90 lumina bodykit
tikiman_2005
11-23-2003, 04:59 PM
i can't find any bodykits for my 1990 lumina euro and was wondering if anyone knew where i could find some. please help if you know anything or any specs on the lumina
thanx
thanx
Blaze420
11-24-2003, 09:12 AM
I don't know about the body kit, but here are some specs on the engine.
Engine Description (LHO) 3.1L 60 degree V6
Horsepower (HP@RPM) 140@4800
Torque (ft-lbs@RPM) 180@3600
Block Cast Iron
Heads Aluminum
Valves 12
Displacement 3.1L (3100cc, 192ci)
Cylinders 6, V formation, opposed 60 degrees
Bore 89mm (3.503")
Stroke 84mm (3.3122")
Compression Ratio 8.9:1
Fuel Management PFI (Port Fuel Injection). Electronic, controlled by ECM
VIN code T
Usage All, later 1989-1993. To '94 in Lumina
Type Gen II (Same motor as 2.8L with increased stroke volume)
All of this information comes from this website.
Block Cast Iron
Heads Aluminum
Valves 12
Bore 89mm (3.503")
VIN code T
The Burning Rom
11-24-2003, 11:29 AM
Ugly kits...I mean body kits: http://www.w-body.com/upgrades/body-lumina1.html
Blaze420
11-24-2003, 07:57 PM
Yeah, go to a local junkyard and find a Z34 and buy the Body Kit off of it.
