stinky gas/egg smell, check engine light on...
rodeo_rider
03-29-2005, 03:04 PM
96 rodeo stinky after drives, replaced cat converter...still smells? senzor,fuel injectors,....also hearing theres 2 converters? HELP!
Canucklehead
03-29-2005, 03:12 PM
If you have a 5 spd there is only one cat. converter, automatics have two.
i would recommend getting the CEL code read at your local AutoZone (or whatever is in your area). Once you have the codes it's much easier to troubleshoot.
rodeo02
03-29-2005, 05:25 PM
Rotten egg smelling exhaust indicates a rich running condition. Aboslutely nothing to do with the cat itself, just the cat trying to process all the hydrocarbons. Check your airfilter and Mass air flow (MAF) sensor. Like Canucklehead says, start by reading the codes.
G/luck
Joel
G/luck
Joel
2eyefishclaw
03-29-2005, 07:44 PM
IT COULD BE AS SIMPLE AS HIGH SULFUR CONTENT IN THE FUEL i WOULD FIRST TRY FUELING UP AT A DIFFERENT PLACE
Ramblin Fever
03-30-2005, 09:00 AM
Why is that? Automatics have two?
