94 Camaro Z28 - LT1 to L31 Engine Swap
driftinggrifter2
02-01-2010, 10:18 PM
I'm buying a 94 Z28 but the LT1 motor in it is junk, so I am swapping out for a L31 (suburban) motor.
Both are 5.7 350's, so the question is, will any of the Z28 mods work on it? IE: Cold Air Intake, new exhaust sys, etcetc
As far as the exhaust goes, it probably doesn't matter seeing as I'm going to put true duels on the car anyways.
Anywho, any advice, critizism and the such is always appreciated.
What would you go for?
Whoaru99
04-23-2010, 07:23 AM
As long as you can get it bolted in and working, any typical mods that increase air and fuel through the engine would apply.
1986Z28
05-30-2010, 09:09 PM
100% completely different engines, LT1 is Gen 2 reverse cooling, L31 is gen 1 style SBC, about the only thing that would be the same is the engine mounts.
