View Full Version : Lumina
- 98 lumina brake lights and turn signals not working
- Squatters in the air cleaner
- Anti lock light after a new stereo installed.
- blinker arm is stuck
- 1997 luminia replace fuel tank need help now
- Fuel pressure spec's 01 Lumina
- Chevy lumina 97 crank but wont start
- P0140 code
- 98 lumina LTZ 3.8 smoke out the exhaust
- steering rack replacement costs=--- ???
- 98 p/s fluid leak=-
- 98 lumina sedan , horn question=-
- brake pads=-
- 97 lumina flooded
- 98 lumina,coolant leak on floor.=
- Bolt Specs & Thread Size for Front Hub and Speed Sensor
- a/c direction problems=--
- slow to start and other things
- Upper inside door panel's Gen 2
- Cruise control inop. 98 Lumina LTZ 3800
- Starter wiring
- 97 Lumina Intermittently Won't Crank With New Starter
- Blower fan not working / vaccuum line maybe?
- vent motor or resistor???=-
- install new horn & button=-
- repair rear center brake light=-
- 1995 Chevrolet Lumina Engine/Electrical Problem
- 1992 Chevy lumina
- 1992 lumina dies when engine goes into open loop
- What does this mean??
- 1994 Lumina 3.1 ECM replacement
- 1993 Lumina 3.1L Transmission Problems
- Need help with 1999 Chevy Lumina
- 1997 3.1 Lumina ECM?
- 1995 3.1L - Replacing Master Cylinder and Booster
- Headlight interchange
- led . center high brake light ???
- 1995 Lumina 3.1L LS - Lost 4th Gear - I know it is common but pls read. Thx.
- 1998 Chevy Lumina brake line confusion
- hesitates, jurks or stops at times when slowing or stoping or starting out
- Help ya girl! 94 Lumina wirin issues
- 1995 Chevrolet Lumina 3.1 V6 - Transmission doesn't gear while moving the lever
- 95 lumina 3100 and 4T60E trans problem
- 1993 Chevy Lumina Service Engine Soon Light
- Monte Carlo dash with tach in a 95 lumina
- 1992 Lumina 3.1 possible transmission slip?
- ABS Light
- Thermostat housing won't seal anymore help!!
- Need help with removing or repairing window tinting film
- high speed blower speed inop as well as rear window defroster
- no oil on dip stick=
- Part No
- here,s a halloween special=-
- P1811
- Turn key, wait 2 mins for fuel pump, then start
- what does this sound like?
- 93 rear door will not open
- keyless entry remote 97 Lumina
- Front end noise, cv axel? hubs? what else?
- replaced booster. now cruise don,t work=-
- wanted= brake booster holder=-
- 92 chevy lumina 3.1 crank but no start
- 98 service manual info needed=-
- 98 (base)= brakes?? hishing noises?
- Transmission shifting fast into overdrive
- How Do We Fix Gas Gauge & Odometer That Don't Work?
- Spark plug gap question
- A/C problem in 99 Lumina
- Headlight's on and key in ignition chime module
- P0108 Code
- Help On lower intake manifold
- 1998 3.1 timing chain longivity=-
- 1998 3.1 fuel pump job question=-
- 97 Lumina, 3.1, 128k miles, weird response fro accelerator
- 92 chevy lumina euro has spark no injector pulse
- 1995 Lumina - Strange Starting and Electrical Problems
- 1990 Chevy Lumina Accelerates Slowly Dies in reverse
- 95 lumina engine loud overnight?video included
- your help plz ...
- 1990 3.1 L Misfire when cold
- z34 Cold Start Problem
- Red Brake and Amber ABS Light On
- 96 chevy lumina 3.1 NEED HELP
- 98 lumina will start a couple times then die
- 3.1 stalls when put in gear when engine warm
- cut hole in trunk to access fuel pump=-??
- 98 3.1 fuel pump longivity=??
- Brake Light in dash wont go off
- Need help identifying a tube/hose
- safe to remove?
- 94 lumina started stalling
- Injector O-Ring's size?? 3.1L engine
- After 6 Month sleep brake light
- Wire not plugged in?
- install oil in struts question=-
- Lower Ball Joint Rivet Question
- 1997 Chevy Lumina3.1-Won´t start when hot
- What will happen if tranny fliud overfilled
- Chevy Lumina EGR issue
- 1993 chevy window problem
- 1990 Chevy Lumina just stopped running, while driving
- 2010 Chev Lumina DTC P0171
- head gasket replacement
- 2001 Lumina a/c blowing out of floor/defrost
- Bad Ignition Control Mod.? 92' Z34
- 1997 Lumina Fuel Pump... I think.
- 3rd coolant leak, driver side this time. '98 3.1
- How many miles to throttle cable destruction?
- Lumina '92 3.1L Euro: Temp Gauge running Hot, but engine not
- 97 runs warm
- 98 3.8 oil overfilled problem
- internal engine grime; is there a solution?
- 3.1 water leak front cover, What else needed?
- 95 Lumina - Clicking Fuel Pump Relay
- Rear Spark plug boots. This may be a known solution...
