View Full Version : Trooper | SLX | Bighorn | Wizard
Pages : 1 [2] 3 4 5 6
  1. remote key programming help??
  2. 2.8 L fuel economy?
  3. 99 Trooper TOD Green Rear Wheels Flash then CHECK but 4wd Works Fine
  4. Mysterious battery drain on 98 Trooper...
  5. 1994 Trooper Issues
  6. 1998 3.5L engine swap for a 2000 Trooper?
  7. Flex plate to torque convetor bolts will not stay tight.
  8. Rear engine oil seal how to replace?
  9. Rear water cooling hoses. When to change?
  10. What type automatic transmission seal to use
  11. 99 Trooper p0121
  12. Blower only works on 2 speeds
  13. sparkplug and distributor question
  14. No Pressure in hyrdraulic clutch line
  15. Fuel Sending Unit
  16. 1996 Isuzu Trooper Hesitates & Stumbles
  17. 1991 Trooper
  18. wiring diagram 99 trooper
  19. Acura 1997 SLX 147,000 miles plus
  20. Changed Alternator charging light stays on
  21. Bought an '88 Trooper yesterday...question
  22. 90s Izusu trooper Fuel pump question
  23. 2000 Isuzu Trooper codes P1290,P1125,P1295.How to shut off Check engine light
  24. Power steering pump parts
  25. trooper 96 noise P/S pump
  26. 90 Trooper 2.6L A/T over drive Problems
  27. new OME shocks and springs - really nice.
  28. trooper trouble: rear wiper relays
  29. 94 trooper manually over ride transmission computer
  30. 2002 Trooper engine clicking
  31. Scanner Adapter conector for dignosis engine
  32. Isuzu trooper 95 3.2L dignosis engine conector
  33. Trooper 94-changed alternator now have no lights and power
  34. 1990 Trooper clutch hydraulic system
  35. 2001 Trooper gas/diesel engine swap
  36. Bushwaker fender flares
  37. anyone ever change speed sensor on TOD?
  38. How to bump up the HP in my 2.8L?
  39. Emergency brake lite.
  40. Alarm won't turn off
  41. Brake Squeal
  42. Trooper BLACK SMOKE/ACCERATION
  43. 1999 trooper stalling
  44. 96 trooper hesitates and chokes up while accelerating, aweful burning smell
  45. 1998 Trooper 3.5 V6 Accelerating @ gear problems
  46. Looking to buy motor...
  47. 2001 Isuzu Trooper Limited.... ABS Light
  48. Replacing Voltage Regulator in 93 Trooper
  49. 94 3.2 sohc changing valve cover gasket
  50. P1404 after the EGR and tube have been cleaned
  51. 98 Trooper uneven front tire wear, vibration above 30 mph.
  52. TOD and Front Drive Shaft
  53. 1990 2.6L Trooper overdrive problems
  54. Effects of Timing Belt Failure 2000 Trooper
  55. 1990 2.6L Trooper Fast Idle Problems
  56. 99 trooper tranny question
  57. 1990 Trooper has no spark
  58. Want more power and torque
  59. 94 trooper trany swap. How much time?
  60. 2000 Trooper and 10% Ethanol Gasoline??
  61. I just bought a 87' isuzu trooper II for $1800
  62. 92 Isuzu Trooper engine probs
  63. why is it leaking?
  64. 94 trooper "O2, fuel, brake, & charging" lights stay on
  65. 2001 Isuzu Trooper Transmission NIGHTMARE "Thread 2"
  66. 2001 Isuzu Trooper Transmission NIGHTMARE
  67. Are all engines the same?
  68. Alternator questions
  69. Override automatic transmission computer?
  70. 1994 Trooper wiring
  71. 88 Trooper Engine Knocking
  72. 88 Trooper For Sale
  73. 97 Trooper dash battery and 4WD lights don't illuminate before 'start'
  74. 1994 Trooper randoming flooding
  75. Isuzu Trooper Owner Manual
  76. Oz Photo Guide to 3.2V6 SOHC Timing Belt/Water Pump Replacement
  77. Roof Rack and Brush Guard Recommendation
  78. value of Trooper
  79. 01 Trooper with 1340 code and a P0502.
