View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Engine interchange
  2. problem starting
  3. Fuel gauge not working
  4. Replacing Main seal
  5. 97 cavalier wont stay running period
  6. low oil pressure/ruff idle
  7. TPS and map sensor
  8. 1988 z24
  9. 02 sunfire window motors
  10. 97 cavalier cranks wont start
  11. 97 Cavalier bogs down when throttle is pushed
  12. 97 Cavalier - Won't Start - Died while on interstate
  13. 96 chevy problems??
  14. 99 cav seems starved for gas?
  15. 01 Check Engine Trac Off Hard Shifting
  16. 1997 cavalier 2.2 starting problem
  17. 89 cav. temp sensor
  18. temperature sensors
  19. Cranks but won't start
  20. Blinker's all fuckered up on 03 cavalier
  21. ac short
  22. 97 Sunfire vibrating
  23. 2003 chevy cavalier speedometer stopped working
  24. 2005 Chevy Cavalier - Add two 12V AC outlets...
  25. 1999 Cavalier 2.4 Z24 Strange Issues
  26. Cavalier died and wont restart
  27. 1996 egr pintle position
  28. 2000 cavvy - engine 'whine'
  29. Trouble getting the fuel rail to disconnect
  30. 98 CHevy Cavalier Shifting Problem
  31. 2003 cavalier 2.2 nocompression
  32. Fuel Relay Noise
  33. Can't unplug the Main Engine Harness
  34. 2002 Z24 Motor Mount trouble
  35. Sludge in intake air/oil separator hose, 2.4L
  36. 2004 cavalier gas gauge problem
  37. 01 Cav park lights problem...
  38. 1993 Cavalier wheel locks up brakes
  39. 1996 Cavalier Code P0440
  40. 96 cavalier P0440 Code
  41. Overheating Problems '98 2.4 liter
  42. New electrical issue
  43. 2005 Cavalier- gauges sometimes work, sometimes don't- frequently not right
  44. wipers staying in the up position
  45. 91 cavlier 2.2 fuel pump problem
  46. Electrical shut down at start up
  47. Engine Mounts
  48. 98 Cavy Z24 - Dilemma
  49. 97 cavalier 2.2 overheating
  50. 2002 cavalier dlr and headlights dont work but highbeams do
  51. 99 z24 wont stay running
  52. Engine problem 1997 z-24
  53. Test fuel pressure on a 96 2.2L Cavalier
  54. Engine problem 1997 z-24
  55. will not start
  56. stuck in park when cold????
  57. '97 2.4 A/T Engine Removal
  58. 1996 knock sensor 4.2 motor location
  59. 1997 Cavalier Headlight/DRL Issues
  60. '97 Cavalier Stalls and Revs...
  61. help please!!!
  62. blown Head gasket?
  63. Replacing Engine and Trans together.
  64. 98' Cavalier wont start
  65. removing quarter panels and doors
  66. Remove fan and its housing
  67. Removing starter 1999
  68. cavalier leaking oil real bad when running
  69. Whine under hood?
  70. Replacing Water Pump
  71. My Herky Jerky Cav!
  72. My Herky Jerky Cav!
  73. I'm having a problem with some kind of mout..
  74. Engine removal help 1998 2.2L
  75. 02 Cavalier Reverse Lights / Blinker Not Working
  76. swaping an engine diff transmissions
  77. Switch Housing
  78. Wierd dashbard light behavior - 2002
  79. '98 Sunfire turn signals
  80. at a loss
  81. Problems accelerating
  82. Stormmy begging for advise again!
  83. 97 Sunfire,runs great until you turn on lights
  84. 2.2 EcoTec
  85. Theft System??
  86. 2001 caviler ?
  87. Blinkers Stopped Working all of a Sudden
  88. Slave cylinder
  89. Info on 2.2 transplant
  90. Clutch Problems
  91. Clutch Problems
  92. Clutch Problems
  93. clutch problems
  94. clutch problems
  95. clutch problems
  96. day time running light problem on a 02 z24
  97. 2001 caviler help!
  98. 1996 Cavalier (base - 2.2) Running hotter than normal
  99. 2.2 head gasket?
  100. headlights and drl don't work
  101. whistling sound coming from engine
  102. 98 & 99 Sunfire Injector leak...
  103. 97 2.2 head gasket leaking
  104. 1996 wheel problem
  105. Need advice on 2.2
  106. 1996 front brakes
  107. pcm/bcm reflash removal
  108. cluster issues
  109. turn signal fuse keeps blowing
  110. 2001 cavalier 2.2 I4 crankshaft PS location
  111. brake master cylinder 96 cavalier
  112. Electrical Prob 2001 Cav.. Anyone else experience this??
  113. 2001 chevy cavalier overheating
  114. 1997 cavalier leaking antifreeze
  115. 2005 sunfire
  116. Headlight switch
  117. 2001 Cavalier drain plug
  118. Tip for replacing wheel bearings
  119. CKP sensor
  120. cavalier blower issues?
  121. Fluttering/Rattle noise....?
  122. Part inquiry/trunk
  123. Shot Out Spark Plug Today
  124. clutch problems
  125. 99 cavalier 2.2 ohv overheating
  126. Odometer Light?
  127. Back brakes lock up, what gives?
  128. 96 Cavalier high pitched noise
  129. P1336 code
  130. 97 cavalier tranny problem
  131. mailbox vs. ABS!?
