View Full Version : Passat
- Video: Replacing the servo pump on the Passat 35i
- Video: Replacing the generator on a Passat 35i
- Video: Replacing drive axle boots on a 35i
- Video: Replacing the cables of the handbrake on the 35i
- Video: Replacing the water pump on a 35i
- How to Stop Bong Noise
- Video: Replacing thermostat on the Passat 35i 2E
- Buying Passathe 2015 TSI gasoline
- Passat illness
- Video: Replacing the lower ball joint at the 35i
- Video: Replacing the timing belt at the 35i with 2.0l 2E engine
- 2013 Passat TDI AC out
- 2005 Ck engine light coolant message
- Passat GLX Wagon 2004 Rear Headrest
- Video: Replacing the muffler at a 35i
- Video: Replacing the gasket of the cylinder head cover
- Video: Replacing the rear shock absorbers
- Video: Replacing the rear brake pads
- 2000 passat intermittent miss
- Video: Replacing the starter
- Video: Replacing ignition starter switch
- Video: How to repair the climatronic of a 35i
- Video: Dashboard removal
- Car stopped while driving
- Key Fob problem
- 2002 Passat problems
- Replacing the rear engine mounts
- Video: Servicing a Passat 35i
- Video: Climatronic diagnosis - Repairing the blower relais
- Video: Replacing Front Engine Mount at 35i
- Video: Replacing steering gear boots
- Video: Replacing the brakes
- Passat Windows Keep Opening On Their Own
- 2006 Passat 2.0t Code P0221
- 2001 Passat 1.8T AUG wont start no spark
- 1999 passat v6
- 1999 VW Passat V6 2.8L
- Help Please? Oil gasket leak...
- Engine swap possible?
- Steering column and ignition problems on Jettas and Passats
- Need Timing Belt in Santa Monica
- '97 questions
- Passat 2000 stopped working
- Der Meister Inc 2508 West Tennessee Street, Tallahassee, FL
- radio and ac not working
- 1999 passat
- Passat Wastegate Error Code
- 54 reg locking problem
- I need help with my passat 99
- Should I buy B5.5 or B6?
- Passat CC vs Audi A4 vs BMW 3 Series
- Spy shots: New Passat B7
- passat won't start after battery died
- Engine hood doesn't stay open.
- passat 2007, 2.0t
- 2000 passat blower dont work right
- Passat Windows off Track 99
- Passat released in India
- Headlight chime help
- 2000 Passat GLX Knock/Bump
- 05 1.8t passat p0600, any help?
- VW Golf5/Passat 2006/2007 Dashboard Programmer
- Microphone and alarm
- 2002 passat tdi water problum
- 2000 passat 1.8l turbo
- 2001 Passat cat converter help
- 2001.5 VW passat round side marker lights
- Passat shaky , then wont start
- Passat 2000 problems after water got in!
- HELP!!! 99 Passat auto tran no gears at all
- 2004 Passat Tiptronic GLS Lurching at Stoplights
- Spark Plugs
- Check Engine Light
- 2003 Passat ABS and ESP Lights
- 1999 V6 Passat - stutters on accelleration
- My 2 cents on my Passat...hate this car
- Anyone wants to buy my 06 Turbo Passat ?
- Maf Vaf Low Input / 03 W8 P102
- No AM reception on radio
- passenger door does'nt unlock properly
- Alarm activating without reason
- Serpentine Belt
- 2007 2.0t aftermarket I/C pipes
- Passat 2007 - hard acceleration /high noise engine
- Should I buy 2002 Passat W8
- 1.8T o2 sensor
- 01 passat engine mounts
- 2000 VW Passat
- Smok check / airbag warning light stay on
- Downloadable Owner's Manual?
- 1998 passat 1.8L turbo TEMPERATURE WARNING LIGHT
- 1.8 PAssat 2001 Keyless programming
- Squealing heater fan
- DAMSEL IN DISTESS engine error code help PLEASE!
- Hello and please help
- A/C stops working
- Change Xenon bulb on PAssat -01
- passat that is slow
- brake noise after changing pads
- Passat 2006 grill on a
- 98 passat wont start - hazards flash...
- Passat instrument cluster
- '93 VR6 stalling.
- instrument cluster 2000 Passat
- Brake Troubles
- My brother needs HELP!
- noob
- 2002 Passat Turbo Failure
- VW tiptronic gearbox vibrates in 3rd gear
- 95 Passat trip computer/clock problems
- Brake mystery
- Please help!
- ABS Control Module - Repair / Replacement Cost
- '98 VW Passat ABS and Brake warning 3 beeping sounds
- Does anybody know how to change a 2002 Volkswagen Passat 1.8t Air Filter?
- Power Door, Sunroof,Alarm, etc.Electrical problem
- The heck did I break now?
- 2001 Passat- 1.8 liter - cooling fan clutch
- Baked-on Brake Dust
- Front Bumper for a '99
- Trans + diff or transaxle?
