View Full Version : Jimmy
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12
  1. fueling problems
  2. '98 Jimmy 4WD.HELP PLEASE.Stuck Ball joint
  3. 97 Blinkers.
  4. Air conditioner freon leak - help
  5. For better results...
  6. Temperature gauge
  7. 1996 Jimmy - How to remove the trailer hitch?
  8. looking at jimmy as daily driver need advice
  9. 96 jimmy front bumper
  10. 2001 Jimmy relay for the secondary air injection pump
  11. Need help with 99 jimmy powertrain control module
  12. 1992 need help removing the ECM
  13. Jimmy Idles fine, but when driving...
  14. 91 jimmy bumper and grille
  15. 96 Jimmy Braking problems. Please help.
  16. Service Engine Soon codes
  17. Going to replace plugs
  18. lift kit
  19. 98 Jimmy not starting
  20. 94 GMC Jimmy 4x4 4.3L(W)CPI Vortec---surging, no start, and wont shift
  21. 94 GMC Jimmy 4x4 4LO works but not 4HI...
  22. my 2.8 Sucks
  23. 1998 Jimmy radio flashing
  24. trip keeps reseting
  25. 2000 Jimmy door panel removal/speaker replacement
  26. 97 jimmy relay sitch
  27. 4X4 trouble...I love this site!!!!
  28. Tires Tires Tires
  29. ECM on a 1996 jimmy
  30. help with a 92 gmc jimmy
  31. Replacement Bumper End
  32. female stuck in park
  33. Programming new remote
  34. Side View Mirror Not responding...
  35. ABS problems on my 93 jimmy
  36. distributor out of wack 98 jimmy 4.3
  37. distributor out of wack
  38. 96 jimmy jumping against starter
  39. 84 jimmy 4wd 2.8 2bbl hesitation
  40. 84 jimmy 4wd fuel filter location
  41. Inexpensive mechanics/Co.
  42. Heater core
  43. stalling trouble
  44. Front bumper 1995 Jimmy
  45. fuel pump relay location ?
  46. 96 jimmy ses lite
  47. High/Low headlight mod
  48. 2000 Jimmy SLT, Sunroof electrical Problems
  49. 1999 Gmc Jimmy
  50. 89 s-15 jimmy door lock relay
  51. jimmy 94 hatch lock cylinder
  52. I have no knowledge about car mechanic - should I buy a Jimmy?
  53. Jimmy's average lifetime and other question...
  54. jimmy 1996 4wd
  55. rear wiper wiring issues
  56. 1994 stalling, this seems unique
  57. Jimmy whistle sound
  58. Lower the Jimmy?
  59. 97 Jimmy Oil Filter Location
  60. 95 gas tank vents (where to get)
  61. 1999 Gmc Jimmy Sls 2 Door Heat/engine Problem
  62. 2001 Jimmy a/c drain tube location
  63. Forum Rules! READ ME BEFORE POSTING!
  64. 95 Jimmy Motor Shot, Will a 94 4.3 vortec fit?
  65. 92 s15 4wd inop
  66. 95 Jimmy wont start plz help
  67. 93 GMC S15 jimmy or S10 blazer power windows
  68. P0440 - 96 Jimmy
  69. 90 GMC Jimmy Knocks
  70. 2000 Gmc Jimmy Quit And Won't Start
  71. Intermitten tranny.... Any suggestions?
  72. misfire problem
  73. Speedo inop
  74. Do it yourself questions.
  75. How to buy a better Jimmy ?
  76. 96 Jimmy hard to start
  77. odometer
  78. 4wd trouble / 97 jimmy 4.3
  79. Power Window Stopped Working
  80. An easy one for ya, old timers.. ;)
  81. 1993 Jimmy GMC PLEASE HELP!
  82. Climate control knob failure
  83. Shuttering through steering wheel
  84. Alarm system? (i am helpless)
  85. 96 to 2000 converson?!
  86. Gas Smell/Leak On Fill Up
  87. help finding check/purge valve on 99 jimmy
  88. 94 jimmy timing problem.
  89. SQUEEK SQUEEK SQUEEK argh!
  90. 94 Jimmy uncommon wiper problem
  91. '92 Jimmy windshield washer sprayer
  92. 1997 GMC Jimmy HELP!!
  93. 4X4 default problem
  94. 2001 GMC Jimmy Keyless entry problems...
  95. Low Idle
  96. Escort 15.5'' dual speed electric cooling fan
  97. headlights/ flicker
  98. 31" tires on '98 jimmy sle... how?
  99. 95 jimmy blows ecm fuse when I floor it
  100. 89 jimmy wiring problem
  101. trans fluid loss
  102. Over heating only at idle
  103. Fuel Gauge fluxuates alot .
  104. Vortech 4.3 knock with info.
  105. Help....cant drive at night! Headlights wont work
  106. Intermittent starting problems-2000 jimmy
  107. 93 Jimmy not downshifting to pass
  108. 98 door stop pins
  109. 1996 jimmy new PCM tranny won't shift now!
  110. 2001 Jimmy loud Noise Problem...
  111. could use some advise, 2001 gmc jimmy
  112. No a/c or heat
  113. Is there anyway to check the VCM-A
  114. 91 s15 jimmy sle
  115. 2000 jimmy wont start
  116. 91 Jimmy wont start
  117. Tranmission Problem...I think!
  118. Front knocking noise passanger side
  119. 92 Jimmy sputtering and hesitating...
  120. 98 Jimmy A/C on again off again
  121. Help 89 jimmy sunroof removel
  122. 91 Jimmy rear hatch broken
  123. 1996 Jimmy 4WD Problems
  124. oil on my bell housing 1990 s15 jimmy
  125. Transmission Trouble on a 1995 GMC Jimmy
  126. Keyless entry and alarm
  127. 1995 Jimmy 4.3 CPI no start-have fuel pressure
  128. 98 Jimmy rebuild project - help in removal!
