94 Camaro, 3.4, Electrical/starter
robot9
02-01-2009, 12:00 PM
Any opinions will be greatly appreciated!
94 Camaro, 3.4L , Starter is Good (tested) Battery is good (tested) No bad fuses in the fuse box or under the hood. Clicking sound BEHIND glovebox, when key is engaged. . . no power making it TO the starter.
Parts store tells me there are NO relays between the key and the starter. There IS something that is clicking, with or without the starter in. . . no voltage at the harness.
Thanks for any input!
R9
R9
Helmuth48
03-02-2009, 07:23 PM
There is a Fusible link, I see it on the wiring diagram. Also the clicking could be the Theft Deterrent Relay...if it is clicking then you have power to it....
Get a Haynes Repair Book ....look on 12-16...it has the starting and charging diagram for a 1994...this will help...
Good Luck and Cheers....JJ
