View Full Version : SC/SL/SW
Pages :
1 2 3 4 5 6 7 [ 8]
9 10 11 12 13 14
- Idle Fluctuation/Stalling
- Car will not start
- speedometer
- question for a saturn technician
- help with a bad cylinder
- Lifter hitting Valve Cover
- Sale
- Headlights will not go off
- SES light
- Cooling sensor and radiator fluid leak
- Help! Fuel Pump Electrical Problem
- ABS on a 97 Saturn sc2
- Parting Out '94 SL2
- Am Fm Cass to AM Fm CD in 96 Sl
- brake tool
- Really Really Unusual Saturn SL Project
- ugly
- blower motor, IAC & ECTS prices?
- SES playing games
- FS: wheels
- service bulletin
- High Idle Problem Figured Out!!!
- how to get more speed
- "Performance" switch
- car vibrating
- blower motor???
- LOUD whining 1998 SC2
- shifter assembly
- electrical problem,turns over 95 sl2,brain?
- engine hesitation and other problems
- RCA for subs
- radiator removal
- loose front bumper
- Driver door stuck closed
- goodyear triple tread tires
- 97 sl-1 -
- car dies
- distorted chimes
- IDLE: super high/extra low........
- 1995 SL2 electrical issues.HELP PLEASE!!!
- 2002 SL Temperature Sensor
- saturn sputtering
- oil filters...
- SL1 - Brake Lights off went head lamps on
- Rough Ride
- 1996 sl2 5sp tranny
- High idle, engine loses power, bucks sometimes....
- Oil Filler Cap
- Help my Engine
- Saturn SL2 speakers
- Automatic shift cable
- saturn newbie
- window problem, please help!
- 1995 sl2 turn key....nothing happens HELP!!
- Replacing Seats with Aftermarket seats.
- Undercoat or oilspray?
- Code P0440 Evap Emission Ctll Malfunction
- installed new fuel pump, now runs rough
- Trunk latch stuck - HELP PLEASE
- bad clutch = high idle???
- Funny Noise in the Engine
- SC2 Suddenly no electrical
- 97 SC2 instrument lights
- Rough idle problem When engine light comes on
- Need advice on saturns..
- new member-93 saturn help please
- i love my saturn
- What does a "Brakes" light on my dash mean?
- When are new brakes needed?
- O2 sensors
- new to saturns
- Service Engine light on
- 1999 Saturn SC2
- 01 saturn sc1
- high idle that will never die!!!!
- Duplicolor Fabric & Vinyl
- 1998 Saturn SL2
- How do you get the rotors off
- Oil Additives-carbon cutdown and engine maintenance
- 1995 SL2 maintenance
- '95 SC2 EGR Valve
- proper jacking locations
- Need to know the name of the part..
- Engine block swap
- starting problems
- engine codes
- Wheels still for sale
- anyone looking for sl1 or sl2 parts?
- 94 sc1 engine light
- clutch rebuild
- 2 problems with '95 SL1
- 91 Saturn
- stock tweaks
- 98 SL1 Intermittent No Start/No Fire At Plugs
- 97 SC2 keyless entry
- car seems to start whenever it wants
- Key stuck in ignition?
- Computer Problem?
- Jumped incorrectly, not it won't start. Please help!
- Anyone need a parts car?
- 97 Saturn SL2 codes and Running problems
- noisy sunroof weatherstrip
- constant 4000 RPM after engine install
- My radiator..
- interior 97 sc2
- Wheels for sale
- 98 SL1 head? gasket? block? :(
- light reset
- '96 SL2 Starting Problems
- Blower fan turns on when car is off
- Want to buy a new engine.
- Floorboard leak help?
- 2000 SL1 Transaxle
- can you match a throttle body to any intake manifold
- Trans operation normal?
- stripped bolt
- Transaxle Seal
- '98 Saturn won't start
- help 2000 sl
- brake change
- Hard Starting, stalling & fuel smell
- Scan Tools Spec's
- 96 sc2 for sale
- 97 SL 1 Ignition smoke
- brakes pedal goes to floor
- battery light
- Header?