  129. Distributor installation on 95 4.3???????????
  130. 01 ABS Light On
  131. 99 jimmy SLT reverse will not work?
  132. Fan clutch
  133. Tailgate Latch Control
  134. 97 Jimmy fuel pump pressure
  135. 4 wheel drive problem
  136. broken connection on a/c clutch???
  137. 1990 S15 jimmy is rattling underneath???????????
  138. Little info needed
  139. A/C compressor making growling noise
  140. 4.3 vortec transmision compatability
  141. 2000 Jimmy .Slt, Buttons Above Drivers Sunvisor ?
  142. bosch fuel pump and spare wires
  143. 1999 Jimmy HVAC Control Head and Gauge Lights acting up.
  144. Tips for putting the gas tank back into place on a 1993 Jimmy.
  145. are gear ratios diferent between 1991-1993?
  146. A/C - Heater Fan won't turn off 98 jimmy
  147. 1990 jimmy digital dash,temp reads 200+
  148. 90 S15 Jimmy New Starter Wont Disengage
  149. Brakes work but motor doesn't
  150. 97 Jimmy Driver Power Seat Not Working
  151. E-85 question
  152. Shocks
  153. 93 s15 jimmy 4wd and abs
  154. 2001 Jimmy 4WD Self-Engages
  155. powered driver seat in 95 Jimmy SLE not working
  156. 92 jimmy ignition module
  157. '95 Jimmy 4.3 CPI Vortec - I'm AT WITS END!
  158. Some Knocking Noise????
  159. electrical problem need help!
  160. 95 jimmy ignition switch?
  161. Swap to a ZQ8 steering box
  162. Noise
  163. '95 Jimmy 4.3 Vortec doing it again....
  164. 95 Jimmy SLE died while driving and now won't start
  165. need advice, and a little help from me friends!!
  166. Does This Estimate Sound Right To You?
  167. 94 Jimmy Hood issue?
  168. 97 Jimmy Fuel Delivery
  169. "Service 4WD"
  170. 2001 Jimmy Starter
  171. Few random questions...91 Jimmy
  172. '95 Jimmy 4X4 brake job - COMPLEATED!
  173. Blower motor breaks down in extreme cold?
  174. 95 jimmy fuseable link burns
  175. 94 Jimmy battery drain
  176. Sticky pedal
  177. Suggestions for fuel pump
  178. Wiring
  179. 1996 Jimmy won't start
  180. old vs new injector leaks
  181. Gas
  182. Fuel pressure details
  183. Best way to remove a "stuck" rear brake drum?
  184. Ignition
  185. Trouble with lights
  186. 1993 starting problems - and where is the darn fuel pump relay?
  187. 93 Jimmy 4.3 Vortec idle problem
  188. Corroded Transmission Dipstick
  189. Door Retainer Clips
  190. A heads up on No-Starting
  191. Where does everyone seem to be finding their 36mm Deep Sockets????
  192. Balljoints and torsion bar
  193. 93 jimmy 4.3 valve spacing
  194. Try it one more time...
  195. Wiper Motor stops and buzzes?
  196. 99 jimmy breaking
  197. ABS Code Reading
  198. 1993 Jimmy Transmission fluid change
  199. How the heck do you remove the #3 plug in a 4.3 Vortec?
  200. Seafoam?
  201. 91 S15 Jimmy Check Gages Light when stopping
  202. 01 Jimmy Lock Cylinder/Ignition
  203. Bad alternator or battery?
  204. Manual transfer case won't shift into 4hi
  205. Digital read on compass says OC
  206. Replace steering rag joint with urethane
  207. 1998 Jimmy runs -- then stalls
  208. Questions
  209. 2001 Jimmy - Code 0440
  210. anyone try to improve fuel economy?
  211. Engine misfire on one cyl
  212. Trailer wiring for a 94 s15 4x4
  213. 95 Jimmy 4.3 Vortec starting problems - weird
  214. Finally fixed; stalling when hot (long)
  215. ZR2 conversion 99 Jimmy (Lift kit)
  216. 4.3l power lost & Back Fire
  217. 4 Lo light stays on... Power window motor
  218. 95 Jimmy engine swap
  219. steering is out
  220. 95 battery drain
  221. bogging no power off idle
  222. 93 into 95 motor swap
  223. Gas smell
  224. where is it?
  225. 2000 Jimmy Shake/ Wobble
  226. 95 Fuel pump, etc...
  227. 98 GMC Jimmy power loss
  228. What gives these pigs better fuel economy?
  229. Ok, I got it ordered......now what.......
  230. Code explaination. OBD2 (Jimmy)
  231. 2000 Jimmy A/C and Blinker Problem
  232. Suspension woes -what gives?
  233. Tranny Fluid
  234. 85 700r4 transmission
  235. Gmc Jimmy-axle Swap
  236. Check Engine Light
  237. Fuel delivery issue
  238. Cheap Power Boost?
  239. jimmy tire sizes
  240. 4L60E Trans ?
  241. 96 Jimmy - ? fuel pump sound
  242. 96 Jimmy - smell coolant
  243. 96 Jimmy Hatch Problem
  244. Electrical/Start issue
  245. 95 Jimmy Low Batt = No Start - One for the experts
  246. 91 blazer parts on a 93 jimmy
  247. Few problems with 97 Jimmy (doors and interior lights)
  248. dtc code B2600
  249. headlight question
  250. 2000 Jimmy SLT Door Panel Question
