View Full Version : 1st Gen 95-99
- Cooling Fan Problem
- NO Crank problem
- Hood from a sohc fit a dohc?
- A/c Problems 1997 Dodge Neon
- 1996 Neon Electrical Problem?????
- 1995 Neon 2.0 SOHC mild mods with problems
- Cooling Problems. Really need help on this one.
- 95' Plymouth Neon Gauge Cluster
- cylinder head bolt torque?
- 98 Neon Air Conditioning Recharge...help.
- oil in spark plug tubes
- 2 things to look out for on your neon.
- Wippers stuck in Up postion
- 1997 Neon Water Pump
- 96 neon keeps dying on me!
- 95 Dodge Neon Concerns
- replacement fuel pump
- Turn signal problem
- what size injectors to use
- Factory Roof Rack
- 98 neon/sohc died wont start
- CODE 11 SOLVED (in this case)
- 98 neon shifting and shaking ?
- stock tire sizes
- neon turbo parts
- 99 Neon wont start
- replace 95 sohc with 03 sohc?
- oil all over 4 spark plugs
- 98 dodge neon valve cover spark plug seals
- Help with 98 Neon
- Bet you can't answer me this.
- 95 Neon Fuel Pump Fuse
- Power steering pump problems in 99 neon
- guages don't work
- 95 neon valve help plzzzzzzz
- Need Help with my 96 noen
- Idle problem
- Weird electrical issues
- Sagging driver's door
- overheating, code 35-cant find fan relay 1996
- Stupid alternator! We need help
- Need help regarding Rough Idle
- Key won't even turn!!!
- Need advice on 1996 Neon
- more electrical confusion
- 96 2.0l Sohc Pushing Out Oil Seals
- replaced alternator, still problems!! Help Anyone?
- it wont turn over
- 98 neon shaky idle
- neon....buy it or not??
- What is the best way to remove the Alternator
- not starting again.. bleh
- Heater not working
- WTB Crankshaft position sensor pigtail
- $300 neon
- FS: 98 r/t with full srt swap engine and interior
- 95 neon rear vibration/wobble?
- neon coilpack check?
- Bet You Can't Solve This Riddle, Neon Stalling w/ Check Oil Lite-On
- srt4 swap 96 neon
- strange problem possibly with 96 neon sohc.
- FOR SALE - First Gen Neon Aftermarket Muffler
- WTB: Rear Disk Brake Set-up for 1995-2002 Neon
- HUGE oil leak
- Oil Leak
- exhaust
- help changing belts
- head gasket replacment
- Shaking/Squeaking
- just bought 99 neon r/t wanna turbo
- 95 neon hard starting
- 97 Sport With problems
- srt-4 gauges
- mugen style front lip
- '97 DOHC won't idle
- Odd noise when warm from engine
- Upgrades :)
- Weird gas guage
- can i re-use short block after timing belt snap?
- 96 Neon a couple probs
- 1st Gen Neon - 2ed Gen Eclips
- 1st Gen Aftermarketpart Sites?
- 96 Neon SOHC help
- Leak from the hood release lever
- 98 Neon Horn location ??
- new raditor
- 98 Neon Trans Prob
- Camshaft Position Sensor???
- What's up with my baby?
- motor swap
- 1997 neon 2dr Stalling abruptly. Starts immediately after key off.
- 95 neon brake lights are not working
- 1999 Plymouth Neon #3 injector flooding cyl
- engine/tranny problem
- Neon in need
- Gauges not working?
- 96 Neon trouble codes and power problem.
- Misfire, Can't find cause.
- 99 neon suspension
- Is this right?
- Spark plug tube seals
- Headlamps fluttter on and off
- 98 starter install
- the hood
- someone help
- Save My Neon!!
- 97 highline gas gauge
- srt4
- 98 Neon
- i need major help with my 1998 neon expresso
- cooling problems
- What should I aim for?
- 97 skyline wanna hook it up
- car won't start
- 1997 Neon trouble code P0743???
- 98 ATX Shifter shaft keep freezing
- 96 Neon parking lights/console lights not working
- Hot Rod Neon Q's
- wiper..broken, not multifunction switch
- 1995 Neon Engine Noises
- 98 neon overheated, won't start
- Engine Swap
- Transmission Trouble??? HELP!!!
