View Full Version : Intrepid
- Intrepid dies
- oil light flickering when at running temp
- temp gauge
- 95 Intrepid electrical probs
- timing belt, cam sensor, transmission fuck what is it now!!!!!!!
- 95 Intrepid limp in update, more questions
- strut replacement
- 99 Intrepid ignition problems
- Strange RPM problems...
- 98 intrepid won't start
- Flush or not to Flush?
- 94 Intrepid lights on
- 95 intrepid chronic intermittent lip in
- 1999 oil light
- Intrepid Transmission Interchangability
- Air conditioning recharge
- Just a quick question intrepid not starting.............Please help!!!!!!!!!!!!!!!
- 96 trans stuck in second gear
- Idle Air Control Sensor and Stalling
- 94 tranny
- front end trouble
- Air filter box tube?
- bcm computer
- 99 starter and radio
- new to Dodge
- 95 intrepid won't start cold
- clunking noise
- 97 Intrepid Parking Brake Adjustment.
- Heater Help!!!
- 95 intrepid electrical
- 99 Intrepid Starting Issues....
- intrepid 1999 3.5 engine/1997 3.5 swap
- Transmission
- 98 Intrepid
- no heat
- Can I change a rear wheel bearing on 96 Intrepid?
- Weird problem keeping my car in gear
- 04 Dodge Intrepid
- keyless remote
- autoshift cable
- 1994 Dodge Intrepid dash lights
- Child Car Seat suggestions or after market LATCH system kit
- 2001 intrepid coolant
- '00 Intrepid trunk release problem
- I solved the great WTF problem...
- 1995 Dodge Concprde
- Headlight foglight switch combo?
- 1993 Dodge Intrepid Keyless entry
- 95 Intrepid ES Stalling Problem, Please Assist
- 96 3.3 High Idle
- 94 Intrepid
- Heat
- 96 3.5 Intrepid wont stay running
- 1998 Intrepid ES No start
- 2.7 timing chain
- Starting problem with an added twist
- 1998 Dodge Intrepid Starting Problem
- Got a GOOD WTF problem here!
- 2000 Intrepid error code
- 2000 Intrepid 2.7
- 2000 Intrepid 2.7 timing chain
- Cool weather Thump?
- 2001 Intrepid SE
- custom fit cd changer
- Horn replacement
- sudden idle surge
- 97 intrepid steering issue
- Using oil detergents in 2001 Intrepid?
- 94 intrepid blowing fuses again.
- 2004 intrepid oil light
- Steering
- (ABS) (Trac cont) Dash lights on
- my dodge
- Interior lights won't go off 2001 intrepid
- Replace rear blinker in 99 Intrepid
- 98 Intrepid 2.7 exhaust smoke from exhaust , not only when being started in the morn.
- First Intrepid
- Wow!!! I really hate my Dodge
- Shifting Problem
- 1995 Dodge Intrepid oil pump?
- 3.5 L Water Pump
- 95 tranny/torque converter
- Exhaust
- rebuild 2.7
- engine diagram for 99 2.7intrepid
- loss of compression... oil light on... white smoke
- serious problem
- radio buzz caused by lights
- Power Steering Switch
- fuel line routing diagram
- 99 Intrepid consuming oil
- gas gauge problem
- 95 intrepid transmission
- 1998 Dodge Intrepid HVAC Blower not working
- Drive axle removal
- stallin car
- `96 Intrepid Tranny Problems
- Limp Mode Code #21 Intrepid 95
- Check Engine light (Eagle Vision 95)
- Where is the CPS
- replying
- 99 intrepid
- starting problems 93 dodge intrepid
- '94 Intrepid with accelleration problems
- Tune up 4 Eagle Vision Intrepid 3.5, 24Valve
- 99 intrepid broken window lift
- windshield wiper arms
- 1996 Intrepid Overheating
- Po605 Code???!!
- 2002 Intrepid trunk light
- 2000 intrepid for sale
- 94 Intrepid Tranny Problem
- Transmission
- 2002 intrepid tranny
- 94 Intrepid won't turn over
- Help, Weird Sound
- Replace 1999 Intrepid Door Locks
- 1994 Dodge Intrepid Blows Radiators
- 1997 Cruise Control Problems
- 95 tranny problems
- 2004 Ingine Light and Engine Dying
- 96 Headlight replacement
- 1999 Dodge Intrepid Antifreeze?
- 93 intrepid blower not working
- 94 intrepid power goes down
- 2003 Intrepid overhead light problem
- 95 intrepid cooling fans
- 95 Intrepid won't start
- 1997 Transmission 3rd and 4th gear going...
