar SE Battery Draining
- 95 Windstar hood release cable
- Labor guide
- no fuel pressure
- 1997 GL Seedometer
- what causes headlights to stay on with keys out and not start
- What's causing my negative / \ camber?
- Airbags
- Block Heater
- Rear heat switch, 99 Windstar
- Fuel injector cleaner
- Another "water pump" post
- Lower intake manifold question
- 98 Tension Strut Nut Size
- help please 96 windstar
- fuel pump reset switch
- SALE;"white" wheels/tire set in KY $300
- minsfire cylindre 6
- 95 Windstar No Heat HELP!!!
- Windstar stalls in wet weather
- leaking bypass hose
- Windstar clunk front end?
- 2000 Windstar 3.8L Transmission Shaft Seal Replacement
- "Check Engine" light NOT working
- 2k1 LTD - loud whining noise while steering
- 3.8 V-6 cylinder numbering
- changing the water pump
- 2000 Windstar 3.8L Grabby Tranmission Shift from 1st to 2nd gear.
- 2000 Windstar 3.8L Transmission Fluid Change
- Rear bower control failure
- Jammed sliding door loc
- How to fix headlights on my '95 Windstar?
- Touch up paint for 2002 SEL
- Other than Motorcraft Battery Install
- What do you call this parts?
- front windscreen washer
- 96 - Driver Door Rattling Noise
- Air Filter Change--Not cabin filter
- 95 3.8L NO START (lean?) FIXED!
- 2001 windstar
- 1995 Windstar Tranny
- 03 windstar towing question
- How to disconnect ABS in 96 Windstar?
- really mixed up
- 1995 Windstar
- whats the best oil leak stopper?
- 2005 Sales
- engine compatibility
- 2001 Windstar Power Seat Disfunctional
- 03 Winstar Break Light Assembly
- 2001 Windstar PO401 and PO301
- Loose front end on 96
- A very dumb question
- 96 winstar codes?
- 2000 Windstar 3.8L Tranny Oil Leak and grabby shift from 1st to 2nd.
- 2000 Windstar 3.8L ATF Filter & Fluid Change
- 96 GL Starter replacement
- IMR ctrl bank #2 stuck open
- Poor am reception for 2003 windstar
- Brake Lights
- front brake Torque setting
- wheel rims..
- wheel rims..
- continued P0302 error code
- egr valve
- Battery Drain
- ABS brake let off
- Engine Light
- 1998 Windstar Electrical shutdown in rain
- 2001 cruise button wont go off?
- 1995 door switch unlock problem!
- p0171,p0174 (again)
- 99 Windstar making clacking noises
- high idle on 1996 ford windstar
- aftermarket warranty
- windstar 2001 dying out
- Reverse sensor
- Help 98 windstar int. lights won't turn off
- Engine Fuel Temperature Sensor
- Rear Heater Freaking Out
- 1996 emmision/computer issues
- Side door panel removal
- Any tips on changing ABS Pump & ECU Package on 00?
- 98 3.8L Replacing Squeeking Tensioner
- Changing spark plugs and wires on 2000 Ford Windstar
- Service engine light stays on
- idle speed surge '00 with 3.8L 100K mi.
- Windstar 2002 climate control blend door problem
- 3.0 will not start
- ground wire for the radio
