Factory spark plug Gap?
Drift King
10-19-2005, 07:01 PM
Hey, I just replaced my spark plugs with the equivalent Denso, standard plugs. After I was done and driving around for a while, I realized I didn't even pay attention to gapping. I just put them in as they were. Should I take them back out? If so, how do you "gap" them, by bending something? Im hoping they already had correct gaps. By the way this is a 98 EX.
siege911
10-19-2005, 08:32 PM
yes, you should take them back out and gap them... When I do it, I use a spark plug gapper that tells the measurements... a simple search yielded me this:
Engine Type Spark Plug(NGK) Gap
D16Y5 ZFR4F-11 1.1 MM / 0.043"
D16Y7
D16Y8 ZFR5F-11 1.1 MM / 0.043"
B16A2 PFR6L-13 1.3 MM / 0.051"
You have the d16y8, so you need to gap them to 1.1 mm or .043"... good luck!
Oh, and don't forget to put some anti-seize compound on them so they're easy to get out when you need to take them out again.
D16Y7
Drift King
10-19-2005, 10:03 PM
How do you gap without the tool? can I just bed the U shaped thing
siege911
10-20-2005, 12:32 AM
yeah, but you have to make sure it's measured right...
Drift King
10-20-2005, 09:06 AM
O I forgot to mention that when I bought them, they were specified for my car. So thats why I think they are already set. And they are Denso not NHK.
Drift King
10-21-2005, 08:41 PM
Ok? maybe too technical for this section.
superbluecivicsi
10-21-2005, 08:44 PM
if they are pre gapped for your car specifically, then, you dont need to gap it. if you bought a $.99 gap reader when you bought the spark plugs, that would of made things easier too.
not technical, a little common sense really.
AudioGuy93DelSol
10-22-2005, 11:42 PM
95% of the time "pre-gapped" spark plugs are not gapped correctly. Always double check.
superbluecivicsi
10-23-2005, 04:35 AM
they are pregapped to meet a specific range.
civic_stuntin
10-23-2005, 01:24 PM
i'm sure i could find this after searching, but i'm just gonna ask sinece the subject is up now lol
i have a 97 lx, what engine is that and what is the gapping?
exman98
10-23-2005, 03:14 PM
d16y7 SOHC(non vtec) 1.6 L
siege911
10-26-2005, 10:52 PM
D16Y7
Already stated above... lol
D16Y7
