View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25
  1. Wheels
  2. Clunking noise from the rear (but has new shocks!)
  3. do i have a interfarence engine {95.5 3.2 passport}
  4. loud knocking in the center
  5. 97 rodeo 4 wheel drive wont engage! help!
  6. Check engine light problems
  7. Air conditioner "cycling"
  8. tips 4 removing a 3.2 V6 DOHC on a 95.5
  9. 95.5 3.2 V6 DOHC removel
  10. Some obscure issues here.
  11. I think my timing belt went...I have a question
  12. Code P1153
  13. 93 rodeo...should i buy????
  14. How much oil
  15. 2000 Isuzu Rodeo doesn't start
  16. Brakes/Intake/ABS/Wheel Sensor/Turn Signal/Fuel Sending Unit
  17. engine light
  18. clock
  19. Intelligent Suspension
  20. Alternator Repair
  21. Help Removing crankshaft bolt on 3.2L
  22. OBD 2 Code PO 420
  23. Exhaust Flex Pipe
  24. Surging fast Idle when hot...
  25. Drive belt tensoner
  26. Loud knocking noise
  27. Alternator issue or not?
  28. boots
  29. Diff Lock or LSD on '99 2wd LS???
  30. Seeking Nominations for an Isuzu Moderator
  31. 98 Passport Won't Start
  32. 2000 LSE w/ ISC shocks
  33. Log of my first 60k of maintenance
  34. Need help filling transmission fluid
  35. In need of serious help with 96 Rodeo
  36. 1992 rodeo will not start--electrical?
  37. 1994 Rodeo turn signal problem
  38. 1994 Rodeo Keyless Entry - Can't buy aftermarket remote without FCCID #
  39. 95 Passport Wouldn't Start
  40. I see quite a few posts on where to buy factory parts, here you go
  41. Timing belt
  42. Apology to 2eyefishclaw
  43. bye guys (read this)
  44. Speakers
  45. 92rear wiper n0t working
  46. acceleration/sputtering issue 95 Rodeo
  47. back from shop...high idle rpm
  48. fuel sender and ecm reset?
  49. ABS recall ? reimbursement ?
  50. Possible bad alternator??
  51. I'm thinking about buying a Rodeo what do you think?
  52. Blower motor
  53. 1995 Rodeo Very Cold Weather Start Issues...
  54. 2nd gen. Rodeo fuel sending unit / fuel pump
  55. Need Advice! Just bought '95 Rodeo w/110k miles
  56. flowmaster check engine
  57. 99 Rodeo 3.2 stalling
  58. 97 Rodeo P0300 random misfire
  59. Need Help Asap Electrical
  60. 98 passport losing oil
  61. rear wiper motor wont quit
  62. Clutch and Transmission Replacement
  63. need help finding
  64. need help finding
  65. 95.5 Rodeo 4X4 Rear Suspension (leaf springs)
  66. Importance of PCV valve replacement?
  67. Clunking noise when turning
  68. Would you swap belt driven fan for electric fan?
  69. Old Rodeos
  70. Replace 3.2L V6 Engine
  71. Clutch woes! please help!
  72. 99 pass port fuel pump problem
  73. Help. Must change Starter on 93 Rodeo
  74. How do you check the tranmission fluid?
  75. Electrical problem solved; you won't believe the cause
  76. Welding an exhaust flange - tailpipe!
  77. passport starter replacment
  78. help with CEL
  79. 1995.5 4X4 Problems!
  80. 1994 rodeo cooling fan
  81. Isuzu Rodeo Coolant
  82. Charging light on, brake light on, fuel light on - No A/C fan
  83. P255/65R16 tires on 2000 Rodeo - Tire pressure?
  84. All sensors in front of intake names?
  85. 95 rear door hatch won't open..
  86. Rodeo or BMW- you make the call!
  87. Ranchos
  88. High-pitched loud whining noise when tranny selector is set to D.
  89. BGK 44 fuel cleaner? Anyone use
  90. P0440 = EVAP System Malfunction
  91. manual on ebay
  92. CEL on and Check Trans light blinking.
  93. Buy a nice 98 4x4 !!!
  94. [Exhaust] Bent pipe.
  95. 2000 Rodeo Transmission Noise
  96. I need some tech advise on belts on 94 Rodeo
  97. Heater not hot
  98. 94 Rodeo Trans light blinking
  99. reverse glow gauges
  100. 4WD Indicator Light
  101. 99 Rodeo Wiper Interval Module
  102. 95 Rodeo Child Safety Locks Problem
  103. HELP!!! '94 Shifting Problems
  104. Isuzu Rodeo (97)
  105. Rear window wiper
  106. "Check Engine" light during shifting
  107. Head Gasket or Valve CoverGasket?
  108. 2003 Washer Fluid Change
  109. 94 Passport with Problems
  110. Noise coming from Somwhere???
  111. took Rodeo into shop>>help!!!
  112. gm t5 transmission on the1991-1992 3.1 liter rodeo ?
  113. Possible coolant leak
  114. 2001 Isuzu Rodeo Sport spark plug location
  115. lubing the slip joint on 2 piece drive shaft????