  80. Alternator Gone
  81. GAUGES 1990 Trooper Fuel/ Water Temp Gauges don't work?
  82. 87 Trooper II AC Clutch will not engage
  83. '91 Trooper 4x4, change to diesel?
  84. transmission problems already?
  85. 88 trooper, fuel problems
  86. 1998 Trooper Help - serpentine belt
  87. crank sensor location on 92 Trooper
  88. Oil soaked alternator
  89. Start
  90. 98 Isuzu trooper transmission rough
  91. 1987 Trooper II No fan and no turn signals
  92. 93 Trooper Transmission Failure
  93. Used engine source
  94. Turn signals 2000 Trooper
  95. couple issues
  96. 2002 Trooper
  97. 1996 Rear Binding On Take Off
  98. 1988 isuzu 2.6L 4cyl & Transmission parts F/S
  99. Thinking of Trading it in...
  100. Replace starter without removing exhaust
  101. Intake Manifold Gasket 2000 Trooper
  102. irradic throtle position and idling
  103. spotting radiator problems
  104. where is the switch
  105. Squealing engine still
  106. Transmission or yet another sensor?
  107. 88 Trooper will not start
  108. Let's try again!
  109. 89 trooper new front boots
  110. Starter
  111. Anyone ever solve the misfire on a 3.2 95 trooper?
  112. dragging brakes
  113. 2001 Isuzu Trooper Trans Filter Change
  114. 2 Issues, hopefully connected
  115. 94 Trooper Oil Pump Change
  116. Top Dead Center For 94 Trooper
  117. Audio Question
  118. 2000 trooper limited not staying in 1st gear
  119. sqeeking 4x4 93 trooper automatic
  120. Squealing engine
  121. Trooper Voltage
  122. 2001 Trooper Shift on the fly problem
  123. 94 Trooper headlights
  124. Just bought a '94 trooper...help!
  125. Towing Question
  126. 93 trooper weird tranny slipping problem
  127. no fuel
  128. 93 Trooper White Smoke
  129. HELP 92 trooper won't start just bought 2day
  130. Wheels ????
  131. Compatability question
  132. Problem!!!!
  133. 90 rear differential--compatable rear ends?
  134. 88 Trooper transmission swap
  135. Automatic FWD & REV on 2nd, 3rd, or 4th
  136. 2001 trooper drinks
  137. 2002 Trooper dash clock / temp display need one! Help!
  138. 2000 Trooper Tranny
  139. 1995 isuzu trooper locker
  140. 01 Trooper stalls
  141. Rebuilt engine installed truck wont start
  142. Burning rubber smell from 91 V6 trooper (5spd)
  143. 2001 Trooper flutter problem
  144. 91 Trooper Heater
  145. 2000 Trooper Rebuild Help - Can't Find Parts!!!
  146. 2002 Trooper reliability? I don't believe
  147. 1991 trooper start/idle problem
  148. How to make an auto transmission last longer?
  149. 92 Wandering
  150. What is this clutch part? Pressure problems
  151. 94 Trooper AC dryer pressure switch?
  152. 2001 Trooper starting problem
  153. 93 trooper transmission slipping help
  154. RPM Drop after warmup, but no shift
  155. I smell gas in the cab of my 98 trooper
  156. 1999 Trooper with bad engine-need information
  157. Need help
  158. new to trooper need answers
  159. How to remove the lower instrument panel??
  160. egr tube cracked
  161. 96 trooper should i buy?
  162. 94 izuzu trooper
  163. abs sensor
  164. 5 Speed Transmission help
  165. Timing belt change, need advice
  166. 93 Clutch line pressure loss?
