View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. 97 Winstar overheats while idling
  2. How to drop transmission for access?
  3. Is it tme to change coolant hoses
  4. clicking noise 2001 ford windstar
  5. P0304 misfire
  6. Bumping sound
  7. Bucking (misfire) while driving
  8. 2000 windstar
  9. lights went dim
  10. 2002 windstar making noise sounds like idler
  11. trailer brakes
  12. Front end clunk
  13. Brake On Off Switch
  14. 96 3.0 windstar burning rich on 87 octane
  15. IMRC question
  16. 98 Ford Windstar 3.8
  17. '99 Windstar
  18. Lower intake gasket leak Blackstone Labs
  19. Windstar 1997 stalls when cold
  20. Goodbye and thanks
  21. engine pings and dings
  22. ? about the Berrymans Chemtool Products
  23. 96 Windstar's bizarre starting problem
  24. 95 Windstar Van power windows
  25. remove retaining bolts wheel bearing hub assembly
  26. Strut bearings
  27. 1996 windstar 3.8 rattling noise
  28. 171and 174 codes affect gas mileage
  29. 98 win 2nd gear slam
  30. REALLY Dirty Intakes (was "won't accellerate"
  31. Is it Possible to replace struts and springs yourself?
  32. oil, oil everywhere
  33. Fuel Injectors
  34. help!!!!
  35. OBD 2 ABS scanner
  36. 2003 Windstar Radio Reception
  37. IMRC Codes/Cooling System Issues
  38. ABS activating no code.
  39. 3.8L Broke Serpentine; now no start
  40. Location of REM (Rear Electronic Module) in a `99?
  41. Ford Windstar Parts
  42. High Speed Shake
  43. Heater Blowing Cold Air
  44. Please help Jatpapa....
  45. Hot to bypass ABS on 95 windstar?
  46. PO741 and PO305 Codes..mind is spinning!
  47. UIM gaskets reusable?
  48. p0174/p0171 ...other possible causes?
  49. Bad head gasket or LIM gasket?
  50. 99 ford windstar keyless
  51. 97 windstar running rough
  52. 97 Windstar running sluggish
  53. 97 Windstar running sluggish
  54. How to find TDC? / Valve Springs & Pushrod Replacement
  55. 99 windstar stalls after warm starts randomly
  56. 99 Windstar battery draining
  57. P303 needs new engine?
  58. 96 windstar just turns off please help!!
  59. 1999 windstar windshield washer
  60. Replacing the seat foam
  61. 1999 door adjustment
  62. Just to be extra safe, please check your Brake Pressure Switch
  63. '98 Windstar 3.8 Won't accellerate past 40
  64. 1998 3.8L Windstar won't start. Please Help!
  65. Brake Greases for 99 Windstar
  66. 1996 Windstar Not Charge
  67. Power Steering Pump and Water Pump
  68. Transmission and Battery
  69. Fixed Intermittent ABS light and Brake light!
  70. Shop manual
  71. Power problems
  72. OBD II Scanner Recommendations
  73. DPFE on 01 windstar
  74. Tail lights staying on. . . .
  75. Castrol Mercon V -- Changed formula!!
  76. power door locks go crazy in the rain
  77. 98 windstar possible head gasket issue.
  78. Brakes On 3.8 Liter 1999 Windstar
  79. p0171 is back
  80. Interior Lights
  81. 99 windstar 3.8 stalling at lights
  82. Grade of Oil
  83. '98 3.8 codes PO171/174, rough idle, shaking steering wheel
  84. Windstar air bag sign
  85. 98 Ford Windstar GL Diagnostic Results - Need guidance
  86. Electrical Problem
  87. OBDII "P" Codes and What They Mean
  88. 96 windstar 3.8 Intermitemt P0402
  89. isolator bolt fix help
  90. 2000 SEL Lumbar problems
  91. 03 front end howling
  92. 2000 LX 3.8 problemafter Isolator bolt fix. Please help!
  93. 1999 Ford Windstar (Correct Gap) ?
  94. 2001 Vacuum related problem
  95. Misfire worse after changing plug
  96. 96 3.8L IMRC question
  97. 1999 ford windstar
  98. 1999 Ford Windstar (Brake Pressure Switch)
  99. Problems with Ford Service CD
  100. There's oil in my intake dear Martha, dear Martha....
  101. 1999 Ford Windstar 3.8 L (Fuse Keeps Blowing)
  102. Valve Cover
  103. Water pump hose or tube
  104. Quick one: need to raise car to drop transmission pan? Best location for jackstands?
  105. Wiswind
  106. rough idle
  107. 96 Windstar stalls when you...
  108. 98 On the Road Again - Transmission Advice
  109. 200 Windstar Rust
  110. windstar leaking coolant
  111. Another blown head gasket and some engine removal questions
  112. are they any good??????????
  113. Airbag Code B1942 HELP!
  114. 1999 Ford Windstar
  115. Thank you WISWIND!!!
  116. P1409???
  117. interior lights staying OFF, not On.
