3.8 V-6 cylinder numbering
anatka
01-09-2006, 10:11 AM
I'm looking for 3.8 V-6 cylinder numbering in order to replace 4th cylinder spark plug (to fix PO304 code - causing engine light ON).
Before tracing spark plugs wires, maybe somebody could tell me, please, which cylinder is which number?
Thanks.
Thanks.
LeSabre97mint
01-09-2006, 11:44 AM
Thanks.
Hello
Facing the front of the vehical. The front plugs: 1,2,3
The rear plugs: 6,5,4
4 should be the closest to the driver.
Some one speak up if I'm wrong. This is from memory of a headgasket job last winter.
Regards
Dan
Thanks.
Hello
Regards
Dan
ruggratt
01-09-2006, 03:19 PM
Hello
Regards
Dan
Haynes manual says that number 4 plug is on the front of the engine on the passenger side, the far left plug. That is the plus furthest from the driver, unless different years have different configurations.
My 96 is as follows.
Rear of engine closest to firewall starting on passengers side 1-2-3
Front of engine, nearest radiator starting on passengers side 4-5-6
Regards
Dan
anatka
Hello
Regards
Dan
Hello, Dan
Thanks for your response.
But I'm not sure you're right:
the picture of engine on the website below -
http://community.webshots.com/album/201931518cScpNK
shows quite opposite numeration.
May be you have other sources to look at?
Please advise.
Thanks.
Regards
Dan
Hello, Dan
Please advise.
Thanks.
anatka
01-10-2006, 08:14 AM
Hello and thank you for your reply.
That's more like it.I was able to replace a faulty spark plug - now engine runs OK.
Thanks a lot.
Thanks a lot.
ruggratt
01-10-2006, 03:59 PM
Thanks a lot.
No problem, glad to help.
Thanks a lot.
LeSabre97mint
01-11-2006, 11:46 AM
Thanks a lot.
Glad to of almost helped..... :confused: that shows what the memory isn't doing for me any more.
Dan
Thanks a lot.
Dan
