View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29
  1. A few 96 windstar questions
  2. Vehicle Speed Sensor (VSS)
  3. 98 trans issue
  4. ABS Light
  5. Where's the Lower Intake Manifold?
  6. 2001 windstar cut off while driving
  7. Steering Column Lock stuck on !
  8. 96 Windstar rough idle after warm up
  9. Anti Freeze Rail underneath the upper intake manifold
  10. dtc U2500
  11. Windstar Pet Peeves
  12. 99 WINDSTAR CODE 171 & 174 LEAN FIX
  13. 96 windstar misfire no 5 cylinder
  14. Damn it
  15. 1995 Oil Pump Installation?
  16. SRS Airbag questions
  17. 2000 SEL Check Engine but no codes
  18. Anti-Freeze Leak
  19. windstar door wont lock
  20. 95 windstar radio trouble
  21. Interior lights stay on
  22. Suspension Help
  23. high crankcase pressure
  24. ‘96 Windstar Check Engine Light
  25. Speedometer limit Windstar 2003
  26. ABS rear wheel speed sensors- bad??
  27. No electrical power...
  28. Code 300 Windstar97.3.0
  29. 1999 Ford Windstar No Rear Heat
  30. 96 windstar (wont start)
  31. Heater problem
  32. Windstar versus Caravan Tranny problems
  33. 1996 Windy Knocking
  34. Damn rear heat/air
  35. 1996 3.8 intake manifold runner control stuck open
  36. 98 Winstar Shifting
  37. 96 Windstar electrical
  38. Steering noise
  39. What is the cheapest most funtional obd2
  40. TSB 3-16-1 or not?
  41. is mercon ok for powerstearing fluid
  42. 1995 With shift problem when cold.
  43. 2000 Windstar - No Heat in Roof Vents
  44. OBD II Code Reading Error
  45. 98 windstar weird transmission problem??
  46. Best Year Of Windstar?
  47. intermittent engine idle
  48. Does your engine require difrent oil as it gets older
  49. Coolent, Oil, Power stering fluid recomendations
  50. valve cover replacement
  51. PCV Oil Seperator
  52. Question ? (o/d off light) on all the time
  53. To possible fix ABS problem (Activation before stopping)
  54. Fixed charging problem
  55. Windstar transmission-RPM sensor
  56. CEL No power to OBD
  57. 96 GL Vacuum Leak
  58. 98 WS Rear Hatch Door Ajar
  59. Can you swap a ford 3.8 with something reliable
  60. 2001 Windstar Oil In Throttle Body
  61. My 96 Windstar is Weird! Please Help!
  62. 98' ford windstar
  63. flashing o/d off light-1999 WS
  64. 2000 Windstar Automatic sliding doors keeps opening/closing
  65. Noise in steering
  66. Busted Oil Pump?
  67. 2001 Keyless entry Code location??
  68. the radio and keyless entry fuse blows again
  69. 98 Windstar- Cruise control stopped working
  70. AIR VENTS & FRONT END NOISE
  71. WINDSTAR CODE 171&174 FIX
  72. 1998 Windstar Interior Light Control
  73. All about the ford alternater (pretty good)
  74. 2004 Sales
  75. Swapping bench for captain's chairs in the second row...
  76. Preventing head gasket failer
  77. Block Heater Plug
  78. replacing wiper,washer, signal switch (stalk)
  79. alternator not charging but good ?
  80. LATCH safety system
  81. Rear HVAC
  82. Tire pressure light on on console
  83. 1999 Windstar - manifold
  84. Leak or Blown? - Coolant of cat
  85. Transmission problem 97
  86. 00 SEL Air Bag Light Blinking
  87. Greasing Type for "Sealed" Joints
  88. 00 SEL Sliding door switch
  89. blowing fuel pump fuse Ford Windstar
  90. no heat
  91. 99 windstar anti-theft
  92. 96 windstar No heat from vents
  93. right signal works on/off
  94. front end noise
  95. gas guage
  96. reviving up
  97. Tranny Leak?
  98. Need 97Windstar Fuse Map
  99. transmission
  100. Engine replacement
  101. Windstar bucks, need help identifying problem
  102. Heater continues after key out of ignition
  103. timing cover gasket questions
  104. Blown Head gasket
  105. 2000 Windstar Tie Rod
  106. cartrackers.com windstar forum???
  107. 95 Ford Windstar Computer Question
  108. In need of help with 99 Windstar
  109. A/C Clutch Clunking??
  110. engine noise
  111. gasket installation
  112. All new steering parts, steering stiff
  113. 96 Windstar Tachometer Wire
  114. Digital Compass seems to be off by 90 degrees
  115. 3.8L Anyone else have bad lifter guides?
