Honda
Civic | CRX
> '96-'00 Civic
View Full Version :
'96-'00 Civic
Pages :
1
2
3
4
5
6
7
8
9
A Cvic
d16y8 turbo times
side moldings
short shifter
hatch/coupe parts interchangable?
Changing Brake pad
motor mount question on 1996 civic
auto to man tranny swap
Squeaking belts
Carsmetic!
Few Questions
Civic headers please help!
Humidity issues??? normal??
96 Civic Ex Smog Problem
brake-shift interlock
install factory radio
2000 Civic LX Tires
Difference?
Replace the radio bezel on 98 civic
drivebelt noise
2000 Civic LX - No Instrument Lights
braking issue
98 Civic Ex Keyless Remote/valet Prob.
jerking
97 civic needs helps
speedometer does not work!!!!!!
someone help me
what is this part called?
Alarm problem on 99 civic turns xmas present into dud...santa's helper needed
brakes
Dumb question
Power antenna?
Code P0420 (update)
Stock Clutch Life
97 civic dx
96 DX No Start & Crank pulley bolt torque??
engine swap problems?
b16b
97 ex question-Idling at stop(pushing clutch in)
97 civic dx coupe???
headlights...
Heater Not Working
spedo acting up
Strangest Problem I've come across
headers and intake
Question dat needs a ANSwer ASAP
What do u guys think about this???
Wont Start
lower compression
gauges
i need help installing a BOMZ Cold Air Intake for Honda Civic 00
axle question 97 civic ex
Please HELP
vtec controllers
99 civic si problems
hydrolocked b16A2 replaced
b18
Engine question
no instrument lights???? wtf!
wiper motor fuse blows
Civic Problems?
valve cover
b16 question
timing belt
96 civic idle problems
1999 civic si
EK Swap-B18A1/B18B1-C1Head
quick questions
h22 motor mounts
Ram Air or Cold Air Intake?
door locks
Gas
won't start
newbie in need of help...
cat and header exhuast trouble shooting
97 ex possibally alternator
Is Nos Cheating??
disassembly of door
b16 or h22
Exhaust
Strut Compatability question
Cold Starts
99 Civic trans shudder
overheating 96 Civic
19" Rims Need HELP!!!
WINTER tires.. good deal or not..
CRVtec
b20/vtec?
help b18b into 2000 civic
02 Eliminator
97 EX Hood Won't Open
springs
1.6L SOHC potential?
Call it a dumb question
b16a to b18c swap?????
mini me, help!
prelude seats...
Cold weather problem
Ecu info
Driveshaft
help! wiring prob.?
99 Civic Winter rims
ZC swap into 97 civic EX
B16b Swap
is this normal
car fax help
Where is 97 Civic PVC?
Honda 1600 VTec Head Torque Settings
1998 Honda Civic LX engine swap
Just got my first Honda (97 Civiclx)
96 Civic Si
anyone selling?
starting problem
98 civic EX headlight bulb question...
Dohc
I need Honda Civic Si
98 EX jack points?
big road trip coming up, your inPUT needed..
Car Fax!
What do Civics feel like to drive? *Civic noob*
Difference in doors?
Civic 96
installing a 93 civic engine on a 92 civic
96-98 2dr & 4dr fenders diff?
LS, GSR, and Type R transmissions
is this normal ?
VTECH (also known as V-TEC)
Replacing the Steering Wheel
car wouldn't start this AM
97 Civic LX Radio Bezel
B18B engine internals internet dealer?
Removing 1996 Civic airbags...
not like u
is it hard to change a 5 speed transmission
honda OEM parts
Engine swap 97 honda civic for vtec
civic hx
difference between cx and dx?
dead tranny
Headlights
96 lx timing belt
driver door lock?????
civic lx exhaust manifold
Honda Turboz
EXTREMELY soft brakes
Couple of questions about my civic.
A few concerns...
Fuel pump or???
will 2000 rear bumper fit
need exhaust gaskets
engine question
96 Civic DX Engine Swap
96 civic ???2000 rear bumper???
Factory spark plug Gap?
can someone help me answer this........
P0122 code Honda Civic 16Y5
99 Code P1362 & P1298?
megan racing
sohc non vtec just kicked in, yo.
test pipe
Best Swaybar for 98 Civic Ex
Smooth ride?
Looking for a d16y8 cylinder head mini me
civic 98 radio bezel removal
Rims For Sale
cousins civic
96 Civic Camshaft Suggestions?
Vtec
D16y6
Techno Racing Soundtrack
96 civic oem bumper lip??
96 Civic Dx Injectors?????
96 civic dx cam gear suggestions
96 CIVIC DX FUEL SYSTEM suggestions?
CHECK engine light...p1337 Help.~
HELP! Does this problem sound familiar?
spark plugs
Im building this car, please comment.
Help! P0420 CODE
engine light on
97 civic air bag removal - Help!
Starter Issue
exhaust/muffler?
Awd Civic?
What else should be replaced when doing timing belt
Major Problems
honda 96-98 engine #
oh the mileage
97 Civic alarm or panic problem
honda's
CIVIC 97 - Air intake problem
new
will this work?
caliper mounting bolt
Ruined Head?
rice vs. sleeper
2000 civic, new header new trouble codes
Intake Troubles
clutch pricing
97 civic dx stereo removal HELP!!!
* Need Some Help Guys*
1996-2000 Civic's Any Chronic problems ?
Accelerator Sticking
obd2a/obd2b
spoon sports EK9 pictures!
CEL Code PO420
Complete Manual Tranny for a Swap
Cold Air...
Auto to Manual Transmission Swap Photos?
Vtec question...?
97' LX (four door) - Acceleration?
97 EX Guage Cluster Lens Cracked
B18b
00 sunroof sunshade replacement???
flywheel
need help - crack in exhaust manifold
Help! 96 Civic EX door panel removal
manual tranny 96 civic
How to replace fuel filter on 2000 Civic EX
ha ha ha
in dire need
I finally got my SI...
B16 Swap
knocking noise...help!!
98' Civic HX transmission crapped out
Radio Code
97 trim levels and specs?
obd1 or obd2??
99 Civic D16Y8
Cruise Control
D18Y8 ignition timing.
What do i do with it???
Washer/wiper question
intake cause low rpms
lowering a civic
replaceing starter 98 civic dx
brake light problem
megan racing lower control arms goood??
some advice..please?
98 Civic wont start
axle problems on my civic si
Need advice/info on Air Bag control of Fuel Line
Checkmate remote programing
DTC P1298 at a roadblock..anyone help?
catalytic converter
99 civic ex driver side glass fit my 96 civic hatch dx? does anyone know? help thanks
starting civic cold
intake and exhaust ?
D16Y8 Intake manifold cost?
MAJOR engine problem
