1995 Ford Windstar (requesting major HELP!!!)
lil_josh
02-06-2006, 01:33 PM
Alright, i have a huge problem with my moms van. Under 15 mph the van begins makeing a dingin noise that wont quit untill you get over 15 mph. And as soon as u get under 10 mph it starts dinging again. And sometimes if u mess with the ignition it will stop for a second. So what is wrong witht his frod? any help is highly appreciated!
DRW1000
02-06-2006, 07:27 PM
Is your check engine light on? Can you describe the problem a bit more?
wiswind
02-07-2006, 01:12 PM
Do the interior lights come on?, does the "door adjar" light come on on the dash? If one or both of these things is happening, and the doors are closed securely, then you may have a problem with one of the door sensors. Do a search in this forum on " door sensors " and you will find lots of company, and how to fix them. Remember, that there are 2 sensors for the tailgate.
If a door is open (or sensor says so), the interior lights are supposed to stay on, and the dash indication of a door open will be lit. When you start moving, you should get a long ding sound, and the interior lights should go off.
The, when you slow way down, or stop, the interior lights will go on, and you will get the ding again.
lil_josh
02-09-2006, 05:20 PM
I think its the door sensors then becaus you were correct with the lights. Thanks guys!
pegh
02-11-2006, 01:28 AM
We have had this trouble too... We have been able to solve it by cleaning all the sensors on the doors with nothing more than a rag and rubbing alcohol.
jtman04401
02-12-2006, 08:56 PM
Your fix is a mouse click away......
http://www.automotiveforums.com/vbulletin/showthread.php?t=383261
MoveInRhythm
04-07-2006, 05:52 PM
I had the same problem, and it drove me and my family crazy. It went away after replacing the ignition switch.