  116. info for anyone wanting to rebuild their ford 3.8
  117. engine light on Ford Windstar 2000
  118. 1996 Windstar Gl From Hell
  119. Codes 171 & 174 TSB # 03-16-1 update
  120. Lock-Down
  121. Still Running Rough
  122. Power Steering Fluid leaking
  123. Remove Radio panel 98 Windstar
  124. check engine light 96 windstar
  125. 2000 Windstar-side power doors retracting
  126. 98 Windstar Heat Problems
  127. a/c switch
  128. Front Bumper Assembly
  129. 2000 WStar SEL outdoor temp sensor
  130. 98 Limited: air suspension bag leak
  131. 1996 Ford Windstar 3.8L
  132. Bad Idle on '96 3.8L
  133. OBD II Code P1517
  134. code 1350 or1450 translate please
  135. Check engine
  136. 99 windstar..won't start in cold weather
  137. Fuel Filter
  138. Newbie with tranny problems on 1999 WS
  139. I wanna buy a WS,BUT....
  140. Traction control clicking and startup noise
  141. Steering Noise Greasing
  142. Lower Intake Manifold Gasket Leak
  143. lip kits or body kits???
  144. weird smell from exhaust
  145. fuel pressure loss when car is off
  146. head gasket project
  147. Replacement Fluid Caps??
  148. Buying a 98 Windstar - What to watch for?
  149. CHarging Problems
  150. 1995 EGR on windstar
  151. Problem with subwoofer on 98 Windstar
  152. '99 LX 3.8L Bad Engine Noise UPDATE!!
  153. Check Engine light code P1131 & P0135
  154. 2001 WIndatar idle surge
  155. 1995 Acceleration problem
  156. '98 Windstar Serpentine Belt Question
  157. Brake Lights Stay On
  158. wheels sticking in cold weather
  159. up/down engine idle, Battery light on/off
  160. Broken blend door
  161. power steering out
  162. 2000 Windstar Knock ??
  163. 1999 transmission
  164. Check Engine Light
  165. ABS after rotor replacement - 95 windstar
  166. Brake Light Problem 97 Windstar
  167. 99 winstar engine ping
  168. 2003 windstar rear heat not working
  169. Mercon V or Mercon??? 96 Winstar
  170. 2000 Ford Windstar
  171. bottom piece of upper intake manifold
  172. AX4S Trans Swap - 1997 WindStar
  173. 99 ford windstar
  174. bet you cant guess what wrong...electrical
  175. 95 tranny disengaging after stop
  176. bank 1&2 too lean
  177. Killing the Door Chime?
  178. Dome Light Problem
  179. Where are the ignition switch wires???
  180. CV Joint Noise
  181. 95 Windstar Temp Gage Fluctuating
  182. 1999 Windstar RSS (reverse sensor system) help needed
  183. Antenna
  184. RTV for Inner Plastic Manifold Plenum
  185. ford windstar for sale
  186. '99 LX 3.8L Bad Engine Noise Identified!
  187. Cruise control problem identified!
  188. 2 New Issues
  189. Dome light stays on
  190. chilton windstar manual
  191. zero pressure at compression #5?
  192. Front Engine Cover Leak 97 3.8L
  193. Check Engine
  194. key replacement
  195. driver side door lock messed up
  196. Brake rotor removal
  197. Passenger side rear door won't shut.
  198. Windstar seat swapping
  199. chirping noise when cold
  200. replacing burnt out bulbs behind cluster
  201. sliding door panel removal
  202. '99 LX 3.8 Bad Engine noise
  203. o2 senser location bank one
  204. 1998 windstar heater leaking
  205. Parking Brake Cable Help
  206. fuel filter
  207. fuel filter
  208. speedometer/abs
  209. Valve spring
  210. Tranmission cooler install?
  211. HELP! Battery light...interior lights dim
  212. resetting the computer on 2001 LX
  213. Check Engine Light
  214. 1995 windstar transmission pull
  215. '98 oil pan and trans gasket
  216. Obd Port
  217. 2000 Windstar OBD codes 171, 181
  218. question about a idiot light
  219. throttlebody
  220. Fuel Economy/Engine Perameters??
  221. 2001 Windstar sport
  222. 98 Windstar wipers front & rear wiers acting up
  223. Transmission, Power Steering and Cruise Control
  224. receiver of the remote key
  225. Starting While In Park
  226. Door chime and Rear Heat/AC
  227. 2000 Windstar Dead Battery
  228. As long as I'm pulling the engine. . . .
  229. need to warm up 98 Windstar; is this normal?
  230. side door wont unlock
  231. Power steering pressure switch
  232. inverter
  233. 1995 3.8 Windstar starter
  234. '99 Windstar Monitors "not ready"
  235. power steering hose leak
  236. No Airflow From Dash Vents???
  237. driver side window motor
  238. Isolator bolts
  239. Check Engine
  240. 96 Winstar Trans fluid change.
  241. Transmission trouble
  242. 1999 Ford Windstar Keyless Remote
  243. 1999 Windstar Heater core shot, how do I replace it!
  244. 99 windstar misfiring
  245. Confused about intake manifold.
  246. CEL misfire #1 rough idle
  247. P0175 Code!!!!!!
  248. 2001 Ford Winstar - won't start sometimes
  249. 96 Windstar transmission, Fluid change or replace????
  250. 98 Windstar overhead dvd console?