- 2000 Intrepid Dash Removal
- CV Joints on 2000 Intrepid
- Electric window relay???
- 1999 Transmission taking a coffee break?
- dodge 1994 intrepid transmission problems
- no gauges are working
- 1995 Intrepid ES Heater Control won't turn on
- 99 Dodge Intrepid
- '99 intrepid fuel delivery issue
- Tranny Problems
- 2000 dodge intrepid
- 2002 Dodge Intrepid Overheating Only with Air On
- 1995 Intrepid- Code 32
- headlight replacement
- over heating 1996 Dodge Intripid
- 94 Won't Start, Ign. Fuse Keeps blowing
- Part # for 98 Intrepid keyless entry remote?
- Air Conditioning HELP
- Special tool for A/C condenser?
- Gas Pedal Vibration
- Need Help With 94 Intrepid Please!!!!!!!
- front vibration over 55 only when accelerating
- 2000 intrepid fuel gauge indicator
- 96 Intrepid Back Up Light Problem
- A/C compressors for intrep
- AMP problem
- 96 3.3L Slight stutter?
- Oil Coming Out Of Oxygen Sensor
- intake manifold gasket
- 2002 intrepid wont start after 20-30 mile drive.
- gonvoer on a 97 3.5 dodge intrepide
- '94 Concorde Won't shift out of low
- 94 Dodge Intrepid not idling
- 02 Intrepid NO A/C
- 97 with some probs
- Check Engine Light
- 99, intrepid heater problems
- 94 A/C not working...
- Speed sensor location
- 94 intrepid 3.3L stals from stop only when hot!!
- Air Bag "Door"
- Blinker Problems
- Engine knock
- Oil Presure Light Flicker at idle
- 96 jumper cables backwards. whats broken?
- 97 intrepid w/ some type of electrical problem
- dent in bumber
- 200,000 on 2.7?
- Replacing manual AC with ATC
- 97 Intrepid: Electrical Problems
- Engine hesitation while at a stop
- 1996 3.3L Starting Problem
- programming keyless entry remote for a 2001 intrepid
- Have Trans Problem
- Timing belt bent valves on my 95 Eagle Talon
- Engine noise in my 95 Dodge Intrepid 3.3L
- car wont start
- 2004 Intrepid Driver window falling off track
- Door Speakers
- A poll for Intrepid owners. Like or dislike
- 95 Intrepid stereo
- rear end conversion on dodge intrepid
- please help
- code
- Need advice on 2001 with 2.7
- 94 dodge intrepid tranmission problem i think
- 93 transmission problems
- blinker lights
- 96 intrepid blower only directs to windshield
- intreped for sale, but it has a broken tranny, how much $$$
- engine code help needed
- 2000 Low Idle
- 97 Intrepid wont start
- 2.7 engine stalling / rough idle
- 99 cooling fan problem
- A/C Compressor electrical
- Replacement stereo
- 97 Dodge intrepid tranmission
- how to remove airfilter housing on 99 intrepid
- Hot Intrepid
- Metal To Metal
- Changing a '98 intrepid starter
- Intrepid 2.7 conversion to 3.5.....HELP
- Cooling fans
- Overheating at highway speeds
- 94 Intrepid Transmission Problem
- Lucas Transmission fix for 95
- Engine noise
- Battery light engine dieing.
- starting problem 1995 intrepid
- 1998 Intrepid Transmission Question
- 2003 dodge intrepid stereo wiring problems?
- belts
- 1999 Plymouth Voyageur
- washer fluid light
- Car is DYING need help asap
- 98 Intrepid - Stereo/CD - No Volumn
- Oil light flashes on 2001 Intrepid
- Top Speed On 95 Dodge Intrepid?????
- door locks and window motors
- hood release cable
- auto idiot (me) needs help re starting/electrical
- Wondering
- 1999 Dodge Intrepid (2.7L) A/C problem
- Changing 2.7 to 3.2
- keyless 1996
- 96 intrepid dies sometimes and will not start
- Never Know when its gona Die
- 2001 Dodge Intrepid ES, good deal?
- Starting Problems '99
- Car Cuts Off And Engine Light Is On
- 96' Dodge Intrepid Check Engine Light
- 99 Intrepid Won't Start
- 97 intrepid stalls PLEASE HELP!!!!!!!!
- Transmission Noises
- Cruise Control Not Setting
- Airbag Sensor in 95 Intrepid?
- trunk lock
- 94 Intrepid starting problem
