Car wont start
97sc1owner
09-08-2005, 01:03 PM
Help! I have a 1997 Saturn SC1. The car starts to crank but does not turn over, it just makes a rapid ticking sound. Why won't the car start?
atc2be
09-11-2005, 09:34 AM
Sounds like either the battery is dead or you have a bad starter. Is it turning over at all? Usually the click is because you have just enough power to kick over the relay or if you have a bad starter, the relay clicks in but the starter is seized. I doubt the engine seized from just sitting there
sierrap615
09-11-2005, 09:59 PM
i argee with the bad starter or battery theorys.try a jump start, if you have a manual trans also try a push start. there is also a small chance you have a damaged flywheel.
97sc1owner
09-21-2005, 04:26 PM
Turns out, it was the battery. I was so glad that it wasn't something expensive.
atc2be
09-21-2005, 07:49 PM
glad it was just the battery...amazing how 5 minutes and an internet connection can save ya a ton of cash..
