New battery-radio in "LOC" Need a key
upholsterer
10-26-2003, 09:52 AM
need a sunny color!
BOOZER
10-26-2003, 01:17 PM
I can use a stack of $50.00.
Delco Loc radio's have a factory installed & a user installed unlock code. If you forgot or baught used & did'nt get it, the only thing I know you can do is to see your dealer. The raido has a diag feature you can get into by depressing a combination of buttons
& get access to the factory backup code. From there you call the delco hotline & get the unlock code for it. No sence in going through that though, its not a public thing, for security reasons. See your dealer, some will charge & some will not.
The Burning Rom
10-27-2003, 03:08 PM
This is the process for the CD deck. I assume it's the same for any 88-90 deck with the DelcoLok system. It may also work with 90+ DelcoLok I units.
1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down. (mine were 881)
2. After doing step one and writing down the code, immediately press the
AM/FM button to get the last 3 of the 6 numbers you'll need, and write
'em down. (if you wait too long between steps 1 and 2 and the LOC code
displays again, just start over). (mine were 322)
3. Call this number, it's a prerecorded message, so don't worry about
having to talk to anyone...1-800-537-5140. The voice will ask if you're
calling for Chevy, Pontiac, Cadillac, etc... When you hear this,
press 1 for chevy, followed by 02107and hit the * key. (i.e. 102107*) He'll ask you for the 6 digit code that you've written down.(mine was 881 322) Enter that and press the * key. He will then give you a code,(mine was 810 891)
4. To unlock the radio:
A. Turn the ignition on.
B. Press “SET” (000 appears on display).
C. Press “SEEK until the first digit of the code appears.
D. Press “TUNE" until the second and third digits
E. Press "AM-FM" (000 appears on display).
F. Press “SEEK” until the fourth digit of the code appears.
G. Press “TUNE” until the fifth and sixth digits of the code appear.
H. Press "AM-FM". Now the radio can be turned on.
