Chevrolet
Camaro | Firebird
> Engine and Transmission
View Full Version :
Pages :
1
2
3
4
1995 Firehawk
1300hp camaro
Headers
87 camero 5 Speed Not ran in 20 years
92 firebird 5.0 tbi 5 speed manual transmission
2001 Firebird motor problems
1992 tbi v8 will only start when primed
85 Trans Am,won't accelerate,backfires,no power
Pontiac Bonneville 400 engine for 79 Firebird
FAST EFI with D.U.I distributor non computer controlled timing
Crossfire & TBI distinction?
1989 IROC Z28 350TPI L98 mods
1984 firebird 5-speed transmission
Haven't started my 350 v8 since 1991.
Need help with a crap freeze plug.
1998 Chevy camaro crunching noise
1998 Chevy camaro need help
Tranny Tick
99 Firebird 3.8 cranks but won't start
86 trans am 5.0 to 5.7
Overheating
Valve/lifter noise 02 Firebird
454 chevy truck engine into 1979 Camaro
1995 camaro crank but no start
82 camaro 5 speed wont shift
looking for a new engine
96 Firebird starting problem
Help Please !!! Clutch wont release!!!
1989 camero RS
another transmission leak
2000 Pontiac Firebird 3.8L AT problems
Transmission leak
1998 Camaro Z28 Engine Stall
92 Camaro RS VERY HIGH IDLE! 2000 rpms
help needed with 89 iroc
95 3.4L V6 camaro surging and backfiring
327 with 350 casting numbers
Tcs off?
305 to 350
RamJet 350 Fuel Injectors Not Firing
95 camaro 3800 ignition/starts and dies
HELP!!! 96 FIREBIRD starting/not starting!
Ignition Control Module???
speedometer
Engine breaks up at WOT
383 2pc. rear main in place of a 1pc. rear mian block
01 Firebird, slow to pick up speed, Is it a muffler?
1996 Camaro 3.8 V6 Spark Plug Change
LT1 Engine break-in procedure
Cooling Fan sensor.....please read! Baffled!
91 Camaro rs Timing
engine hard to turn when warm
No spark...
want to build my ws6
What engine should I put in my 67 Firebird?
88 iroc z engine?
fun 89 camaro v6 guessing game
LS1 into a 1967 Firebird 400?
1997 Z28 Automatic Hard shifting !
just wondering
1989 firebird 305 tbi 5.0, wont start.
Formula body
355 small block 700r4 transmission question
More HP!
1978 pontiac 400 build help
late 70's 350 runs and idles like dirt!
383 stroker motor out of LT1 block
Is this high millage?
oil pressure sending unit plug wiring
Coolant Problems
Question on horsepower
can it really not shift from a dead battery?
Tpi
Fuel problems
my first firebird, throttle/ fuel problems
replace crankshaft w/engine installed
Engine Swap
Transmission Troubles
American car Virgin
Exhaust Manifold question
Need help with 305
Coolant Fan Problem
Stage 1 Performance Chip for 95 Camaro
Cold Air Intake
EGR symptoms
supercharger on a 383?
rebuilding my 305
Engine Flutters under hard acceleration
Burning Tranny Fluid
78 trans am rocker arms trouble
wasting time?
AC went out....Help!!
1980 Camaro Z28 Running Bad, Tune Up Questions.....
tranny swap
motor swap
havin prob.
cam spec question
4l60e no 1st / not shifting to 4th
1988 Camaro V.6 - 2.8 Mileage help.
1986 camaro 305 mods
'86 Camaro 305 to a 350 Engine Swap
1988 camaro ecu and chip upgrades
Idle Surge
Rebuilt transmission or rebuilt motor...?
95 firebird 3.8 to v8
94 camaro corvette motor????
Questions about 95 Camaro.
84 camaro speedometer doesnt work
@@@ 91 Camaro RS v6 not getting anypower @@@
1991 Chevy Camaro Car Starts Then shuts off if I don't keep pumping the gas
My 94maro z28 stalls
89 transam gta
Wont kick down.
ignition advance on 80 z-28
Oil in Radiater
94 lt1 timing mark question
3.4 From 2003 Monte Carlo into 94 Firebird?
bleeding slave cylinder
'99 Camaro fuel gauge pegged full
Vacuum Help
1994 camaro no spark. 3.4L
Timing cover replacement
94 camaro z28 starts up and shuts off
chevy 327 popping at low rpm??