  116. O2 sensor light reset??
  117. Shifting problems
  118. 93 rodeo electrical
  119. Need help with rear wiper
  120. 92 rodeo codes 34 and 45
  121. Aftermarket light bar with off road lights
  122. Warn manual hubs
  123. 2001 Rodeo Security System
  124. Clicking noise, sounds like relay behind frontdash passesnger side
  125. weight of oil
  126. CV half shaft problem?
  127. electrical? 98 Rodeo wont start - coincidentally after fender replace
  128. airhorn install/fuse problem
  129. red light
  130. Equiped with cruise, but will not engage
  131. 92 rodeo how to remove oil sender unit
  132. Relaced Tranny now have another problem
  133. How do you drain the block?
  134. Wiper Fluid Stopped Working
  135. Low voltage at idle
  136. headlight adjustment
  137. high oil pressure then drops down when idle
  138. engine fuze
  139. is it hard to replace the valve cover gaskets on a 92 rodeo 3.1 liter with the carb
  140. Looking for a 1988-1995 Isuzu 4x4 pickup.
  141. 98 Rodeo Engine trouble again
  142. 98 rodeo Heater Core help
  143. Reduce power light
  144. Passenger side keyhole
  145. 1st gen Rodeo rear speakers!
  146. Is it a water pump failure?
  147. Help!!just Bought 99 Rodeo;car Shakes When I Accelerate
  148. Low Oil Pressure issues
  149. 1992 rodeo,2wd.. can a transmission be rebuilt?
  150. 93 rodeo stalling problem
  151. tail light and dash light trouble
  152. Isuzu Rodeo 94 engine problems
  153. CV Boot
  154. Wiper Motor \ Arm Disengaged
  155. T-Belt tensioner Where to buy
  156. Engine won't crank
  157. Both brake lights out
  158. Sylvania Silverstar Headlights
  159. '99 Rodeo standard front heights before torsion bar adjustment
  160. Starter Problems
  161. 1994 Passport Check trans light--help
  162. Popping noise when operating door
  163. Moonroof inoperable
  164. Fuel Sending Unit Part Number
  165. trooper wheels
  166. what does code P1406 for Rodeo 97 mean ?
  167. Backpresure on 98 Rodeo
  168. optima batteries
  169. wiper fluid problems
  170. CV Boot Replacement - '95 Rodeo
  171. 1992 radio wire color codes (odd colors)
  172. Torsion bar adjustment
  173. 97 rodeo fuel pump probs?? help!
  174. Timing Belt Cover / Tension pulley mount
  175. Aftermarket Alternators - You guys were right!
  176. changing fluids DUMB Questions
  177. 1994 electrical problem I think??????
  178. Rodeo Puzzle: No Start, only a click on ingnition
  179. 93 Isuzu Rodeo tailgate needed
  180. help...94 won't start when cold out.
  181. Rodeo jerks at highway speeds
  182. 2000 Rodeo Sport with P0128
  183. Rodeo Speakers & Audio
  184. U/S Light
  185. Whistling Sound
  186. fuel pump help
  187. broken fuel pump help
  188. 92 rodeo help
  189. virbation at highway speed
  190. Heater Core
  191. Sloshing sound
  192. SL Timing Belt
  193. Coolant Flow
  194. rodeo transmission noise
  195. Red transmission oil, Manual 5spd MUA ?
  196. Transfer Case threads stripped '05
  197. Engine help
  198. coolant temp.sensor location. 94 V6
  199. Stuck in 4WD
  200. looking for a crankshaft, 99 Rodeo
  201. electrical issues
  202. Gas gauge not working, go here for the fix!!!
  203. 97 Rodeo won't idle when hot
  204. check engine light
  205. Help
  206. Differential changing
  207. engine warms at idle...cools at speed.
  208. 98 Rodeo DLC location?
  209. recomend any sites?
  210. Need advice on valve cover/head gaskets-96 Rodeo
  211. Spare Oem Computer/ecm/ecu Brain???
  212. '95 Isuzu Rodeo Hood Problems
  213. 4WD won't engage, 99 Rodeo LS
  214. 2003 Isuzu Rodeo engine miss
  215. Brakes on Rodeo, 97
  216. What is the gear ratio
  217. Dash Light
  218. alternator
  219. CEL, Rough Running, Help!
  220. Help needed with a specific CEL code...
  221. Dummy lights stay on too long - 95 Rodeo
  222. sticking throttle cable
  223. CEL light and Fuel Gauge.
  224. 94 rodeo black smoke and shuddering problem
  225. Fan clutch adjustment.
  226. Thank you Amigo2
  227. Up Shift Light
  228. potential tranny problems?
  229. 2000 Rodeo Isuzu 4WD Front end
  230. Ticking or pinging??
  231. Place your vote:
  232. P1340 please...Kids vacation at risk
  233. intermitten wipers?
  234. Error code P0171/system too lean????
  235. Whining/whistling from under the hood: belt, pulley or timing tensioner
  236. 1998 Front Bumper.
  237. Muffler for '99
  238. 98 Izusu Instrument Lights are Out, HELP!
  239. Power windows stopped working
  240. Help My 01 Rodeo Is Falling Apart
  241. '99 Rodeo instrument lights
  242. 95 rodeo
  243. Help with whine noise
  244. Timing Belt Replacement...
  245. 96 Rodeo 3.2L V6 - Engine Picture
  246. Need a pair of grey cloth +98 headrests
  247. ABS Light
  248. can't remove the wire connector from headlight
  249. Oxygen Sensors
  250. Rear hatch Lock