- Airbags
- 1997 Neon power problem
- Fuel Pump Problem??? 1997 neon
- what to do?
- 1995 Neon Help Please
- Newbie with a problem!!
- ac/belt help please
- 98 Neon-- No power
- 1996 Neon Want to make it posi. ???
- 98 neon HLP
- 98 dohc timing belt sounds like wood chipper
- Shaking steering wheel problem
- megasquirt
- srt-4 swap
- Exhaust work need some Assistance
- major help soon
- Borla exhaust?
- 18mpg?
- Help with O2 Sensor
- 96 neon running really rough
- new here please help 96 SOHC dies
- Timing
- Battery Relocation question
- 95 Neon Performance Mods?
- 95 Neon Block 4g63?
- head throttle body upgrade???
- Obx Lsd Issues Help!
- inconsistent overheating...puzzling problem
- 1999 plymouth neon clutch release cable
- 97 dodge neon wont start
- 95 transmission
- Hit brake, turn signal lights up???
- Help
- 99 Neon Overheated ... now won't start
- im having some engine problems
- Lots of parts..turbo kit..wings west kit..misc parts for sale
- 97 neon will not start, neeed help asap
- AC clicking..?
- Won't start
- 98 neon
- Moving Sale - 1st gen parts
- S.O.S. Help With Neon
- speed limiter
- got hit while parked
- 96 Neon Help!
- problems with my neon....
- Is This Right
- Speedometer with a mind of its own
- 99 neon tranny problems
- 98 Neon 2.0 SOHC
- need help
- help! air conditioning..
- AC condensor..
- falls out of gear
- 95 Neon wont start HELP!!!!!!!!!
- clutch = hydraulic?
- oil leak on 99 dodge neon 2.0 dohc
- gas mileage?
- body parts interchangable?
- 96 Dodge Neon Speedo not working
- NoFireNeon(code43)
- 1998 plymouth neon problems neeed advice asap!
- hey all neon fellows..
- head gasket replacement cost?
- Neon 96 with three codes...
- Improvements to my 96' Neon
- 98 Radiator size question - Mexico / USA
- '99 DOHC to '98 SOHC
- spark plug wires
- News on Turbonator
- Exhaust
- Help with 98 neon starting problem
- gear oil for 98 neon 5 speed
- Door Ajar Light?
- Weak E-Brake?
- 98' Neon Door Panel Removal?
- turn signal lever
- Transmission bands ?
- Battery compartment sensor ?
- pcv valve installation
- Temperature Gauge
- Fuel Pump fuse keeps blowing. Is it a short or the fuel pump?
- my car won't start why?
- Guages
- parting out 95 dodge neon sport sohc
- Air Conditioning??
- 1995 Plymouth Neon Turns Over, But Won't Start
- how much you think i can get
- check engine light not working
- Neon Problems Dont Know What Else To Fix??!!help!!
- After market gauge hook up?
- Electrical problem or mechanical problem?
- 96 plymouth neon wit upgrades for sale
- 1995 Dodge Neon ACR Part Out!!!!
- 99 Neon Camshaft Seal Popped Out-Major Oil Leak
- 96 2.0 no Start
- engine swap 2.0 dohc to a 3.0 dohc?
- WTB '96 Neon Engine
- Fuel pump
- Problems with 98 Neon
- After market engine question
- is this intake worth it
- 1998 plymouth neon expresso engine specs
- 1995 SOHC Automatic transmission issue
- Engine Shake, any ideas?
- Motor mounts!
- Lend Me some help plz!!!
- shock or cushion like spring that conects on the underside of the back I NEED HELP?
- Cant get it in . . .
- Fuel Pump Replacement - easy job? Newbie
- Engine Swap-98auto to a 95 manual?
- RadiatorLeak/overheating
- 95 neon
- 95 Neon, No clutch peddle
- juss got a question!
- 95 trans
- Wtb Neon
- egr blocked / bad gas mileage / 1997 dodge neon
- what is wrong?
- Water Pumps Rebuilt or Dealer?
- capable power
- Gas in Oil Help
- Are Coolant Bottles on 1st Gen interchangable?
- What's wrong with this car
- Can Bad Rotors Cause A Shimmy or Wobble?
- 2.0 to 2.4 swapable parts
- OBD II trouble code