- Removing seatbelt
- Door opens from inside but not from outside
- Oil Leaking
- 1998 coil,wire ,plug question=-
- Excessive Fuel Tank Pressure
- Security Light???
- strut install fluid=-??
- Catalytic Converter No Welding
- Another no start for 92 3.1
- 90 Lumina 2.5 Bucking
- install console 98 lumina?=-
- Losing tranny fluid
- how to remove head restraint
- Can't Remove 97 Lumina Heater Core Cover
- No Start Troubleshooting. Condensation??
- 98.whistling noise?
- 1995 chevy lumina dies when stopping and reversing?
- 96 Lumina low coolant warning light
- Lumina 2004 LS AC Fans not working
- Hard time starting
- Anyone know what this is??
- 1999 Lumina 3.8L Starting/Idling/Running problems
- Cold weather high rpm
- do ICMs go partially bad? 1992 Lumina 3.1 mpfi
- 1996 Lumina How do I clear codes?
- driver door is stuck closed, won't open
- p0240 code
- pulling computer from black case 1992 3.1 mpfi
- computer flashes "12" 16 times ...
- coolant in oil
- 1992 3.1 died, starts with starting fluid sprayed in intake, sort of
- FPR Sucking Gas
- Hard Start / Engine Cuts Off
- Find vac leak
- 1993 lumina no spark, and clueless!!!
- Spark Plug question
- 92 Euro stalling/no start etc please advise
- 98 3.1 24x crankshaft sensor removal
- Starter Removal Problems
- Mystery again
- 1996 Lumina - chasing intermittant starting issue
- 1996 Lumnia-thinking I have locked up engine
- How to check head warpage on 95 3.1L
- Low coolant light
- Brake booster replace
- How to use a floor jack 98 Lumina
- 1998 remote cover needed.
- '98 Lumina Loose or Broke Multi Function Lever..?
- steering wheel installation
- 93 lumina door lock trouble
- removing the cover/trim behind steering wheel
- anyone need an ashtray?
- Door hinge roller pin
- P0420 Cat efficiency
- Seems emergency brake is not releasing
- 1998 flip a tire question=-
- Lucas products
- (lower) control arm problems
- Seat issues, "in a pinch" info
- Idle when its cold
- Wierd misfiring
- 98 lumina loud tick
- '96 Lumina Suddenly running rough with a non-rhythmic tick
- 97 Lumina Fuel Pump OEM vs Aftermarket
- 99 Lumina Sedan Sun roof stuck open
- Need help to install front bumper that was torn off in accident.
- 97 Lumina Brake Mastercylinder change
- 98 dash light problem=-
- Rough idle and trouble codes
- Lumina APV starting issue
- 98 lumina oxygen sensor post cat removal
- 98 lumina wiper switch = @!%&!*
- Speedometer Not Working - High Idle
- 96 3.1 lumina miss fire under acceleration
- Need help with 97 Lumina 3.1L Heater Core
- Help me think this one out
- '91 Lumina dome light trunk light power locks circuit problem
- Overheating Issues! Again!
- '98 lumina cold transmission
- 98 lumina 3.1 stalls when warm up
- dificulty (stiff) shifting a cold automatic
- Replaced Thermostst Now Won't Run Right.
- 99 Lumina front left tire acting weird.
- Injector sparking
- What is it?
- walmart oil filters are no more=-
- 95 lumina ls randomly not starting
- removal of crankshaft position sensor
- '98 Front hub torque specs?
- Bearing races?
- Steering wheel replacement
- Turn signal lever stuck
- 1999 Chevy Lumina LTZ issue,Please help!!!
- 1999 Lumina power window trouble
- Fan not turning on/ changed thermo already?
- CV Axle testing and replacement
- OMG, I know no one is going to want to touch this one!
- stumped on this one, strut problem 1992 Lumina sedan
- Passlock & '96 Lumina LS
- current draw
- 99 Lumina LTZ stalling issues
- lumina new brake line and bleed
- NGK G POWER Spark plugs
- 96 Chevy Lumina Multiple Random Misfire
- UIM crack...GM techs...
- 1992 Lumina 3.1 rear struts
- 91 Lumina sudden death
- lumina split brake system question
- Air conditioner is leaking
- Front brake caliper bracket removal. T60 bolt?
- Rear brake caliper replacement
- 93 Lumina - Help Please!!!!
- RKE module installation
- how to take apart vacuum lilne connections
- 1996 Lumina 3.1 fuel filter
- can't get my lumina running right
- Cooling issues
- 97 Lumina normal A/C duct temps 3.1 Engine
- 97 Lumina, A/C Dead, Compressor Not Engaging,
- 1996 Lumina 3.1 V-6
- 1997 Lumina Fuel Gauge
- Cross threaded rocker arm bolt
- A/C Flush
- replace 1998 seats with=?
- wiper switch supplier.
- Warning DIY oil changers
- 1999 lumina ltz wont turn over(battery is fine)
- used airbag question=-
- Evap line
- stalling/starting issues (ignition module, egr etc..)
- 99 lumina transmission problems
- it,s back=- p-0440
- Some LIM replacement hints
- Where does this go????
