View Full Version : Trans Sport
Pages : 1 [2] 3 4 5 6 7 8
  1. Vibration when driving straight
  2. Won't go to overdrive (4th gear)
  3. small collant leak
  4. Part 2:Changed my alternator, won't shift outta 1st
  5. transmission not engaging guys i need your help
  6. [95 t-s, 3.2]Changed my alternator, lost my speedometer...
  7. '94 TS: transmission grinding in Park
  8. Oil Leak Repair
  9. Replacing door mirror cover
  10. 1998 Transport Brake Light Melting
  11. 2000 venture 3.4 engine in a 96?
  12. 1994 Transport - Having Acceleration Issues
  13. 1992 transport no spark
  14. Emissions test tune-up
  15. AutoGas (LPG) is it worth it?
  16. Wiper Arms
  17. 98 Transport trouble starting
  18. 1995 Trans port not shifting into OD
  19. 97 trans sport idle, but won't run
  20. 94 trans sport no shifting out of 1st
  21. ac control bulb
  22. transport 93 no spark
  23. 1993 pont,transport
  24. Trouble Code
  25. 98 ABS light trouble
  26. Electronic Readout on Ceiling Interior
  27. Van shudders
  28. TranSport Computer
  29. Fuel Injectors and Spark Plugs for breakfast
  30. Front Blower doesnt work
  31. tranny install
  32. 1998 Transport Humming
  33. going to try out 96 transport anything i need to look for than the usual?
  34. trans sport keyless entry
  35. 94 trans sport SE
  36. '94 TS 3800: RPM Question
  37. transports going to the scrap yard
  38. 98 Stalls in driveway on start up
  39. '94 3800: dies while driving...
  40. '94 Pontiac Trans Sport SE 3800 3.8L - Questions
  41. Aw crap...blew my transmission...(95 Trans Sport)
  42. '95 overhead console: orphaned cables
  43. '94 3800: OBD what?
  44. Pontiac trans sport 92. 3,8 code44
  45. 1990 TBI, Starts but dies immediatly. Sparks & FP runs but inj. pulse stops?
  46. Rear Control Arm Bushing Size
  47. 99 Transport Trans Noise
  48. Power Door Locks Fuse
  49. '95 3.8L Primary/Sec Resistance for Ignition Coil
  50. Metal intake plenum for 3800
  51. tranny took a dump
  52. My 3.8 is very fast
  53. Sensor middle top of windshield?
  54. Rack and pinion point of failure
  55. 94 Trans Sport-No voltage at fuel pump relay input
  56. new to these trans sports, relay question
  57. 2 3.1 Pontiacs, different electrical behaviour
  58. '94 TS 3800: HUGE coolant leak - and other fluids
  59. 1998 Trans Sport engine misses under load
  60. 95 Transport Charging system
  61. Greetings to you from Russia!
  62. 1997 TP 3.4 L Odor of anti-freeze
  63. 97 transport rough idle dies when warm
  64. 1998 Pontiac Transport 3.4 Driving like poo DTC codes!
  65. 95 Transport: Did the mechanic shaft me?
  66. headlights on when not running/ stoplight lenses melting
  67. Transmission oil in radiator:better watch for it
  68. 93 Trans Sports looking for good home
  69. 1995 Transport Lives on... 3800 III Transplant
  70. 95 TS 3.8 CEL on - codes P341-P321-P123
  71. Transport stalls when decelerating at slow speeds
  72. 1994 Pontiac transport back hatch metal top cover rusted
  73. 1997 TRANSPORT Surging
  74. 98 Transport - Overheating
  75. Fans in front
  76. Summer is still here and it's hot in the car.
  77. Do front 98 struts fit a 96?
  78. The Winter is coming and I don't have heating
  79. 95 Transport 3800 NO HEAT- how to flush system?
  80. ABS light on C1242 code... what gives?
  81. Cruise COntrol gets a new life
  82. Crankshaft Pulley/Damper
  83. Amazing MPG :D
  84. '95 3.8-Location of Neutral Start Switch?
  85. Driver's door lock
  86. 1990 3.1 Trans Sport Overheating
  87. 97 transport high rpms problem
  88. Po 366 which one?
  89. Cash for Clunkers: What should I save before turning in the Transport?
  90. Engine trouble
  91. 97 Pontiac Trans Sport Oil Pressure light
  92. Oil Pressure Gage Spikes when gas peddle is pushed
  93. Component Location Diagram
  94. 92 Trans Sport 3.1L v6
  95. Car Jerks in Cruising Gear
  96. Pcm
  97. 94 transport speakers
  98. Auto Lever PSI?
  99. Rack and pinion revisited
  100. 94 transport air pump
  101. brake problem 98 transport
  102. 96 Transport tranny problem
  103. 3800 TPS Stumps Local Repair Shop
  104. Trans Sport / Grand Am engine sparkplugs?
  105. Reversing the middle seatrow
  106. Engine Rattles when AC Engages
  107. 92 Dead Pontiac Trans Sport SE
  108. Overheating 98 Trans Sport
  109. GM Fuel Filter disconnect fitting
  110. 92 Pontiac Trans Sport OBD Scanner/Reader
  111. 95 Transport revs & surges
  112. The End. '95 TS 3.8
  113. Where does the coolant dissapear?
  114. how many #injecters?
