View Full Version : Contour
- qwik question
- 96 zetec Bad pcm again?
- 96 Ford Contour Gear Shift Console
- Running lights dont work!
- ABS light and no power
- Countour stalls?
- Okay, I need some help
- 96 Ford Contour Vehicle Speed Sensor
- Basic 4 Cylinder 2.0 Engine - Interference?
- lugging problem
- wiring
- Mega Fuse Where?
- contour tranny problem
- Custom HVAC, Headlight Knob, and Gauge Faces
- Mount under air filter
- in need of a couple parts
- 98 running hot
- 1999 Ford Contour Fan relay
- 98 contour -- a couple problems
- what size?
- Fuel filter?
- Update - 98 Contour Reprogram Keyless Entry Transmitter
- ac and heater problems
- freedom at last!
- 98 Contour Reprogram Keyless Entry transmitter
- 98 Contour AC Compressor!!!!!
- 97 contour 2.5 Cam Chain tensioner question
- Very lost....
- im having alot of problems with my contour
- Battery light problems..
- 1998 vtec no start
- Help
- crakshaft bolt
- problems...1-10
- wiring diagram 96 zetec
- 96 contour zetec no spark
- 97 engine R&R
- 95 Ford Contour V6 with transmission(?) problem
- lack of power, rough idle
- Weird noise in cam....
- wheels and tires
- How to Remove cam Pully on 2.0 Z-tech that has oil&spring sprocket
- 1996 ford contour won't start
- parting out 1998 ford contour sport!!!!!!!!!!!
- problems with cONTOUR
- Fog Light Relay rewiring for fogs on...
- 2000 Contour automatic stutters/dies when gas is low
- crankshaft sensor problem ?
- 98 contour keeps stalling
- 99 contour backup lights
- 99 contour v6 runs rough and burns tons of gas
- trunk light 2
- '97 Contour GL, 2.0L, Manual, 4-Cyl, 140,000mi
- Clutch is shot on SVT?
- 98 Contour A/C Fan Died
- trunk light
- Dead 99 SVT HELP
- Couple problems
- Dire need
- aftermarket performance parts?????
- Turbonator---Worth the 130
- A few problems...
- Used Contour Sport
- Tire Won't Spin
- Car keeps stalling unless given gas
- my first car
- where is the pcv valve and how to I change it 95 contour
- 2.5L V6 Stalling in Cold Weather Sollution
- Various Problems with contour
- Brake Job (Drums)
- 95 contour turn signal relay
- 2000 Contour
- Speaker Replacement
- '95 2.0 idle prob
- 1997 Contour Transmission Problems
- cigar lighter wiring
- car speakers
- ABS Brakes Help!!!!!
- 97 trans problem
- Fuel pump problems
- Starts but then stalls instantly ???
- 2000 contour se won't start
- got a few issues
- Brake question
- 1997 contour blowing pcm fuses
- 99 ford contour 4 cylener
- need parts
- 98 V6 timing belt or chain
- need some help
- timing belt eater
- Coolant
- What the crap?
- Starting Problem
- '95 Contour. Diagnostic codes???
- 96 contour for the guys that know about codes
- 95 Ford Contour-running hot, can you prevent blowing a head gasket
- Parts for you
- 95 Ford Contour
- Lights
- 98 contour v6 throttle cable. please help!!
- 95 contours pleas help
- back with questions about the 96 contour
- 95 Contour GL with 2.0
- Looking for "beyondloadedSE"
- Accesory belt Replacement on 98 2.0,,AAARG!!!!!
- newbie
- performance
- 96 contour ticking noise
- 98 contour radio,remote mirrors,map lights not working
- 99 contour idling rough
- Help by looking under your hood...
- Flashing O/D Off Light means what???
- are there 2 different spark plugs in this engine
- warped dash help
- contour keeps dieing 95 contour
- How to replace spark plugs v6 2.5
- help
- Engine
- tcc sylinoid
- Help Finding and removing ABS Module
- Heater fan blowing fuses 96 Contour
- 96 zetec timing marks
- 98 4 cylinder SE Alternator removal - HELP!
- 98 Ford Contour ABS light-how to replace fuse
- 96 contour no forward gear
- 1996 Contour wont start either
- engine replacement
- blown head gasket
- 1998 2.0 4 Cylinder Clicking won't start
- a REAL screw up!!
