View Full Version : Rodeo | Passport | MU
- 1995 4X4 manual trany
- Computer chip in 95 rodeo?
- Adding Remote start/keyless entry
- Parking Brake Light?
- Timing Belt problems
- '92 Rodeo 3.1L V6 Erratic Idle
- 1995 Passport 3.2L BackFires?
- Rodeo/passport replacement
- Freeze Plugs
- Eeek! Friend hit 5,500 rpm's...anything to
- Do I REALLY need the front hub nut tool?
- Manual Hub Install on '01 Passport
- Valve Shims on 6VD1 DOHC
- isuzu engine runs rich
- wanky suspension
- 94 passport constant stalling problem
- Out Of Ideas & Money
- power steering hose
- '98 3.2 camshaft timing
- 98 Isuzu Rodeo Engine trouble
- P0753 - shift solenoid electrical
- lock and other issues
- New Alternator Installed, New Problem
- How do the spark plugs come out?
- 2000 Passport Shock recommendations
- 2000 Rodeo Instrument Cluster or ???
- Deadly Warning for dog owners in TX, FL, & CO.....
- 99 Passport stripped EGR pipe nut. Plz help!
- Passport/Rodeo rims & tires Questions
- 1996 Passport EX For Sale
- 91 2.5l Diesel engine swap
- 1995 Honda Passport Leaking Brake Fluid
- 96 Rodeo Charging Problem
- 96 Passport Valve covers
- Lifting the Green Goblin 2"
- Stereo Installation - problem with instrument panel lights
- engine stalls after rough idle
- 1997 Rodeo suddenly dies
- Fuel pump dying? '99 Rodeo - Anyone?
- Coolant leaking from under 1996 Rodeo 3.2L
- 1999 Passport CEL codes
- Special plugs for '01 Rodeo
- Blinking CEL, runs rough - for a friend
- Wanting to tackle tb and wp
- Rough riding 99 Rodeo
- Alternator Belt too tight?
- Where is it?
- Alternator Amperage Question
- Plane crash site trail run pics
- FYI - No longer using Napa Gold's on.....
- What size shocks needed for a 3" lift?
- Rodeo Sport Amigo Top Zipper Window Repair
- Don't call her ole' faithful for nothing....
- Electrical Issue: Radio (AUX) Interference
- Cen-Tech OBD II CODE READER
- 2000 Rodeo. slipping transmission
- 4wd light blinking, shifts into 4wd, in 4wd grinds in tight turn
- temp idel falure
- 1997 Just quit running
- 98 Passport condenser install instructions
- Dealership 2nd opinion...
- Interesting P0300 Code on 2001 Passport
- Another timing belt ???
- New spark plugs without new wireset?
- I MUST be crazy......
- 1998 rodeo
- 95 Passport hamonic balancer removal
- Feeler for Daily Driver
- Leaking tranny fluid from up top?
- where can i find a lift kit
- CEL(Check Engine Light)
- More Colorado scenery pics for SurferFletch
- 99 isuzu rodeo0(5spd-manual)question about battery?
- 93 borg warner 5 speed
- 93 2.6 rodeo ticking.
- 2000 Rodeo 'Slip Yolk'??
- will the 94 gauges fit into 91?
- Timing Belt--when to replace?
- Our 900 mile journey thru Colorado Rockies...
- power loss @ check light
- 93 Rodeo Stuck Rear (tailgate) Glass
- Disgusted in Colorado...tell me about Montana, WY,
- A/C: Air conditioning stopped working
- Outer CV boot
- 93 rodeo engine power loss
- 99 Rodeo (Frontera) ABS braking issues
- 95.5 3.2 v6 runs rough @ 2k rpms
- Normal Idle RPM
- 99 Passport Voltage Inquiry
- Problems putting 99 Honda into Park.
- 01 rodeo starter problem ?
- Tranny leak?
- Automatic trans not shifting
- Rodeo, rear doors will not open
- Squeeling noise at idle when started
- Removing the resin top?
- Power loss and red hot catalytic converter
- well just checked my oil
- is it bad gaz
- 2004 Rodeo Stalls Randomly
- Engine question...
- Auto tranny fluid....can I use
- Contemplating Rodeo purchase, some questions
- Tires falling apart?
- props for the FAQ's
- Out Went The Lights
- 1993 Isuzu Rodeo 3.2L V-6
- 2000 ISUZU RODEO ABS ligt on
- + 1 (million) for BOSCH alternator!
- cruise controll not working
- Rattle in dash - any other ideas
- Replacing a Transmission for a 2000 Rodeo
- how to remove the starter from a 2001 rodeo 4WD
- wiring up a condesor fan
- 95 blower fuse melt problem
- Grand Mesa pics.....
- Fender flares added - what are your thoughts
- Traced my non-4x4 actuation...
- mechanic labor charges, Serpentine belt & signal switch
- engine help
- FL3.2/Surfer - fender flares/pics anyone??