- cleaning IAC???
- 97 SL Electrical Problems
- wheel lock delima
- Is changing a tie rod a "do-it-yourself" job?
- My saturn got hit by some punk kids
- windshield wipers won't turn off
- 95 Sl1 Transmission
- exhaust
- Head Gasket
- 2001 SC2 Service Engine Soon Light / Codes
- OBX header
- Trunk lock blows fuse
- Saturn SL 1995 - Wont Start
- is this a good buy
- radio changeout 2000 SL2
- Aftermarket Parts
- Wierd RPMs
- 96 SL2 turns over, won't start
- ac/heater low air output
- Power restriction
- swapping engine??
- Slamming between gears on an automatic
- 2000 SL2 Cruise/Hood release
- another way to save gas
- looking for knowledge on a 1.9l sc1
- Iceman or AEM?
- Saturn sl1, 2001, starting/ignition problem
- 99 sohc engine swap
- crack in the head: defective engine
- swapping out a 95 sl1 for newer?
- low mileage saturns
- The Slamming sound between gear changing
- 2001 SC2 Service Engine Light
- high idle
- slick 50?
- 2000 Saturn SL2 rear door handle removal
- crankshaft position sensor problem
- shifting sounds
- 2002 1.9 engine ??
- brake change.
- Please help!
- 97 SC2 will not start ????
- tranny fluid?????
- 99sc2(manual) wont start
- engine rev.
- gas mileage survey
- oil changes.
- Car wont start
- car starts but stops immediately; please help
- '93 SC2 for sale......
- radiator fan operation
- Saved $130 with fix for manual shift linkage
- 1998 SL1 Speakers
- 91 SL2: How to flush & replace Power Steering Fluid
- key stuck in ignition 95 saturn dohc
- largest sized rims?
- 2000 sl2 bodkit
- fuel injectors
- 1994 SC1 Sunroof
- car hesitates while shifting
- headlights
- Saturn SL2 won't start-not the starter
- Changing the fuel filter on a 93 Saturn SC2
- Question about oil.
- 1997 SC1 fuse diagram? electrical prob :(
- O2 sensor
- replacing belt
- 1995 SC1 wont start or turn over nothing
- How to change the oil filter on an SL2?
- 94 SL2 Stalls when driving
- high idol
- 1994 SL2 Wont Start
- 99 Saturn SL2 Check Engine Light
- O2 sensor and Camshaft Position problems
- ticking sound from tranny
- WTB saturn ignition coil - read i have questions
- My saturn wont start
- 91 SL2 Strange Noise Problem
- wheel/rims
- '94 SL Odometer Gear Tooth Count?
- Aftermarket Cruise Control
- I have a 99 SC2
- push button ignition
- Idle speed is 2100 rpm
- Cooling Fan
- 1998 Saturn Warning Lights
- K & N
- 98 SL1 Stalls at cruise speed?
- door chime
- Need help on center console removal on 93 SL
- A couple of questions
- Idling High/Dieseling at shut off/accelerates on it's own/too much fuel
- dash brake light
- shudder
- weight
- 95 SL2 stalls at stop after 3,000rpm rev
- trouble code
- Front end body parts
- Oil in Cylinder no. 1
- dual exhaust
- SC II Front Brakelines
- 95 Saturn SC2 Floods
- 1996 Saturn SL1 1.9L oil in overflow tank
- Flip Up Headlights
- pcm testing
- How do i change clutch in 1991 sc without pulling the motor ? Can it be done?
- Dexron III synthetic or Blend atf fluik
- horse power?
- Newbie Advice Needed - Rattling Noise in Car
- c.a.i.
- this is weird wonder if it really works
- 97 SL2 keyless entry system
- My Tranny is acting up , HELP ME!!!
- 1996 SC Low coolant light
- PLEASE HELP!!! radio locked
- speed o meter stopped working
- Fs: Injen Short Ram $100 (brand New)
- 95 sl2 only fires on starter fluid please help!!!
- 98 SC2 Starter
- Engine Compression
- Service Engine Soon light on 99 SL2
- 97 sc2 manual shift linkage