- 1996 Passat GLX VR6 heater hose question
- 99 passat 1.8T won't start
- Is My Clutch Going Bad?
- 2000 Passat Leaking Antifreeze from bottom of car
- touchy gas pedal
- 99 pasat lacking power/ hard shifting
- 06 passat noob-changing oil?
- Need Intermediate shaft bearings for 99 Passat
- 2001.5 PASSATS and their CLUTCHES
- Gas smell, decreased mileage, check engine light
- My Outdoor Temperature Gage Always Reads ---F
- Volkswagen Passat Service
- HELP Interpreting A CARFAX REPORT
- passat floorboard wet
- VW Passat won't start
- Passat Wagon
- remote starter
- Passat alarm system question
- vw passat key fob
- Engine Starting Problem
- slow or scary gas pedal.
- timing belt replacement
- 2004 Passat 1.8 Turbo Cold start
- unstable idle
- 2004 passat 1.8L Turbo Air filter change procedure
- Buying 2003 passat 1.8 any problems
- Won't start when Hot!
- passat '02 1.8T oil leak
- Stalled while on interstate
- 2003 passat front fog light wiring?
- dead remote control and starting a 1999 passat
- How To change a Indicator Column? Passat TDI 98 MY
- Passat-04 hard shifting from P to R(or D).
- dash lights
- 3-4 minute delay for wiper, indicator start
- ADVISE? Want to buy one.
- 2000 Passat 20V tiptronic gear hunting & surging
- 99 Passat V6 manual shifting issue
- passat world forum down?
- Service engine light
- 99 1.8t engine
- 2001-2005 Passat front window defroster
- Changing the oil in a 1.8T engine
- Programming instructions for 2005 VW Passat
- passat tdi lazy acceleration
- VW diesel engines/vehicles
- Fuel, Air, and Cabin Filters - help a girl out!?
- Why no manual transmission option??
- 03 Passat transmission problem
- Banjo keyless entry remote questions
- No Turbo Boost
- 2005 GLS Hood Heat
- Passat wont unlock and alarm sounds please help
- three more questions .. two about aesthetics
- Suspension or steering? Clank!
- Motor Mounts
- 91 passat plug wire diagram
- 99 1.8T Passat, lil help?
- 92 p. wagon wont start engine light comes on res
- Passat auto transmission mistake-HELP!
- 93 passat turbodiesel 1.9 litre
- 2001 passat warranty
- 1.9TDi Fuel Pump
- need to know, 92 passat
- 95 passat clutch/master cylinder
- 99' 1.8T clicking engine
- sunroof drainage holes???
- 1997 VW Passat Radio Code
- 1999 passat temperature gauge
- clicking hazzard switch
- 2001.5 Volkswagen Passat Wagon 1.8T 5-Speed Gold!
- sunroof leak???
- 2001.5 VW PASSAT: 5-Speed Turbo Wagon for sale
- BBS Alloys from a Passat for sale - WA
- volkswagan oil pan damage
- 4 Qts Oil, dipstick says overfilled???
- brakes
- air flow sensor
- 1999 passat mass air flow sensor
- Bent Frame
- '93 Passat snapping sound
- OBDII tests not ready?? PLEASE HELP!!
- Rattling noise
- 2003 Passat wagon fuel pump
- Disable Seatbelt Warning Chime?!?!
- Strut Mounts need replacing (1995)
- Factory Service Manual (1995-97)
- Emissions Workshop - first time
- Big puddle problem
- my 1996 passat + water = problem
- Rear Brakes caliper wont go back in
- 03 Passat - general questions
- ABS Computer problems
- 1994 Passat - Can't roll down any windows
- Low oil pressue!
- Instrument cluster froze 1996 passat
- 97 GLX/interior heat(climate control) issue
- 97 GLX/auto Cruise Control Problem
- sudden break down
- 97 Passat VR6 Loud Whining noise with Steering
- Passat 2.0 Litre 8 Valve Cambelt timing
- Front Seat Removal
- '98 Passat Won't Start
- interior smell
- Blowing Smoke!!!
- TDI/Diesel killing me!
- interior smell
- Xenon lightbulbs
- flat spots/hesitation when engine high revs
- 98 Passat Electrical Problems
- Struts for '95 GLX VR6
- Passat Climate Control
- 2000 passat intermediate shaft broken
- Cambelt on 2001 Passat
- new owner - 1999 V6 Engine light and weirdness
- 2000 Passat - Sounds like an exhaust leak but not sure
- Please Help Me!
- ASR did it come in Manual Trannys?
- Passat W8
- 95 Passat VR6 whining @ 2.5k - 3k rpm
- 97 Passat diesel check valve exploding...
- vw passat glw 1995
- vw passat bulb change
- Power Loss/ Gear Shift Problems
- 97 passat check valve exploding! HELP!!
- 2000 Passat tierod ends
- 2000 Passat surging, "emissions workshop" message
- VW Passat Bosch 5.3 ABS Modules Rebuilds Available!!!