- sunk rodeo back end = now wont start
- what do you guys think of her
- honda passport grill and badges
- ABS an option or it comes with all rodeo's
- 336 & 351 Codes
- Electrical Problems
- few questions
- Rear Rotor
- Rodeo replacement: which way should i go....
- 98 Rodeo - ABS kicks me?
- Diference between passport and rodeo
- winter/power button
- 97 Passport clutch problems
- 4x4 question need help
- speedometer
- Hot Start Problem
- 1995 Rodeo sounds like a diesel
- 97 Rodeo AT comes out of Lockup at 60mph+
- 98 Passport sounds like a Harley
- intelligent suspension light
- Dome light in trunk area = DEAD
- Cargo Net Problems
- Reduced Power warning light
- I have your sending unit. Do you have my regs?
- Transmission Problem
- code 0405 on isuzu 2001 4wd 3.2l
- Speedometer
- Help Window Problems 98 Rodeo
- Y-Tail Pipe & Muffler
- 99 rodeo "jumping" tachometer
- Replacing the overdrive pan gasket
- 99 Honda Passport issues with parking..
- window up and down problems
- High Erratic Idle
- 97 Passport EX - Overheating Problems, Please Help!!
- Want to replace the front rotors. A couple of questions.
- 99 Passport intermittent wiper ( Where is it ?)
- 97 Passport no fan problem
- 98 Rodeo - Hard Starts
- 96 Rodeo w/p0151, p0153
- biggest tires
- Sorry, it's another alternator question...
- 1996 Power Window Fuse keep on Blowing
- I've HAD it.....help me decide on new tires....
- 99 Rodeo Suspension
- 97 isuzu rodeo m/t 4x4 won't engage
- Blower motor
- Best mileage yet!
- 95' Passport Blower Motor
- 1999 Rodeo V6 4WD
- sig check
- 4WD light blinking
- Parts?
- 99 Rodeo with Loud noise from Right front!!!
- 94 Rodeo Intermitent Engine Light
- Can't open my hood
- Check Trans light comes on together with Cruise Set light
- Power drive light question....
- 1993 Rodeo CODES..........
- Removeing cat's on 2002 rodeo-PLEASE HELP!
- My 99 PissPoor
- 2001 Rodeo Hot Start Problem
- 96-97 3.2L sohc Rodeo's prone to rod failure???
- 2000 Isuzu Rodeo Timing belt/Tranny question.
- Something wrong when car starts in the morning!
- Deer Creek / Saints John / Bill Moore run
- 96 Isuzu Rodeo 3.2l V6- Clutch!!!
- few questions on my passport
- Throw out bearing dilemma...
- 2000 Isusu Flywheel/Torque Converter
- Bad Flooding Yesterday.
- Which US dealers ship parts to Toronto Canada?
- Can you Reset the Speedometer?
- Need help!! 98 Rodeo won't start tried everything
- Looking for a used/rebuilt engine for 2000 Isuzu Rodeo
- 2001 Rodeo Muffler
- 1995 isuzu rodeo wont start
- 91 Rodeo, 3.1L w/blown head gasket...Which repair manual do you need?
- Giz - have you been to the grand mesa
- TECH 2 Scanner
- p0101
- Reand End Roaring
- '98 - '01 Hatch Glass O-Rings (For Sale)
- vent / bypass cooling hose
- 95, electrical problem any suggestion at all?
- 1993 Rodeo Overheating
- Surfer - here's some *mountain* pic's
- 95 Passport Rear ABS and Brake light on Panel
- rodeo crossed with pathfinder
- One more pic and question>>>
- Pics of the girl as she is today....
- Pics of Blue Mesa 2006 Colorado
- Pictures - long awaited...lets see if
- 2001 Texas Rodeo, 4cyl. engine
- Surfer/Giz - found my vibe problem....
- R1 concept vs Ac Delco brake rotor
- bad idle after head gasket replacement
- Problems starting 98 Rodeo
- 2000 Rodeo Transmission stuck in Limp mode.
- is it the catalitic converters
- 2001 Rodeo Sp-Evap Readiness-NYS Inspection FAILED
- 4L30E secondary clutch drum
- accumulator piston cover and range selector seal arrived
- CD player has no pwr no door panel lights
- ATF To change or not to change?
- What's it worth with a Reman Engine?
- Tranny leaking
- Overheating , Don't know why.... please help !
- 4 Colorado mountain passes...truck's still got
- Intake Air Temperature Sensor On 95 Rodeo?
- tailpipe bangin' into the hitch
- Brake Bias Problem on 2001 Passport
- transmission heating in rodeo 2001
- FIGURES! I'm like the worlds .........
- Engine Failed, Now What?
- Fuel Pump????
- Noise at 45-60mph
- 92 92 rodeo tranmission line? need help identifying
- need drum brake drawing or pics
- Rear brakes locked and ABS light on.......
- 97 Rodeo codes 0300 and 1133
- Honda Passport 2001 NOISE
- engine dies immediately after startup
- Rodeo just serviced
- 95 passport Fuel type
- Saying goodbye to an Ol' Friend
- Timing Belt replacement
- Used 98 Isuzu Parts for Sale
- Made it to New England!
