View Full Version : Lumina
- 97 lumina: I need help taking the factory radio out
- '92 Lumina 3.1L start fine but sputter after warming up.
- 90 Lumina Euro Question (Weirdness in the RPM's)
- 2000 lumina smell antifreeze
- intake manifold gasket how to help
- 93 Lumina dies while driving
- 1990 lumina 3.1 idles, wont stay running
- 98 Lumina LTZ Electric "pulse"
- How to change battery 1997 Lumina
- High Idling
- bob
- 91 Lumina won't start
- transmission swapping
- electrical problem with a 95, classifieds?
- Idles rough then surges
- checking 3.1 injectors
- 93 z34 cant get timing set
- 1993 no start
- Engine lagging, help me guys.
- rust issues
- cracked windshield
- air cond. not working
- 97 3.1 Lumina Overheating..?
- Replacing Radiator...Need Help &Tips
- 1991 Chevy Lumina
- 91 3.1 lumina wont stay running after exhaust repair
- 97 lumina block heater?
- Oil pan removal
- 91 3.4 Lumina Misfiring
- Fuel gauge is bouncing.....
- 92 lumina no air out of vents at all
- Many interior lights out
- common lumina problem?
- My 92 Lumina needs help, runs like it has a rev limiter on it
- lumina is idling high
- amp install help
- 91 3.4 Lumina Spark Plug Gap Setting
- Problems after Warmup
- 96 lumina sedan 3100 motor missing on accelaration
- fuse box 2000 chevy lumina
- Poor mpg
- Power Window and Door Lock Switch?
- Could someone help me with a problem (Possible Leaf Spring?)
- ABS issues "abnormal" constant "clicking"
- 1996 Lumina hesitates when hot
- '92 3.1 Lumina Coolant Temp Light
- Need "How to" inst for a/c clutch removal
- need to know where the wires go on a 99 lumina 3.1 starter
- Help with Relay switch housing (corroded)
- This Sucks.....
- Reoccuring Tire Wear Problem
- Wiper Arm part numbers?
- 91 3.4 Lumina What Spark Plugs To Choose
- Fuel gauge problem
- Anyone have any idea's?
- Computer Module
- is head gasket blown and what can be done
- 1999 Lumina 3.1
- exterior mods?
- 97 Lumina brown foam in EGR
- 98 Lumina Cyl 6 Misfire.
- 90 lumina OBDI code 42
- Instrument panel bulbs
- What are my chances...
- 99 Lumina LTZ 3.8L Coolant level sensor?
- Factory GM Transmission Cooler for the Lumina
- Lumina tire size change??
- Do you own an LTZ?
- Brake shudder- 95 Lumina 3.1 Car
- New heads,, now it wont start
- 90 lumina euro stereo amplified question
- Crank Position Sensor
- Problems pushing button in to engage shifting
- 96-97 Engine Pics Requested
- irratic idle 98,3.1
- Scavenging Euro Parts
- AC knob does work, but the air is coming only through win and under
- 98 Lumina LTZ 3.8 with upper plenum coolant leak.
- 96 3.1 check engine shows 0401 code
- Chg Oil Soon!
- 98 LTZ Engine Knock
- 96 3.1 Oil in Coolant
- Changing Doors On A Lumina Ltz
- 92 Lumina Z34 Will Not Start
- 96 3.1 check engine shows misfire
- need help with tapping noise
- 92 starting problems
- 1998 lumina 3.1 intake
- Water in trunk!!!
- Thank you
- fule pump?
- 99 Lumina LTZ 3.8L Surges at idle sometimes
- 1997 with problems?
- radiator overflow tank question
- Charging Problem
- 95 lumina overheating problem
- cars slugish
- 98 Lumina Body
- Passenger Air Bag
- Bypass AC?
- Headlights don't flash.
- 92 lumina - blown fuel pump fuse
- Still having problems
- winter gas mileage?
- 92 lumina z34 stalled driving down the highway
- '97 tranny problem
- 91 3.4 Lumina Sputters? whats up with that
- 1993 Lumina with overdrive, How fast on D?
- Question about service engine soon light
- Lumina '93 V6 3.1, 200K - Oil question
- 1990 Chev Lumina Oil Pressure
- Using parts from other GM cars
- Should I Replace the Transmission or Fix it?
- 97 lumina.....service engine soon light?
- No Pressure, but have heat and temperature
- 98 lumina ltz stalls which slowing down
- location of coolant bleeder valves
- 91 Lumina New Water Pump Broke???
- 96 Lumina daytime running lights quit working
- Engine Swap From 96 Malibu 3100 Series To 91 Lumina
- 1998 ,water pump question =
- Flutter, shutter, skip, ~ minor annoyance
- New computer?