  132. O2 sensor after the muffler
  133. Brakes not catching at same time
  134. 2000 pontiac 2.2l misfire
  135. 95 cavalier bumper removal
  136. 2002 Cavalier Blower Motor removal
  137. Cavalier rims
  138. Check engine light
  139. 1999 cavalier z24 problems
  140. 1994 hesitation
  141. Electrical/ Tail Light Problem
  142. 2000 cav engine revs while at stop
  143. Possible radiator problem with 1997 Chevy Cavalier
  144. How to remove coil packs from housing?
  145. Need help diagnosing a problem with 99 sunfire
  146. Radiator install problem
  147. 99 cavalier z24 2.4 won't start
  148. 1997 Cavalier - Light came on, need help?
  149. Back tire (something) banging all the time
  150. 90 cavalier 2.2 tbi missing
  151. PO 404,405, and then 753
  152. 2000 z24 convertible top won't work
  153. 96 cavalier transmission stalls
  154. 97 Cavalier 2.2 won't start after overheating
  155. 1996 firing but not starting.
  156. 1999 Cavalier z24 - Stalling
  157. 04 Cavalier Engine Vibration
  158. 1997 2.4L Water pump
  159. 94 Cavalier, pass rear brakes too tight!
  160. Random Misfires etc.
  161. 95 cav with 2.2 problems
  162. back brakes grabbing harder than front
  163. 93 Chev v6 pcv
  164. power steering
  165. ets off light and check engine light on
  166. Couple Quick Sunfire Salvage Questions
  167. setting timing on a 2.2 ecotec HELP
  168. 96 2.2 overheating
  169. head light will not shut off switch problem?
  170. Starter relay wiring?
  171. 2002 CD Player won't shut off
  172. '97 Cavalier 2.4 - lifters or oil pump?
  173. 96 Cavalier won't start, no compression
  174. Possible tranny leak?
  175. 95 chevy cavi z24 2.3l -- misfire/wont turn over
  176. stalling problem [please help :)
  177. 91 Cavalier ECM Fuse
  178. Oil light help
  179. 02 Sensor Heater Circuit Malfunction ????
  180. replaced 97 2.4 with 2000 2.4 no power to interior
  181. 97 Cav questions
  182. Clicking noise
  183. Oil Light lit on 97 Sunfire 2.2
  184. need help with a major pain in my ass
  185. crazy problem in my 2.2l bet you cant figure this one out
  186. 1993 cavalier rs fuel pump relay location
  187. what years fit 1999 z24
  188. Help no head lights!!!!!!
  189. radio problem
  190. car keeps making clicking sound
  191. Rear engine seal leak?
  192. Fuel pump relay grinding
  193. Passlock 1 Bypass
  194. Anybody ever align a door on 95+ Cavy?
  195. Cooling fan 98' 2.4L
  196. No fan operation-98 cavalier 2.2
  197. 97 Cavalier- Stalling Problem
  198. 97 Cav with unknown "issues"
  199. Brake problem?
  200. Any help would be great!!! 1997 Sunfire 2.2L
  201. 90 cavalier,a/c issue
  202. 2.4 Quad 4 NAME THAT NOISE!
  203. 97 Cavalier antilock issues
  204. Could you have a look at this condition?
  205. left inner tie rod
  206. 97 cavalier cooling fan
  207. 2004 Sunfire quit running
  208. Could I bypass the AC compressor in a 2001 cavalier
  209. Sunfire stalls
  210. Car won't accelerate in drive
  211. will these interchange ??
  212. 2005 cavalier oil pan
  213. will these interchange??
  214. Vacuum Leak near Power Steering Resivoir
  215. Trans will not shift into reverse
  216. 1998 cavalier drl relay switch
  217. 97 sunfire clutch slave bleeding
  218. 96 Z24 Cavalier clutch slipping
  219. 98 sunfire cutting out/ stalling
  220. 1998 Cavalier Overheating
  221. 96 2.4 starter
  222. 98 cavi probs
  223. 2000 cavalier z24
  224. replacing 95 Cavalier brake lines
  225. heater only works on high
  226. idle speed
  227. Engine Coolant leak (2001 Cavalier)
  228. clanging noiw
  229. 03 Sunfire problem, need help!
  230. 99 chevy cavilier z24 2.4 liter engine problems
  231. 1999 pontiac sunfire serpentine belt repalcement
  232. 02 Dash Display
  233. '96 2.4L Runs After a Charge, Then Dies Out
  234. Will not start.
  235. Over Cooling issue....
  236. 00 2,2l sunfire fuel problem
  237. Simple question
  238. 05 cavalier low beams & drl's quit
  239. Brake line has no pressure on drivers side
  240. Cavalier CD Player says "LOC"
  241. Odor when blowing air from outside
  242. Changing fuel pump. connection ???
  243. car wouldn't start (electrical problem)
  244. 1992 3.1 Liter Z24 Cavalier
  245. 1996 Chevy Cavalier running rough even after tune up
  246. Chevy Cavalier 2001 Cooling System Problem
  247. 2001 Chevy Cavalier Coolant System Problem
  248. wiring help
  249. Serpentine Belt Problem
  250. driving lights switch help
