View Full Version : Rodeo | Passport | MU
- Problem Bleeding Clutch System in 95 Isuzu Rodeo
- Rearend Noises
- Exaust Manifold Removal.....
- Just what we need ... another Passport bulletin
- keyless entry remote number
- Car Dying While I Am Driving It Help Asap!!!
- Ping-a-ling
- Painting "Chrome" Bumper End Caps?
- Problems after alternator install
- Oxygen sensor and EGR vlave
- engine support brackets
- Fuel Sending Unit, 1999 Rodeo, 4 Cyl, 2.2
- Flashing 4wd indicator light
- 1999 Spare Tire Cover?
- tranny problems
- Warranty Question
- Air mass meter/air flow meter/dishonest mechanic
- Confused about my 98 rodeo
- Security system
- Towing Long Distance?
- Website for Rodeo Parts
- Vacuum Hose Diagram????
- The Dealer is fishy
- Rodeo works without keys
- rattling in rear of 92 rodeo
- 95 Rodeo - condenser fan question
- Tranny fluid replace
- starter brand
- Head gasket replacement
- Rodeo under the knife:
- suggested preventive work on rodeo 2001 v6 3.2
- Skid Plates
- Motor pinging
- 98 Rodeo blown fuse
- 2000 Muffler on '99 Rodeo?
- Lifting a 2nd gen Rodeo
- what now? with transmission
- Squeaking noise
- Rear end bottoms out
- oxygen sensor code PO135 & misfire in #5
- fixed super loud knock 96 rodeo 3.2 v6 6vd1
- Synthetic Oil 125K on 3.2 Should I switch
- 2001 Rodeo Electrical Problems
- 93-97 Rear Bumper To Fit On A 91 Rodeo?
- Recently installed lift/ 2nd generation Rodeo
- starter replacment/passport/rodeo
- Rodeo 97 Burning Rubber Smell
- 3.1----3.2 Difference
- Isuzu engine wiring for sale
- 91 rodeo engine swap.
- Another knocking Question
- Egr Valve
- Another Mirror Question
- Outside Mirror- that special tool
- tow hooks
- head gasket leak
- rear end noise GONE!!
- 95.5 rodeo Rotten egg smell
- Check Engine 440
- clutch/transmission problem
- Help- outside Right mirror
- Window Regulator parts
- 93 Rodeo runs good cold stalls when warm..
- 1991 Isuzu Rodeo Check Engine Light
- Noisy lifters. Can you adjust ?
- 1996 Rodeo Won't Start
- opinions requested
- Fundamentals of Oxygen Sensor Life
- 98 rodeo rear end jerk-growl
- 95 rodeo 3.2 v6
- OEM alarm keyless entry information needed.
- O2 Sensor and CEL
- PCV valve location
- St Charles Isuzu
- where to get a good rebuilt transmission
- transmission woes! please help!
- 1993 Rodeo 4WD
- How do I remove & replace tranny accumulator cover?
- How to Remove ReplaceTranny Accumulator cover
- should blower fan work with key on???
- Isuzu Story ......
- transmission leaking, 99 3.2lt
- right side engine knock...suggestions
- isuzu to chevy
- Keyless Entry Questions
- 95 Rodeo Timing Belt
- Need Help...please!!!
- Need advise about the starter (98 Rodeo)
- Engine knock noise
- Passport hard starting running rough
- Electric fan not working.
- Coincidental battery death?
- New range sensor clean up write up +98:
- high revs during start
- Heater / AC Control Lighting
- 93 Rodeo pegs voltmeter, check trans light and tranny slips...
- Thieves!!!!!!!!!!!!!!
- 3.1L head bolts
- 2000 Rodeo A/C
- 98 Passport engine alternatives...
- Automati Trans Leak: Easy Fix
- fixing the fuel sending unit
- Isuzu Rodeo 2000 air compressor
- Towing 12ft Uhaul with a Passport
- Rod Bearings
- leanel Injectors
- More power window woes 1997 Rodeo
- Interesting EGR tube cleaning idea
- cold air intake for isuzu rodeo 2001
- Winter Mode
- "Hissing" sound under dash
- question about factory cd player
- Question about tailgate on 99 Rodeo
- 00' Rodeo Underneath tire carrier
- Rear tire carrier
- alternator, battery, or other problem?
- IMPORTANT...Isuzu FAQ Maintenance!!!