  115. Code P1640-- P1670 QDM 1
  116. gauges
  117. 94 transport wheels
  118. Some questions
  119. Engine won't start
  120. 95 Xport remote door locks
  121. European TS (2,3) up for chain change?
  122. 93 Trans Sport Outer Door Handle Left
  123. Coolant Fan Maxi Fuse Location
  124. starting problems
  125. Trouble Code P1640 QDM 1
  126. 97 Trans Sport Key Fob Help Please!!!
  127. Electric malfunction
  128. The next best source for TS parts
  129. 97 Hard to Start Warm!
  130. Post your Baby's Mileage, Year, Engine
  131. fuel help
  132. 1993 fuel shut off
  133. Barney-style definition of trouble code
  134. A Problem With Transmission
  135. Inner tie rods?
  136. 1995 transport heater core replacement
  137. Oil Cooling Lines
  138. 96 front struts squeak
  139. 93 transport Transmission
  140. Left turn singnal issue?!
  141. Valves
  142. Engine stumbles on accleration
  143. AC compressor '95 TS 3.8 - How hard to replace?
  144. Power steering pump pulley
  145. Clock LED dimming out.
  146. '97 TP with Faulty Gas Gauge
  147. overhead console
  148. harmonic balancer
  149. 94 transport loud engine
  150. '95 Transport 3.8L Tapping Noise!! :(
  151. 94 transport tranny interchange
  152. '94 Transport Misfire
  153. Driver's Side Halfshaft needs replacing - 95 Transport
  154. Which o2 Sensor?
  155. 94 Transport water pump replace?
  156. 1993 Pontiac Trans sport SE Seats
  157. which way do i turn the passenger tie rod to get it off?
  158. Fuel Pressure Regulator
  159. 95 Transpport 3.8L CEL code acess
  160. 94 Pontiac Transport Power Steering
  161. Help! - I can't get the tie rod end off the shaft.
  162. 95 Transport 3.8 Intermittent slow cranking
  163. 95 Transport - Replacing Ball Joint and Tie Rod End
  164. Supercharger anyone?
  165. Power locks - 1998 Trans Sport
  166. 96 fuel pump relay chatter
  167. 93 Transsport A/C Heat - Ctrl Panel
  168. 1995 Trans Sport 3.8L stalls out while driving...
  169. 95 transmission shudder under load
  170. 94 Transport Heater Control
  171. Alt Gauge goes to Top. Now Battery Dead.
  172. Noisy front suspension
  173. HELP! Engine service indicator!
  174. Strut replacement..
  175. overheating still
  176. ABS & Low Fuel Light
  177. 95 3.1 Headlight problem
  178. rack and pinion leaking
  179. Dload free owners manual
  180. Electric Cargo door-where to start?
  181. speedometer not working...Tach is 95 3.8 TS
  182. Coolant not returning to rad from overflow tank
  183. 1993 Pontiac Transport Van
  184. BlackJack0021
  185. 1990 Trans Sport- Doors Won't Open
  186. 97 Trans Sport, no third gear.
  187. Trailer
  188. power door lock actuators for 96
  189. tranny woes
  190. 98 Transport heating
  191. 1990 Trans Sport Overheating- Causes?
  192. 15A fuse
  193. Cleaning
  194. 1998 Transport AC Cycle with Defroster
  195. 91 TransSport Rear Light Cluster. Which one is the indicator bulb?
  196. rear brakes
  197. 97 Transport jerks
  198. rear wheel wells rotted
  199. 92. Pontiac Trans Sport gearbox
  200. fog lamps 96?
  201. 98 P1870
  202. Dont start after engine warm up
  203. Grounding points 1998 Transport
  204. 98 Transport changing driving lights bulb !!HELP??
  205. 98 Abs
  206. 1998 Trans Sport air bag error code
  207. transport accessories & roof racks
  208. 94 Trans Sport High/Fast idle
  209. Fuel line lose in fuel rail
  210. 98 trans port dash removal
  211. Torque settings on rocker arm
  212. 95 Transport Stalling
  213. '94 pontiac transport plug wire protector
  214. trans sport stalling, surging
  215. Intermittent oil warning light.
  216. 94 transport turn signal,dimmer switch ,cruise switch
  217. Rear Hatch Popper
  218. 97 Pontiac Transport Head cracked
  219. 1994 Transport Fuel Problem
  220. Hmm..electric fans coming on at random..
  221. 4T60-E Gearbox Problem
  222. 95 Transport Oil pressure sensor
  223. Ignition switch replacement
  224. 94 Trans Sport missfire problem...bad Ign. Mod. ?
  225. Accumulator, moisture removal
  226. 98 Brake Torque Specs
  227. 94 pontiac transport radiator fan motor problems
  228. Engine stalled 93 transport
  229. Low oil level light always on
  230. 96 Option code
  231. 1996 Pontiac Trans Sport 2.3 electrical problems
  232. Temperature gauge ??
  233. 96 A/C question
  234. Trans Sport Performance Chip
  235. Pontiac Trans Sport 0-60
  236. High Idle after attempted kill switch installation
  237. Momentary Engine Cut-out Problem
  238. 1998 Power sliding door click
  239. front wheel vibrates at high speeds
  240. 1998 Pontiac Trans Sport Driver Information Center
  241. Fan stopped working on high setting..
  242. Having issues
  243. Having issues
  244. What does this dashboard light mean?
  245. trans. + handle
  246. tranny flush.. 3.4
  247. gas cap return spring ..gone
  248. Dash/courtesy Lights not working '97
  249. code P0441 EVAP incorrect purge flow
  250. 92 Transport Starter Issue