- 1999 Contour SVT- Catalytic Converter
- For Sale: Zetec head $95 Free Shipping!
- brakes 2000 contour SE
- 1995 4Cyl 2.0L Acceleration/Idle Problem
- 98 2.5L Idle Problem
- Need 96 Ford Contour 2.0 Timing marks
- 96 v6 contour surges
- Car Wont Start
- 96 Contour SE
- Idle Air Control Valve?
- Side View Mirror
- how do you replace tp sensor on v6 contour
- 96 contour motor ?
- Heater Core in Contour
- 98 contour random misfire help
- timing belt guides/idlers on 1996 contur 2.0 liter
- 96 contour v6 giving codes
- how much to replace headgasket?
- Fan Noisy
- 98 contur problem with belt keeps breaking PLEASE HELP!
- 1999 Rough Idle Problem
- Stalls/Rough Idle in Cold Weather
- IAC Valve.
- 96contour will not start
- swapped out engine
- Strange Idling Issue with 98 Contour
- tail light 1995
- 1995 ford contour want start
- 1996 Contour hard on fuel
- National Spring Zing 2006 SVT Contour Meet
- P0304 code, rough idle, better since code
- Turbo
- have to depress accelerator to start 95 contour
- Melted vacuum hose destination
- how to fix my wiring harness?
- Anyone live near pontiac Mi want to replace a timing belt?
- Timing belt/water pump installation - What did i do wrong?
- Battery Light Flicker & illumination
- Turbo for a Contour?
- Timing Belt Replacement Cost and Labor
- timing belt- what did i do wrong?
- Broken cam/timing chain and I need a new engine???
- 98 Contour Duratec v6, Stalls at idle
- 1995 Contour tansmission
- 1995 Contour fuse layout
- 96 contour stalls, looking for filter.
- battery wont hold charge
- Contour 95 SE, need replace wiring harness?
- 97 contour (instument panel no lights)
- 95 Ford Contour 4cyl help please
- wont shut off, help!!!!!!!
- Pls Help is it the tranny ???
- A/t Transmission Problem
- svt contour catalytic converters
- Okay, it's not the VSS.......
- need BIG help
- Lumpy idle and bogs down at 4000rpm
- won't start
- ideas!!! plzz
- 2000 contour se 4cyl
- probs(please help)
- Water pump working?
- 96 Contour Overheating
- window
- just want to hear
- intake runner
- more probs (please help)
- rims
- my 1999 contour se
- need everbodys help
- 95 ford contour problems (please help)
- 1996 Speaker Size?
- 95 Ford Contour Stalling
- check that... I need a 2.5
- 94 countour starts then shuts off
- 2.0 Timing Marks
- 1998 Contour overheating
- Need To Find An Engine!!!!
- 96 Contour Flasher clicks anytime key is on
- 96 Contour right turn signal
- Steering Wheel Vibration (shake) Contour 97
- contourRadiator fan wont come on
- 97 starts, then stalls
- Speedo Stuck at 60kmh
- Speedometer Falure
- 95 mtx contour won't go; throttle cable or traction control?
- 96 contour intermittant no spark
- Rotors
- how to change the engine mount insert
- loud noise in rear
- 1998 Map/Interior light
- Contour SVT vs V6 Camaro
- 95 Ford Contour, 2.5 Automatic Trouble starting in cold
- speaker wiring diagram
- car problems, it won't move (even in neutral)
- electrical Problem
- wheel bearings
- 1998.5 contour svt catalytic converter
- 4 Sale 2000 Contour SVT 62K miles tons of mods $6400
- Same problem, new twist.
- Fuel Tank Door
- transmission or something else?
- Exhaust 97
- Sunroof won't shut... HELP!!!!
- 99 Contour SE's motor mount
- Re-set Fuel Pump
- 95 Contour 2.0L Lost speedometer,cruise,Overdrive
- Replacing engine
- 1999 ford contour no brakes
- 2000 contour code problem
- Odd idle from 98 2.0
- Broken Tep guage
- 98 contour transmission? need help plz
- MAF Sensor problem, 1995 Contour GL, 4cyl
- Wet Carpet
- 98 2.0L Vtec timing belt issue
- help
- 1998 contour SVT 4 sale