- hard starting rodeo
- Three Flywheels later
- Special on parts at St. Charles
- ABS Setup on 02' 2wd
- How to disable anti-theft alarm
- '00 Rodeo Air Conditioner not working
- Anti-sway bar and shocks
- Help identifying switches
- 98 Isuzu Coil Ground Location?
- 92 Rodeo AT issues
- Fuel pressure problems?
- Need an ASH TRAY, where to buy?
- I'm Losing It
- CLR Radiator
- CHECK THIS OUT shop manuals 99-02
- Replace Oil Pump
- OEM Brake part #'s? Are there different
- air conditioner problems 1994
- OEM Brakes - Metallic or ceramic??
- To Buy "with ticking" or not to buy
- Replaced Head Gasket,,,now won't start
- 1995.5 rodeo won't start?
- 94 passport ac clutch removal
- removing spare tire from underneath
- Timing belt replacement quection
- Where does this wire go!??! (98 Rodeo 2.2)
- 99 rodeo engine squeeling from the rear
- help with serp. belt installation on a 2k rodeo
- couple of 91 rodeo problems.
- lagging
- 1999 Rodeo Trailer Hitch???
- Now won't start
- 01 Rodeo ABS Light On
- 2001 faulty relay
- 1997 rodeo faq
- Temperature questions
- Shock recommendations?
- Slip Yolk
- 2000 rodeo rim size?
- auto transmission glitch
- 99 Honda Passport 3.2 V6 code # P0440
- IAT Sensor
- 1992 Isuzu Rodeo FOR SALE...4x4,5sp
- 93 Rodeo won't start
- 350 in a 95 rodeo
- 96 Rodeo Intake Manifold Gasket
- 97 Rodeo for sale
- transmission problem?
- 96 Rodeo hard idle
- 94 LS shocks/suspension
- '96 Rodeo Drivers Brake Light
- Help needed
- Rodeo for sale, maybe.
- Better shifting after a t-tech transmission flush
- 1999 rodeo v6 wont start no idle
- Rotor--Recommendation
- ARB bumper on Ebay:
- antenna
- sound system
- Bought 95.5 Rodeo, Some Questions
- 93 Rodeo 3.2 Won't start
- 1998 passport alarm
- stinky gas/egg smell, check engine light on...
- Loud ticking noise
- Hitch/Bikerack Questions
- More pep from a Standard 4-cyl?
- 93 Rodeo Engine Tap
- noise 92 Rodeo
- Light bulb on floor gear shift?
- 1993 rodeo 3.2 engine
- New user
- Weird heater thing.
- Accel. Problem
- Tranny
- 1991 Isuzu Rodeo Winter/Power mode
- hydraulic tensioner-where to get parts? no Isuzu dealer in my area how much is part a
- ABS kicking in on dry pavement?
- Cruise control
- catalytic converter
- checking transmission fluid
- timming belt changed -- drove a little (didn't run good) quit on me and won't start
- Rims
- Labor rates calculation
- Radiator Flush
- abs and brake light
- The Next Amigo?
- steering column
- 97 Rodeo blowing ECM fuse!!!
- DIY Tranny Flush
- how to tighten the rear view mirror on a 92 rodeo???
- Head Gasket Job
- Cleaning aluminum parts...
- intake and MPG
- tranny??
- 2000 Passport Rodeo trailer hitch question
- disc changer falling apart
- e-brake & battery light
- no heat
- rodeo 2001 fog light next step
- FYI: Installed Yakima rack w/Loadwarrior
- engine check, rough idle, hard start, dies
- How to get to AT fluid fill plug?
- 91-97 Owners w/THULE luggage rack
- dash lights
- performance chip?
- Yakahama roof rack. Anyone install
- Manual vs auto locking hubs
- Why the need for Fuel Injector Cleaners?
- "01 Rodeo Codes - What to do?
- how much to change timing belt
- 1995 Rodeo 4x4 Manual Trans
- Ebay: 96-97 Factory rebuild Alt:
- Need to replace lower ball joints, and tie rods??
- was keyless entry standard on 95.5 Passport?
- High Water temp, Cold Air From Heater
- New 95.5 Honda Passport owner needs advice on some things
- performance chip
- Bumper extension
- 4wd 2001 Rodeo
- abs/brake lights in dash (not just another usual post)
- little black box
- Muffler Questions
- rearerend problem
- Transmission - Rodeo or Passport???
- 93 transmission
- installation of fog light on rodeo 01
- 3.1L Overhaul
- Water in 98 rodeo bell housing
- question on 4wd isuzu rodeo 2001
- timing belt aligment
- store - storage - storing?
- 93 rodeo
- rear drum brakes
