View Full Version : SC/SL/SW
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14
  1. loud squeaking?
  2. Possible ways to change radio
  3. What causes tire pressure loss?
  4. Exhaust?$?$?
  5. saturn sc1 2001 intake question
  6. Starter question
  7. Help Antitheft
  8. Speedometer needle osillates at zero when turning on or off ignition
  9. fluid info
  10. 92 LS1 running rich
  11. Front bumper repair
  12. Coolant refilling problem!
  13. struts
  14. 97 window motor
  15. Oil sending unit making check engine light come on?
  16. Its doing wierd things
  17. Unknown code
  18. Valve cover paint peeling - Overheated?
  19. 97 sc2 Saturn Security System
  20. 134 or 12
  21. Fuel Injectors?
  22. 96 SC1 fuel pump troubles..
  23. **HELP** 93 SC2 Idling at 3,000 rpms
  24. vibrating noise from pulley
  25. obd2 code 0794
  26. 93 saturn sl-2 low idle and intermidiate starting after running awhile
  27. Low Idling 2002 SL2
  28. Harmonic Balancer/Crankshaft Pulley
  29. 1994 driver door chime won't stop while door is open...
  30. Hideous Squeak from my '94 SL2
  31. 99 SC1 slow and hesitant to accelerate
  32. manual-shifter cable
  33. Exhaust mods
  34. '96 SC1 coolant overflowing
  35. drivers seat adjustment
  36. 97 Saturn sc2 will not start
  37. '97 SL manual shifter loose and floppy but still got home
  38. 95 DOHC SC2 engine swap.... will newer engines fit?
  39. radiatior issues
  40. hollow noise
  41. Serious Car issues (98 SC1). Im clueless
  42. I have a question
  43. exhaust flex pipe needs replacing\ 93 sl 1
  44. using for racing
  45. 1992 sc1 will crank but not start
  46. 98 Sl2 Trany slip
  47. 2001 sc2 door appliques
  48. 2001 sc2 instrument cluster lens
  49. Manual Trany SWAP... questions..
  50. New Condensor in order but a question.
  51. obd2 torque converter code
  52. 96 Saturn SL1 sucks in all anti freeze and battery light comes on
  53. 98 SC1 leaking oil - what should I do?
  54. 95 SL1 check engine light only when hot
  55. interested in saturn
  56. 1999 SW vibration from headlight
  57. Oil light
  58. 96 sc2 dies when braking
  59. 95 Saturn SW2 ac compressor
  60. 1999 Saturn SL1 - power locks rattling, windows not working
  61. manual transmission slips when hot
  62. 97 headliner replacement?
  63. High Idle
  64. Radiator Replacement inquiry... urgent!
  65. crank but no start
  66. Manual Passenger side mirror replacement
  67. wipers???
  68. drive axle
  69. odometer light out
  70. Newbie with questions - 1994 SC1
  71. Clutch/Transmission Problem?
  72. Deal or No Deal
  73. Radiator Fan
  74. 1996 Saturn SL 1.9 SOHC high idle
  75. '98 Computer
  76. Timing chain replacement interval
  77. no juice! car sits dead!
  78. Transmission: Reverse dosn't work.
  79. help car wont start
  80. How do I install my new timing chain?
  81. motor swap
  82. how to relieve fuel system pressure in 96 SL1
  83. 96 Saturn SL1 diagram of engine
  84. 99 SC2 A/C Recharge
  85. Deal or No Deal on a 2000 SL1
  86. Leak?
  87. Crank but won't start
  88. 2002 SL1 Rear knocking noise
  89. starting problems
  90. spring or ping noise when stopping and turning right
  91. 98 sl2 rpm vs speed
  92. Mods for 96 Saturn SW1 5-speed
  93. 96 Saturn SL1 Cracked Head
  94. weak brakes
  95. Speaking of dash lights...
  96. no dash lights?
  97. 93 saturn sl2 stock car-- Wont rev over 4 grand
  98. Idol keeps fluctuating
  99. help on changing transmission.
  100. Suspension Advice - lots of vibration- help
  101. 1997 sl2 - a few questions
  102. 96 SL1 making noise when stopped?
  103. 2001 SL2 wont start and fuel gauge reads empty
  104. 2001 SC1 Instrument Panel
  105. 1999 SL Oil Burner- please help
  106. saturn sl2 clank sound?
  107. Starting problems
  108. 97 SL2 Air Conditioner (eletrical problems)
  109. 2002 sc1 gas guage reads empty
  110. What seats will fit a 97 SL1
  111. 92 Sc2
  112. !look at this post!
  113. weird noise
  114. Hard Shift from 1st to 2nd
  115. 94 SL1 Questions
  116. SL1 OBX header
  117. 1994 Saturn sc2
  118. 95 saturn with 96 engine. runs fine but doesnt shift right..
