Chevrolet
> Lumina
View Full Version :
Lumina
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
Pull Lumina radio
ecm trouble
91 lumina euro w/ methanol option
1992 Lumina 3.4 Engine
1992 Lumina Euro 3.4
98 lumina
1998 lumina 3.1
Please Help W/ Unknown Problem
'93 Lumina APV Transmission
Lumina Z34
1998 Lumina
firing order 3.1 l
Z34 Alternator
1990 lumina 3.1 sparkplugs installation
coolant problems
lumina wont start please help
90 lumina bodykit
Yukon 2003 keyless remote
3.1L to 3.4L Conversion Kit
Transmission
Possible Electrical Problem
Problems with 99 lumina 3.1L
Can't get at the back 3 sparkplugs, any ideas?
need a new window but cant find one
Turbo on a lumina
Crazy Question
Is This Temperature Safe?
Fuel Injection System
help... thinking maybe it's the ignition module
problem with coolant level
Dead battery problem
Starting issue
High Performance Parts
Totalled my Lumina
99 Lumina LTZ Transmission Shifts Rough
Floating Gas Gauge
Hesitation during slow accel. pls hlp!!
Who here has the best Lumina?
2 questions
New in South Africa
Delco stereo light out
Long trip planned
'99 leaking coolant
Solution for intermittent no-start/no-run problem
97 LUMINA starting problem
z 34 speedlimiter
how do i unhook battery
93 lumina vaccum canister
performance chip
Removing Speed Govenor on my 1998 Lumina??
Crank no Start
head gasket replacement?
92 Lumina-Sticky brakes
transmission
hazard lights keep blowing fuses
New battery-radio in "LOC" Need a key
Quick Question about installing an AMP
Upper Plenum for Lumina Z34
Classifieds
Z34 ground effects on Lumina Euro
Ground Effects
96 Lumina - Transmission Computer Chip??
91 lumina 3.1 euro sport engine swap
92 Lumina won't stay started!
Love the '92 Z34?
Does anyone know where I could get a wiring diagram for a 99 Lumina LTZ?
Heat control in 96 Grand Prix
Need engine for my Lumina Euro. 3.1 or 3.4?
No dash & parking lights! Related to remote car starter?
96 Lumina Trans, speedometer, odometer
Trans Slipping
98 Lumina Hesitates on hard acceleration
99 Lumina 3.1 - Losing Coolant
96 lumina Code P0420
starting
1990 chevy lumina
90 Lumina help
1996 remote start help
96 3.1 V6 hesitation only when warm
I need some advise badly....
95 Lumina 3.1 creaking problems
Websites
1993 Lumina ABS Problem
power streering hoses
Replace serpentine belt
transmission
Knocking (Rod knock?) '95 w/ 3.1 V6
93 lumina headlights
93 lumina speedometer, odometer, and headlights
'93 Speedometer Not Working
Where is my Fuel Filter?
'96 Coolant Leak
my car
weird starting problem
electronic auto shift kit???
battery? Something else?
how do I get the battery out of my 92 lumina?
Automatic lock question
Where is the engine coolant plug?!?!?
Need help with a leak...
Stalled,,,help!
cruise not working
Stalling/Missing
keyless entry program
Daytime(?) Running Lights
rims rubbin brake caliper?
Rims for Lumina coupe 2003
'98 Lumina: No Brakes in Rain
will these rims fit my car?
No brakes on wet road
Lumina Alarm
1993 Lumina Z34 3.4 Body Kits
Cool Lighting
won't start Half the time
2000 Lumina mystery dash lights
1990 Lumina Brake problem...
keyless entry
transmission
cam shaft
Need some help...
2001 Lumina LS V6 3.1 - Tuning?
Replacing outer crank seal & Timing Belt....
just a question.....
1992 caddilac sedan deville
Grille?
Need Body Kit For 91 Euro Coupe
Convert rear brakes from drum to disc?
Weird whistling/skreeching upon accelleration hesitation/stumbling/surging
Fuel Filter Location on a 1998 Chevy Lumina 3.1L
wiring diagram for power door locks for 93
Help with lumina
car won't stay running
Help on '93 Lumina
Z34 question
Couple of questions on my Lumina...
Dtrl
OBD-II Code P0440
Oil Leak!!Help!!
Turbo??Possible?
Reprogramming Lumina Keyless Entry
Two Lumina Z34s ZFor Sale
81,000 mile blown engine WTF?!?!?!
cooling fans
A Van & A Car?
Disable Electric Door Locks?
Injector replacement
1990 Lumina Euro 3.1 Sedan
ABS Stalling Engine?
coolant
98 Lumina No Stop Lamps or Turn Lamps
'98 Lumina ABS Light On!
Transmission Problem - '98 Lumina LS
Lumina Keyless Remote Programming
heating problem
Starting the engine
lumina rims upgrade???
96 transmission
94 Lumina Z34
'98 Lumina Keyless Remote Programming - How To?
Keyless Entry Programming
daylight running lights
LTZ package
90' lumina w/ keylock electrical problems
98 LTZ front wheels shudder on quick starts
2003 SS Lumina
93 lumina euro 3.4 coolent light?
I have an overheating problem
Help!!!!!!!
92 Z-34
lumina ss
Can the back seat of a 2001 Lumina be removed? How?
Help! Oil in Coolant Resevoir
Knock Sensor
Power Window Problems
90 Lumina check engine light
DELCO unlock...
95 baretta low coolant light
Performance Parts
95 lumina stop lights
92 Chevy Lumina Mechanical Problem
Hazard Flasher on 96 Lumina
'92 lumina engines
2002 Lumina SS
1996 Lumina Intermittent Overheating
Custom Lumina