"overheating" issue..... please help!!!!!
96 Camaro v6 3.800
1993 v6 engine removal
Problem with Camaro 125,000 miles
94 Camaro Z28 - LT1 to L31 Engine Swap
LT1 into 77 t/a
Engine Swap help.
Headers
engine paint prep
1978 trans am firebird 400cid need more horsepower
Quick and easy hp
Need help
Fuel Injector Cleaning Problem! Help!
V6 to V8 gauge cluster conversion.
Park doesn't work :(
Leaking Rochester 4b carb - 74' maro
hypertech max energy!!
New Engine, Will it fit?
cable 700R4 to electric t5 transmission
98 firebird v6 w/ code p0300 help!
cams...which is the best one...
Engine Cooling Fan
Head Gasket
speedo cable into trans
98 V6 Camaro no spark at ICM
Car downshifts on its own???
Please i need to know whats wrong
96 camaro v6 3.8 Low oil pressure! Please help
Swapping 1226870 for a 1227165
94 Camaro 3.4L
85 IROC TPI Distributor
Full length headers
Need help with new engine start
EVAP Canister Issues/Possible bypass?
1994 Pontiac Formula - engine cradle - kframe - sub frame
keep breaking trans mounts need help
Catalytic converter...HELP PLZ...
LT1: Oil Burning Issues
oil grit
Making a big engine swap
tranny i.d
88' Firebird Enigine Options
700r4 will not upshift at more than 1/2 throttle
antifreeze leak
90 iroc oil leak needs help
94 turbo
not starting
Car stumbles
96 4l60e in limp mode.
lt1 turbo?
305 mod suggestions
Firebird Wont Start- Anti Theft Issue
is the lt1 for me?
Some LT1 woes
93 lt1
head swap for lt1?
Tranny help plz
95 3.4l starting problem
very lazy off idle after head swap
is this a clutch problem?
91 Camaro RS 3.1L will run rought sometimes
Tuning Programmers
96 lt1 schematic
Heads and Cam swap
Pleas Help W/p0430 code
1995 Firebird V8 6speed
Dillema?
Bog Down
engine shuts off intermittently while driving along and check gauges light comes on
resistance specs for ignition coil 98
Carb help
no RPM's
should i upgrade to a 383?? advice needed
700R4 tranmissoion
jrkn like fuel pressure loss
3.8 engine swap
Transmission Swap?
More Problems
Ignition Problems
th700-r4 rebuild
Need Help, Check Gauges light comes on and car shuts off.
Motor Seized ???? 3.8 /V6 1995 Firebird
1995 /3.8L Starter Removal... Help !
89 formula 305 flooding issue
1996 z-28 tranmission problem?
what can i do to my 305
carb swap qjet to edelbrock question
95 Camaro Z28 auto tranny problems
engine take out
engine take ou
Alternator humming
98 ls1 camaro motor
97 engine woes
Engine noise
96 trans am no start
FUEL INJECTORs
Chevy th350 in a pontiac trans am with a 400 motor
New/re-built 3.4l V6 engine
301 swap
Idle Problem
where can I find reasonably priced LS1 and transmission?
94 Camaro 3.4L starting problem
94 Camaro, 3.4, Electrical/starter
Advice, Tips & Trips for dropping Engine in 97 Firebird
couple questions about 1979 trans am... what size cam/and aftermarket heads?
LT1 Engine - Which Years Will Fit A '93?
Straight Pipes
replacing heads on my 79 TA
headers for a 79 trans am
MSD 6AL or Accel 300+ ignition on a LT1??
new or rebuild?
automatic 4 speed is slow to shift.
I need to know everything about putting a big block 468 600+ hp into a 3rd gen camaro
tranny leaks!! help
El Camaro
LT1 Timing Problem!!!!
tourqe converter?? woried.
1979 Trans AM 6.6/ TH350 or TH400??
86 iroc transmission for 87z28 transmission
Help with 95 Camaro Z28, Any 4L60E Aftermarket Shifter options
camaro z28 help
junk yard motor just keeps getting better but now im stuck
5 speed manual reccommendations
LT1 Starting Problem
24 years
need t-56 for my 85 iroc-z