  167. Trooper 98, alarm suspect - disable engine
  168. 1988 Isuzu trooper engine swap
  169. Isuzu Trooper 2.8TD Wiring Problem
  170. TOD Check Light issue
  171. 2000 Trooper CD Player
  172. cheap trooper
  173. WOW how do you get to intake cooling hoses.
  174. Using too much oil? Easy fix!
  175. Pulling a trailer 3.2L DOHC automatic 1500lb
  176. +98 OEM alt for sale:
  177. 94 3.2L How to adjust timing belt tension?
  178. NEED HELP w/ft Brake rotor 99 trooper
  179. I am desperate
  180. Clanging noise only in neutral 94 3.2L v6???
  181. 1998-2002 Trooper Fog Lamp Install w/ factory wiring
  182. in need of a service manual for my 92 trooper
  183. Erratic Idle when starting 98 Trooper
  184. oil light flickers on morning commute
  185. 98 trooper running board
  186. 1993 trooper air idle valve 3.2 motor
  187. Tires for 2000 Isuzu Trooper 4WD
  188. '91 - Power or Winter modes not working
  189. Pitman seal question
  190. Locating ALDL/OBD connector for checking CEL codes '91
  191. For sale: 99 isuzu trooper longblock v6
  192. 2000 Isuzu Trooper hesitating when less
  193. 95 trooper- keyless remote programming HELP!
  194. Revo's and Poly Bushings - WOW!
  195. 88 trooper cold stalls
  196. Starter Shims
  197. Help. having transmission problems
  198. 01 trooper code p0440
  199. TOD Check Light
  200. 01 4x4 TROOPER A/C COMPRESSOR
  201. Engine stumbles after 1 of hot running
  202. Where is EGR on 93 LS
  203. Dead
  204. Transmission Indicator Displays Wrong
  205. After Market Add On's
  206. Red Dawg and Blue Mule
  207. Puzzling check engine light
  208. Replacing Gear Oil -- Synthetic Questions??
  209. 2002 Trooper -- Back Door Rattle
  210. wire diagram 89 trooper t.c.u. HELP
  211. 89 Trooper Tranny Problem Send Help>>>>>>>>>>>>>>>>>
  212. what fits
  213. 1996 Isuzu Trooper for sale
  214. Tranmisson Problems
  215. Window will not go up
  216. Engine for 95 Trooper - $500
  217. Changing rear rotors/pads 00 Trooper 3.5
  218. Air Conditioner causes transmition to slip
  219. 02 Trooper high idle in gear
  220. Key stuck in ignition
  221. 1993 Trooper Winch Bumper?
  222. Service and Maintenance on 99 trooper
  223. Service and Maintenance on 99 trooper
  224. 1997 trooper charging problem
  225. carburetor base plate
  226. RPMs Jumping.
  227. malfunctioning oil pressure guage
  228. Plastic Wheel for Window Regulator
  229. new to isuzus
  230. Vacum leak near EGR, wont start
  231. 97 Rodeo starter removal?
  232. Rebuild or not...???
  233. 98-02 Sealed Transmission- can a dipstick be added?
  234. 93 trooper transmission slipping
  235. 2000 Trooper 3.5 - Programming FOB *AGAIN!*
  236. passenger side brake light not working
  237. 95 trooper 3.2l Auto stutters off and on
  238. Too much oil
  239. 1998 Trooper keyless entry ecu location?
  240. location of oil drain plug for 2000 Isuzu Trooper?
  241. 2000 Trooper 3.5 v6 Tranny Shuddering
  242. somethings rubbing
  243. 98 slx tranny gone @ 90K
  244. Check trans warning light
  245. catalytic converter
  246. Radio, speakers and amps
  247. TOD "Check" warning light
  248. 1996 Problems, Please Help.
  249. 2000 Trooper Spark Plug Question
  250. K&N Air Filters??
