Mitsubishi
Eclipse/Talon/Laser
> Eclipse Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
hard starting, but eventually starts
differential kaboom
95 2g eclipse wont start
Oil in valve cover.
94 GS Down on power in every gear
92 Eagle Talon 2.0L ESi Automatic Transmission
turbo
No Spark To Plugs 91 Laser
water coming from the tailpipe
Need expert help on troubleshooting
Engine Stutters then dies.. what could it be?
Ping?
Torn Boot
Slowing me down.
Car won't start
97 2.0 Eclipse not starting
boost leak, ignition
now shes dead
wastegate problem?
AAAUUUGGGG!!!95 eclipse stalls or hits 0 @ various speeds....
car makes screeching noise
car stopped, won't start
Idle and lower rpm accel.
Clutch Friction Point
check engine light. water leak?
idle dropping at start.
Cranks but wont start!! Help!!!
Help Car Stalled and wont Restart
First problem with my DSM
dumb turbo question
problems starting.....stumble on accleration
Rough Idle/Missing
Oil pump question
91 Eclipse automatic trans
Only 2 cylinders running.
95 gst bad fuel/air mixture?
efi conrtol relay
differential locked
The clutch slipping after already driving in gear??
fuel pump relay
Talon stalls when slowing down
Electrical power stuff
first Dsm problem
dash light!
Bad Stock Turbo
it might be the alternator
99 Eclipse needs help starting
ugh!! camshaft positioning sensor or o2 sensor?!?!
I think I have a problem.
Shifting from 2nd to 3rd above 4500 RPMS quickly..
Question on my ECU
wont start HELP ME
Lowering kit wore out my tires!
auto tranny problem
Need Help ASAP (Pleaseeeeee)
Please Help.. Car Will Not Idle
My hks bov & check engine light
need starter help
power loss and gas in oil
Fuel Pump noise and suspension help
Having trouble finding repair site..
Need Help ASAP!
a few little problems and one biggie
oil pressure gauge addition trouble
FOR SALE- 95 talon esi
engine loses power
Another problem again
can a fuel filter make a noise? could be intake...
Anyone know where I can look up my check engine code?
On-Board Diagnostic Data Link Connector
turbo help PLEASE!!!
Weird engine noise HELP!
o shit did i blow it
'92 Eagle Talon Won't Start
Stereo problems
Blown,tranny,clutch,and engine
please help
No Spark, coil or ecu?
knock? heat soak? fouled plug?
Backfire problem
Sensors
coolant problem
Engine Dies After A Few Minutes
HELP PLEASE! clutch problem!
Possible electrical problem
92 Talon AWD Problem
95 eclipse rs has low idle and stalls.....help!!!
Brief power loss & brake jerk
Clutch pedal very easy to push
Eclipse p1494 code
AHHH Speeding Tickets...US Fines??
shitty idle cause? or a fix?
chnged valve cover and now wont start
eclipse lost power
Squeaking has changed...
rear light problems
please help won't start
Transmission Rebuild
mas or maf sensor bad ????
Help!!!!
ECU bypass question
ECU 92 Eagle Talon Tsi
Clicking noise
bad o2 sensor maybe?
rough idle...bad alt?
Major Problem!!!
new piston rings?
body problem
ticking sound when turning
pls help!!
99 RS won't start with key
95 gs-t
My Car Hates Belts!!!!
Low RPM Shuddering
Spyder Rear Windows...
fried something?
Talon goes Click-Click and Shuts off Abruptly? Plz help
timing belt help
91 Eclipse 2.0 idles funny then stalls after warmup
Location of idle air control valve
Seized Wastegate
95 Talon ABS and washer light on - how to disable?
misfire coilpack A code 0351
dead?
Problem with clutch
1998 Eclipse RS, ENGINE HELP
4 dash dummy lights come on for no reason, help me out here
Oil Pressure
oil pump?
Coolant
Exhaust Manifold Cover
RAdiator Tube
Brake Pads Completely Gone
Valve Cover Gasket
alternator trouble
Crank prob.....
Jerking
Being Stupid
Changing the top post terminal!!!
99 Eclipse Auto Tranny Gear Slips and Revs
Engine
Studder
Still noise from front
slave cylander problem...maybe
95 eclipse spewing oil
compression check.
P 1494 code
3 problems for the price of ONE!!
CrUnCh CrUnCh CRucnchhhhh
unpluged maf
auto lag!!!! what can i do?
ignition problem
Fun to Idle at 200 then Die? NOPE!!!!
cylinder head removal?
Turbo Timer!! Won"t work
Brake Rotor Removal?
Starter prob
help,help,help!!!!
sloooooow
Troubleshooting P0455
Overheating...
instrument panel lights always on.. and dim
Problem With Car ?????
Loud Strange Sound At 4000 Rpms
Oil in my air filter and car holds no oil
Misfire or Timing Problem
Back-Up Lights Switch Location
Will a tranny from a 95 fit a 98 eclipse?
Help Please!
93 Talon door ajar, dome light, etc.
O2 sensor wiring.
95 GSX Grinding...terrible
Idle jerks
95 Talon rpm fluctuations - stalling
Slow 95 Gsx
97 gst spyder spark plugs removed from distributor and have no clue which way to put
Insane Jerking around 4500-5000 Rpms
Weird sound coming from my wheels
Trusted DC-area Eclipse Mechanic?
How to enter stereo theft code?
95 Eclipse RS: T-Belt Problem? Engine Light on!
yep idle surge
1996 Eclipse-Oil capacity
Weird noise
Transmission Noise
dash warning indicator lights
Transmission - Next Step
1990 Plymouth laser
2g head on a 1g block.....help!
DSM Gearheads I NEED YOUR HELP!!!!!!!!!
95 Gsx
Clutch is heavily sliping need suggestions
no start
HELP Ignition problem, Car stalling.
seem like to be no fuel
ecu testing
A bad problem that needs a diagnosis
Won't Start
broke mas
95 RS hesitation below 3,000 rpm
what transmissions can b used on "90 eclipse
knocking sound on a 95 gsx
start up
loud grinding
Clutch Not Right
97 Eclipse with clutch pedal problems.
Please Help me I beg of yall
idles at extremely low rpms
cigarette lighter problem
loud knocking NEED HELP!!!
Popping in High RPMs
Boost leak???
90 GSX tranny problems
acceleration problem
Funny Noise
squealing
oil pressure
Elecrtic Problem
95 Gsx
changing out shifter cables
poor cold idle
Car Shaking
ISC question
ECU questions
Braking Problem
oil leak on valve cover.... somwhere...
engine cuts out
Transmission Problems
noise from back when braking
91 Plymoth Laser Automatic
Problem Starting 98 Eclipse
convertible leaking = pouring like crazy
brake light on
power steering hum
whistling noise
Bad Knock at around 5.6k rpm!!
4G63 motor rebuild URGENT!!!!
turn signal flashers spyder 2003
SRS Light On
Just Bought GS-T and need Help diagnosing
Need help identifying sending unit.
car getting loud at 4000rpm
One problem
changed water pump, now won't start
shift knob
Very bouncy/hard ride
Very bouncy/hard ride.
SPEED SENSOR & TCU MODULE BAD????1997 Rs
plymouth laser headlights