- Shudders When Idling
- 91 lumina euro will not accelerate past 25 mph
- ecm fuse blows 96 lumina 3.1l
- Fuel Filter
- 91 3.4 lumina Water Pump removal
- t-stat lumina
- Another possible head gasket....
- Transmission Pan
- 1995 Lumina with several odd probs
- heater problem
- 1997 Lumina....Squeak Over Bumps LOL
- Bad ECM?
- spark plugs
- So many lights
- Z34 Leaking Coolant Under AC Compressor
- taking anti freeze
- 98 Lumina loses all electrical power
- 95 Lumina car exhaust manifold
- average mpg
- 95 lumina shifting problems
- 95 Olds Silhouette EGR Valve
- Getting Spare down when Hatch won't open
- Location of TCC plug
- ecm?? just stoped workin
- help 98 lumina 3.1 coolant loss
- 1991 Z34 Exterior Door Handle Replacement
- Spark plug wiring
- Battery
- 1997 Lumina with a screwy gas guage
- 98 Lumina Head Gasket Problem
- need suggestions on car problem
- Need Parts& Assistance! 92' Z34 V6 3.4l 2door Red
- 97 Lumina Passenger Door parts
- 1998 hard starting=
- hot motor,cold radiator,no heat
- 98 lumina
- Replaced motor mount, torque struts, and trans mount on 93' Euro, still have noise :(
- Charging the battery
- 94 Lumina Overheat/Thermostat
- 91 3.1 problems again!
- Low Trac Light
- 91 Lumina Tach and Speedo Help!
- 96 C hevey Lumnia Wont Start
- Is this a fuel pump going out?
- 91 lumina seats
- 1992 leaf spring removal technic
- 95 Lumina problems
- Chevy lumia z34 smoking
- low coolant sensor goes on what direction?
- crank pulley won't turn
- 92 Lumina Z34 3.4 Wants to start, won't
- Something sings in front
- 95 Lumina Down Shift Problem
- Need to replace motor mount and trans mount on my 93' 3.1 Euro, anyone done this?
- Failed Emmision test
- Antifreeze question
- rear of car sitting low
- Winter Problem
- Remote door lock question
- What can you people tell me about a 94 Lumina APV?
- 92' CHEVY Lumina z34 Stalling out
- brake lights out
- Removing blinker switch 93 Lumina
- Power issue ??
- Cooling System problem ??
- 1996 lumina timeing belt
- opinions on 92 lumina Z34 value
- Bent rim
- 1990 Eurosport 3.1 stalled...no start
- Coolant problem?
- Stainless Steel Brake Lines
- Help PLEASE!!! 2000 Lumina 3.1 wont start
- PASS-Key II
- No electricity!
- Lumina Engine Problems/ Running Lean
- Signal
- Low Coolant Light
- Alloy Rims - 15??? WHAT???
- Cat converter replacement 93 3.1 ?
- 93 Lumina radio harness gone?
- Please help me figure out this noise in the front of my 93' Euro
- 94 Chevy Lumina 3.1 Euro - No Reverse
- 1992 Lumina Z34 wont start. Help
- beginner intake question
- 97 Lumina steering column
- 1998 Lumina High RPM's
- 93 Lumina did back brakes now leaking
- '94 Lumina Euro 3.1 fuel problem?
- 1997, 3.1l Lumina - ignition mystery?
- Location of crank position sensor on 3.1L
- 1999 Lumina LTZ Brakes
- 90 Lumina 3.1 dies at acceleration
- 1998 Lumina wont shift into gear
- 93 Lumina brake light on?
- Intake question
- 97 lumina, sudden stall and no start
- 1991 Lumina Euro wont start
- 1999 Lumina Shuts Off
- Odd question
- Headlights
- 97 Lumina front-end vibration
- Cooling System Help....96 Lumina
- car only starts atfer it sits for 10 min
- 1997 Lumina shakes when braking.
- 96 Lumina 3.1 P0420
- '98 Lumina won't run
- Would you buy again??
- Brakes and
- 1992 Lumina Z34 idle problem when cold
- Power Window Pooped Out
- Strut cartridge is off-center!
- 93 Chevy Lumina Z34 Coupe
- head swap?
- 92 Lumina speedo issues
- new fuel pump won't stay running
- Low Coolant Temperature
- Code 32
- coolant leak?
- 1998 Lumina - Can't shift into gear. Gear shifter button wont push in.
- Just did back pads...pad fallin apart?
- 1995 Chevy Lumina Won't Start
- Blower Motor
- W-Body 4T60-E Transmission Problems
- 1996 Lumina Stalls and Misses
- Service Engine Light
- Coolant???? Going where????