  119. stressed out
  120. possibilities
  121. Squeaking serpentine belt at idle
  122. Car won't start, MAF???
  123. temp gauge help ---95SL1 engine swapped with 97SL1
  124. Replacing Wheel Bearings
  125. 96 SL1 noise from wheels all the time
  126. Engine diagram needed
  127. obd11 codes
  128. 95 SL1 Oil Burning
  129. troble code po300 repair
  130. 2002 saturn sl
  131. 93 Saturn SL2 Vibrates sputters
  132. How can i rig a temp horn switch up
  133. Tranny Problem
  134. No accerleration and hissing noise.
  135. Engine transmission swap questions.
  136. 95 Saturn LS Low Idle
  137. Saturn 1/4 times
  138. engine clicking
  139. Occasional Jerk while accelerating
  140. Engine Gaskets
  141. Idle is High
  142. Stalling while slowing down
  143. Hesitating on Acceleration
  144. hey fellas
  145. 97 saturn overheating
  146. Swap
  147. fog lamps
  148. 96 SL1 Cracked head
  149. my 96 saturn wont start
  150. temp gauge
  151. pros and cons
  152. Engine & Transaxle swap
  153. misfire when hot
  154. motor swap question
  155. 3 Cylinders
  156. My Car is Possessed!
  157. Auto Trany problem
  158. 2002 saturn
  159. Noise when turning. HELP!
  160. Radiator Question
  161. Air Intake
  162. Vehicle died and will not turn over
  163. wont run
  164. '92 Saturn SC auto shoulder strap dead
  165. engine accerlerates 3 diff times when slowing down
  166. Slammin into Reverse with foot on brake!!!
  167. 99 SL2 stalling at high speed
  168. 2002 transmission
  169. 95 sohc locked up
  170. 94 sc2 missing when it warms up
  171. Won't start after engine swap
  172. I'm stumped!! (ignition/oil issues?)
  173. 97 Won't Start Sometimes! PLZ HELP!!
  174. 02 sl1 misfires 58k miles
  175. 2002 SL2 Stall followed by no start/power
  176. 94 SL1 power loss, pep boys says bad comp
  177. poss blower motor or fuse?
  178. Help!
  179. '95 SL1 steering wheel
  180. Idle problem
  181. wont crank
  182. 1995 Saturn SL2 Cold Start Problem HELP!
  183. Engine Idols high 2-2.5 RPM
  184. Engine Swap
  185. Another cooling problem
  186. 96 Saturn sc1..hood will not open
  187. Valve Cover
  188. Front Wheel Rattling Problem...
  189. 1996 Saturn SL1 heat guage problem
  190. Saturn Known For Starter Issues?
  191. 93 SC2 won't idle
  192. msd ignition coil question
  193. floor jack
  194. SL1 Transmission Issue
  195. Son wrecked 94 sl1..have some repair questions
  196. 2001 saturn sl1
  197. anyone have problems with washer fluid not squirting?
  198. 26 QDM fault
  199. line out convertor
  200. line out convertor
  201. headers and cold air intake
  202. Transmission Problem Maybe?
  203. A few questions... cleaning and rattling
  204. fuse marked "body"
  205. PCMb fuse
  206. how to change a head unit
  207. seatbelt problems
  208. 95 SL Horrible sound when turning!
  209. 95 SE hydraulic clutch
  210. complaint: noisy lifter / correction:________
  211. ignition cylinder
  212. '97 SL2 seems to drift
  213. vibrating alot when cold
  214. '97 SW1 Manual Trans. Troubles
  215. 98 Sl1
  216. 91- present saturns w/ bad transaxles
  217. 97 Saturn SC2 Remote Start
  218. 95 SL2 sometimes wont start
  219. Leaking
  220. anyone convert a 93 sc2 to a different fuel?
  221. Radiator Fan
  222. High RPM, Low Coolant Temp
  223. Over heating
  224. My Saturn SL2 is making an awful noise when I start it...
  225. replaced EGR valve
  226. 99 Saturn SL1, OBD code : P401
  227. spark plugs
  228. Driving me crazy!
  229. 99 saturn sl2 mods
  230. Trouble Starting Car
  231. 92 SL2 ABS light
  232. Stabilizer Bar Installation
  233. Front Wheel/possibly rotter problems...
  234. Check Engine light
  235. Coolant reservoir cap leak
  236. 96 Saturn SC2 - SES Light Help Please
  237. Smoke on deceleration
  238. Shifter connecting to cable problem
  239. 93 Saturn Won't Start Dealer claim its a Bad Fuse Box
  240. 97 saturn helllppp!!!
  241. 97 Dohc starting trouble
  242. A/C not blowing air like it used to.
  243. Lost 1st,2nd,5th and rev. :(
  244. 96 SL1 Clicking Noise
  245. 97 sl2 won't crank
  246. 1998 SL High RPM’s When Changing Gears!
  247. no heat
  248. 95 SL2 stalled...
  249. 99 saturn "Service Engine Soon" light
  250. aftermarket radio issue on 95 sc2
