View Full Version : Windstar
- Preprogrammed PCM/ECM
- Engine Whistling and stalling
- Power Steering Problem
- Rough Idle upon starting after sitting for 20 Min
- Wheel speed sensor, how do i clean it?
- Transmission Cooler
- ABS and Brake light stay on & wont turn off
- 95 Windstar Electrical
- Can i burn it now?
- Ford Windstar 2000 not idling smoothly
- No rear heat in 99 windstar
- Speedometer Problems
- 2001 Windstar - intermittent no start
- Abs Fuse Location
- Does This Sound Like The Isolater Bolt Problem?
- Expected Mileage
- TSB 03-16-1 isolator 171 174 valve cover 3/16 hole lean egr check engine light CEL
- Power Steering Leak
- brakes chatter
- Speedometer stuck at 20-30
- 2000 windstar, ABS light just came on today.
- Companion Site
- Can brake fluid evaporate?
- Codes P1450, P0401, P0402, P0304
- 1995 Windstar Brake Rotors
- Any Ford Windstar Silent Recalls or Campaigns?
- 2001 Windstar
- 91 Windstar power window
- 98 Winstar no heat in ceiling vents
- draining battery (99 windstar)
- 1999 Ford Windstar Need Help
- 1995 Windstar Loud Buzzing from trans
- Bad smell from fresh air vent
- 2001 Windstar Heater Not Working :(
- #4 misfire and running rough
- 2001 power door
- Selling 1995 Windstar GL
- 99 Code issue P1633 HELP!
- 96 Windstar Head Gasket
- 2002 Engine Light On - Does this sound right
- intake
- 1995 3.8L Windstar Belt Diagram
- what year is 3.8 interchangable with?
- Rear Window washer
- car died when driving
- Isolator Bolts
- Interesting discussion
- do not know what light means 98 windstar
- 98 Windstar Fuel Gauge not working
- Tuneup for 98 Windstar 3.8L
- Idleing noise
- Steering noise
- 1996 Windstar Abc Goes On
- Rear Heater Stuck in Heat
- Running rich
- Spark plugs
- Check Engine Light On 1996 Windstar
- Abs Light
- windstar missfiring on 1st and 3rd cylinders
- Problems with 98 Windstar
- Replacing Head gaskets on Ford 3.8l engine
- 2000 Windstar - Transmission Fluid
- rear window defroster
- electrical weirdness on 95 windstar
- how to remove a 98 winstar 3.8 PS pump
- how do u remove steering pump?
- codes PO430 and PO732
- Codes 1537 1538 IMRC System
- Powertrain control module
- 98 Windstar - It's Dead !
- Firing order on 1999 3.6 Windstar
- 1999 Winstar stalling
- heater problems
- FS: 2001 SEL w/ vcr & towing pkg
- need help with an abs power relay code
- Emissions Control System warning Light
- 2000 SE paint problem and steering noise (m)
- Transmission Shift Solenoid C P1761
- 1999 - P0301 Code.
- WindStar 2000 LX 3.8 eng
- Power Steering Fluid?
- will 14 rims fit a 1999 windstar?
- Relay #6 Clicking Constantly
- 96 windstar won't start?
- Egr Ports
- Power Steering noise fix
- 1999 Intake Manifold Runner Stuck (Bank1) (Bank2)
- IMRC Testing on 98 Windstar
- Camshaft Positioning Sensor 1998 Windstar
- Need help programming 1996 Windstar LX
- Changing plugs on an '01 Windstar.
- SEL 2000 tran.and front end
- Air Bag light coming on.
- 95 Windstar 2nd Tranny in 17 months
- ABS problem
- Tire pressure (for 12Ounce)
- Transmission - rough downshift
- EGR flow insufficience (Windstar)
- '98 windstar front right clunking
- '98 Windstar stalling & running rough
- '98 Windstar > My problems.....
- Windstar hitch
- Code 0351
- 2002 Windstar Sport Key pad problem and back up sensor
- Battery Drain / Power consumption
- PO 430 Code Catalyst Efficiency
- 95 Windstar, window motor removal
- 1995 VW Golf
- 2000 Windstar SE Transmission Problem
- Tire Blowout
- 2000 Windstar - Radiator Fans Won't Shut Off
- Dropping the Oil Pan
- Windstar LX
- Clicking Noise on Left side?
- 2001 Windstar Transmission Problems
- ECT Sensor
- Cruise control stopped working!