  118. Wiswind will be a Great Moderator
  119. Sqeaking on start up and turning steering wheel
  120. 2000 3.8 Turns over slow, but starts
  121. fuss box diagram 95 windstar
  122. 2000 Power steering fluid change
  123. Intermittent Turn Signal
  124. General Windstar Information
  125. Hey wiswind... let me be the first one!
  126. Please Read Before Posting
  127. CRC mass airflow cleaner
  128. 2003 windstar:blower works no heat, plus clicking noise
  129. 2001 windstar front bumper removal
  130. 01 Windstar: slide door won't unlock
  131. 2000 Windstar arm rest
  132. 2000 Windstar won't start
  133. 2000 Ford Windstar Tune-Up
  134. Mercon V – Trans issues/concerns
  135. The Lights On But Nobodys Home
  136. Smelly Heater Fogs Up Windows
  137. Heating Issue
  138. intermittent ABS warning light 2000
  139. All smells coming in
  140. Suspected Valve Noise
  141. 97 Windstar power locks problem
  142. 2001 Windstar power window question
  143. EGR Valve Dripping Oil
  144. 2001 Windstar Front Wheel Bearings
  145. My 99 3.8 windstar gone crazzzzzzzyyy
  146. fluctuating RPM
  147. 2001 Winstar Milky bubble ps fluid
  148. Power steering leak
  149. Rough Idle
  150. Replaced plugs, now wont start!!
  151. Trying to replace my spark plug wires and plugs
  152. 2000 3.8L H20 Pump Repair
  153. Transmission Info
  154. Now I've done it
  155. 2000 SEL with 171 but no 174?
  156. 2000 Windstar - keeps dying
  157. 95 Windstar- radiator back pressure?
  158. Air conditionet not working
  159. Intermittent start and kill problems
  160. Auto Locks
  161. 98 windstar, IMRC and coolant issues
  162. Front bumper cost??
  163. Blower not working
  164. alicia
  165. Good Bye Windstar!
  166. 98 Windstar GL Auto Trans not Switching Gears
  167. Front wheel bearing
  168. 2001 Windstar tranny filter change..
  169. Sliding Door Nylon Roller Broken - 2000
  170. New Design Valve cover on Ebay
  171. P0401 and P0402
  172. Windstar brake lights sticking on
  173. Backup lights off at (R) windstar 95, 3.8 lt
  174. Anyone to proofread my ’98 Windstar listing?
  175. Instructions to replace steering rack
  176. newbie here and to fords
  177. Persistent P0715
  178. blowing fuse turning left
  179. miss at idle
  180. Which is the rear wiper relay?
  181. Where to get part numbers and diagrams
  182. Hummm
  183. I need the location off VSS and TRS WIndstar 95
  184. Washer Fluid Low
  185. Temperature gauge acting strange
  186. 96 Windstar Code 301
  187. P0118 Engine Coolant Temperature Circuit High Input
  188. rusted brake lines
  189. POWER LOST 15 Ampere
  190. I did what I said I would NEVER do!!!!
  191. Intermitant CEL P1538 IMRC code. ’98 3.8L
  192. 98 Windstar 3.8L- IMRC actuator number??
  193. po172 & po175???????
  194. 2000 Windstar Stalls in Winter when Humid
  195. Possible starter going or false alarm?
  196. 98 Windstar P0171/174 Lean code won't run
  197. My 99 Windstar LX saga had ended...
  198. 97 Windstar using alot of gas
  199. '98 with PO171 and PO174
  200. wipers
  201. Remote Car Starter.....prostart anybody install one on your van?
  202. Which code scanner?
  203. Windstar SE 2003 clicking noise
  204. Silent Warranty on front coils
  205. Turn signal problems
  206. 2003 Winstar Heater blower motor
  207. blown fuse on cruise control
  208. 98 Windstar Jerk when Stopping
  209. Jerk when Stopping
  210. 1999 Windstar - Wet carpet
  211. 2000 Windstar ABS Pump Assembly Replacement
  212. Code P1506- '99 Windstar 3.8L Idle problem
  213. What will happen when the lower intake manifold leaks coolant?
  214. Liftgate Ajar
  215. Windstar 1999 Interior Lights Stay On-- Fixed
  216. Mercon 3
  217. 2001 Windstar Swaybar Links
  218. Transmissions in Winstar and Freestar
  219. Where is the Cabin Air Filter on my '98 Windstar GL?
  220. INFO needed on trailer hitch
  221. I can't find vibration!!
  222. Which cylinder is #6?
  223. How to remove right rear spark plug from the bottom? '98 3.8L
  224. Fashing Trac Off Light
  225. Problem with 1996 Ford Windstar Mini Van
  226. What is the proper spark plug gap for '98 3.8L?
  227. 98 windstar tranny gear sticking
  228. Transmission slipping, seems OK when not in O/D
  229. Broken stabilizer bar
  230. Vss Speed Sensor
  231. Coolant leak?
  232. po401 dpfe repalcement AGAIN!!!
  233. Persistant 171/174 Codes
  234. Code p0118 Heat Sensor
  235. How to shut off low tire pressure light?
  236. Windstar Transmissions
  237. 2001 upper engine knocking sound
  238. Any changes between 95 to 98 models?
  239. Front end noise
  240. 1996-2003 engine in 1995
  241. belt install 3.8 2000
  242. How to flush coolant system?
  243. Whistling Hose.
  244. Need help in using Bar's Leaks
  245. update 2000 windstar stalling
  246. update 2000 windstar stalling
  247. 2000 ford windstar stalls after startup
  248. 99 Ford Windstar Starts Off Rough,Makes Strange Noise Sometimes Dies
  249. Intermittent Starting Problems
  250. 96 Strange transmission behaviour