- Stalling 98 windstar
- Power Seat sluggish
- 2001 Windstar SE Sport Transmission Problem
- turnsignal light won't shut off
- What the heck is wrong now!!!
- 98 windstar RPM issues
- dash warning light randomly blinking
- 199 Windstar getting code U1400
- Factory Installed AM/FM Radio Casette Player
- filters
- A/C condensor
- Engine Year
- Clearing Air Bag Codes
- Replacing 3.8L in a 95
- Po171/ Po174
- 95 shifting problems
- 95 noise in front end
- 95 Rear Quarter Windows
- ABS,light on and then off,cleaned senors.
- 96 3.8 blown headgasket?
- chime comes on with windshield washers and headligh
- Finally...the brakes are working!!!
- Fuel leaking onto exhaust manifold.
- checking problem codes
- Heater Blend Door Fix
- front wheels/brakes get hot
- 2000 Windstar - Screeching Noise
- snake oil for head gasket
- GRRRRR 171 & 174 AGAIN
- 171/174 codes
- Static on the radio Am
- replacing fuel pump (windstar)
- Ford 1998 - feel a Jerk when goes above 30 miles
- Brake master cylinder
- 99 Ford windstar power window and lock problems
- upside down picture on video entertainment system
- spare tire
- Electrial - Horn - Cruise
- oil
- Struts
- loss of transmission fluid mean no transmission?
- 2000 Windstar engine light and o/d flashing
- 99 windstar power steering leak
- 1995 3.8L problems
- Transmission problem- or not?
- p0743 - tranny code in 00 windstar
- 98 windstar - p1538 intake manifold runner control
- MAF sensor
- 98 windstar install power for dvd player
- 98 Windstar CEL problem
- 98 windstar
- What is common practice?
- Help! Turn signal gone berserk!
- No Oil Pressure
- K&N and Fram Air Hog air filters
- changing headlamps 95 Windstar
- Engine Miss 1996 3.8L
- auto repair shop dropped transmission
- Can't find the A/C check valve
- Remove armrest
- Loss of Fuel, Odometer, A/C, and Outside Temp
- Power Mirrors
- 1995 Windstar problems
- Trouble Code P1744
- 1998 Windstar 3.0 with PO171 & PO174
- 3.8 headbolt torque
- Transmission question
- Erratic Fuel Gauge, cannot find ground
- power window problem
- upgrade towing capacity on 2002 Windstar SE
- Reverse Sensor causing rear light issues
- 96 LX No instrument panel
- I need help please..
- Information Display in 2000 Windstar
- 2000 missing/3.8. Help replaced many things
- I think i have somesort of powersteering problem
- O2 Sensor - OBD code P0153
- Quarter Power windows
- 2000 Ford Windstar: Transmission failed at 80K/50M
- Intermittent Dash Lights + then no Start
- Lean Windstar
- 98 rear spark plug replacement
- Interior lights (beyond wd40)
- nybody
- 1996 windstar GL Alt. light stays on ?
- Oil in the Intake?
- 2000 Windstar power door lock solenoid
- 95 windstar transmission replacing
- engine torque specs 96 3.8
- Brakes squealing on 99 windstar
- clicking coming from rear hatch
- 99 power steering major problems
- Transmission sensor location
- 1996 Windstar Oil Pressure Light
- Flashing CEL! Help
- power window problems
- ingnition key problems
- ABS light on when hit 70 mph
- Fixed the rough idling/running but.......
- speedometer/transmission
- Cartrackers
- Windstar still stalling
- 99 tranny leaking
- 1998 Traction control light
- 95 3.8 windstar hesitates
- New alternator not charging
- Passenger side power window motor replacement? Help!!!
- 96'Windstar
- Brake light
- Trans identification
- 95 trans.....interchange???
- PO401 Code
- 2000 Windstart power door stuck open
- 98 Windstar missing on 2 cylinders
- Couple of things wrong with the piece...
- Laffy Taffy in air vent
- 1996 Ford Windstar Check Engine Light
- 98 Windstar P0171/174 runs poorly w/ warm
- noisy pedal & ABS light
- front clunk
- ABS Question
- need help with 2000 windstar visteon rear entertainment system problems
- need fan belt configuration diagram!
- 2001 windstar-many problems
- 2001 windstar remote starter
- 99 Windstar Speed warning chime
- 2001 Winstar - New Drum Brakes squeal
- p171 code and po305 99 winstar (HELP)
- No Parking light on Dash!! need help
- Oil Change Question
- 98' windstar not budging at all. ABS??
- bucking and jerking is back
