View Full Version : Cavalier
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Rocker cover screws?
  2. Wheel Lugnut Torque?
  3. Parting out a 98 2 door lots of good stuff
  4. i just replaced my idler Assembly...
  5. dual exhuast
  6. fuel leak
  7. bigger engine swap?
  8. 91 z24 blowing fuse
  9. how much oil?
  10. 94RS Instrument Cluster config question?
  11. Gauge Cluster
  12. swap
  13. Coolant loss mystery
  14. Looking to buy a 5" tach, in ANY condition
  15. Removing and installing a door, 96 cav
  16. vss sensor
  17. I Need A New Engine
  18. Grocery list for a/c please
  19. difference
  20. need answers on on rebuilding 93 cav wheather to get a 3.1 or can i put a ecotec in
  21. Pics! Cavy made a friend, plus some updates
  22. Its finally running right after.......
  23. Hardtop convertible conversion?
  24. Pick n Pull in Central NY
  25. Cheapest yet good quality bodykit/fenders?
  26. Tune Up ? after winter
  27. 96 Cavalier DRL relay location. . . . .
  28. 94 fuel problem
  29. Need tcc-Torque Converter Lockup Silinoid Location-95 z24 3sp.
  30. Wanted to buy 98 cavy 2.4L motor
  31. 1989 z24 Cavalier--Son want's as Drive Car
  32. mobil 1 oil filter
  33. when should I change oil
  34. Getting new engine and turbo. 2.2 or 2.4?
  35. Doors, 2 Door Cav
  36. Cavalier Iceman Intake for sale ( NEW )
  37. Code P1137
  38. rad fan dosen't work
  39. problems with starting car 95 z24
  40. Is it so Expensive to install Fuel pump anf fuel filter to caavalier 2003
  41. rad fan
  42. Coolant Light On
  43. Vibration while driving, except when turning right.
  44. NEED T25 Turbo
  45. 1995 cavalier fuel filter
  46. How do you replace stud for lug nut on 2003 cavalier?
  47. Cavalier Z24's invited to New Hampshire Car Meet
  48. Miles
  49. Turbo On the Cav
  50. Wiring up 2 1 ohm subs in series or parallel
  51. 03 cav died, needs fuel pump. couple ?'s
  52. For Sale:2001 Chevy Cavalier 5-speed
  53. 94 Cav 2.2L problems
  54. Bang.. Wheel Allignment?
  55. 94RS instrument cluster?
  56. 2000 Calvalier Fusable Link To Cooling Fan
  57. Throttle Position Sensor TPS location???
  58. Pretty stupid question
  59. engine temp problem?
  60. 99 cavalier engine swap from a 2.2 to a 2.4
  61. 1994 Cavalier z24 Problems
  62. What do those indicator lights tell
  63. Sloooow Blinkers
  64. Easiest way to remove oil pump?
  65. I'm about to buy a '96 Cavalier, have any advice for me?
  66. For Sale
  67. Airbag Warning Light
  68. Misfire resolution if it just doesnt make sense for all dohc
  69. Vacuum Lines
  70. Replacing front struts on 01 sunfire
  71. '94 trouble, need suggestions
  72. Gapped plugs/Torque?
  73. 95 cav backfire 2.2L
  74. Front Strut Mount
  75. Flashing check engine light
  76. Do-It-Yourself
  77. Banging noise
  78. Dangers/precautions for supercharging 02 z24
  79. Cavalier For Sale (so i can buy another one lol)
  80. 93 gauge cluster
  81. 95 Cavalier spark plug wires
  82. engine swap 1995 Z24 cavalier
  83. Trouble filling up with gas
  84. ExtremeDimensions/CarbonCreations Shock wing
  85. idle speed is 600rpm...is this normal for automatic?
  86. Longer oil filter?
  87. 94 RS 2.2 floor board rust.
  88. motor mounts and brackets
  89. ? on replacing o ring
  90. Thermostat location on 1996 z24 cav
  91. Blower only works in 3rd and 4th positions
  92. FS: 2.2 Valve Cover
  93. FS: 1996-99 Cavalier Tail Lights!
  94. FS: 96-99 Cavalier Bomex Drift Body Kit
  95. Some Matrix projection headlights up for grabs, dirt cheap!
  96. steering wheel isnt straight after accident
  97. Think i should buy?
  98. windshield wiper fluid leak
  99. tire rubbing against front fender
  100. bent wheels
  101. cavayy club
  102. Regarding Radio On 97 Cavalier
  103. helpful stuff
  104. door is messed
  105. cavay fuel leak
  106. Turbo Write-up
  107. SELLING 92 Cavalier Parts!!!
  108. Toyota cavalier???? WTF
  109. electric turbo any good?
  110. ODB-ll not working????HELP PLEASE
  111. One more new toy from Eibach
  112. looking for a spoiler/rims
  113. 00 Cavalier Acceleration issue HELP!
  114. where is it ?
  115. Just installed my Mark Pain lower engine mount
  116. help
  117. traction control? Can you turn it OFF?
  118. Bushings and tranny question
  119. Is a used Cavalier a good buy?
  120. oil light and hard to turn
  121. aftermarket O2 sensor or simulator for the ecotec??????
  122. 97 2.4 dying on me...please help!!!
  123. `92-94 4-door cavvy for cheap, should i ?
  124. DRL-Day Time running Light lights keeps flashing..
  125. Oxygen sensor replacement-question please...
  126. Cavalier Reliability
  127. shop manual for 03??
  128. Changing Spark Plug Wires Need some help.
  129. hooking up my tach
  130. Blow off valve???
  131. smokes like hell
  132. 2000 Z-24 Battery Leak
  133. Thermostat?
  134. Head Light Switch Lever?
  135. Ractive air filter?
  136. Instrument cluster bulb?
  137. EGay to good to be true bodykit?
  138. How many weep holes on a '96 2.2L Water pump
  139. Short Shift BOOT
  140. Best spark plugs? Ngk, Greddy, Hks, Denso?
  141. how long?
  142. turbo a z24
  143. Headlights, Parking, Lights, Signal Lights???
  144. 97 cav hesitates when starting off
  145. ice cold radiator 96 2.2 cavalier
  146. Early 90s thermostat
  147. New here... but not a new problem...
  148. Car is squeaking...
  149. front speaker suggestions...
  150. Radio won't shut off when doors open.
  151. B&M install pics
  152. Projector/halo/any cool headlights for 00-02?
  153. door trim panel removal
  154. Thinking about sunroof what you all think?
  155. Engine Questions.
  156. Sunroof Issue
  157. defective guage cluster??? again HELP PLEASE
  158. clicking with air on???? HELP
  159. How to test fuel pump...
  160. Being the pic whore that I am.... here ya go!
  161. Shrieking A/C in 90'
  162. noise in front end of 97 cavalier
  163. 94 Remote Door Locks
  164. Where did you install aftermarket fog light switch?!?!?
  165. Hi Im new! 2003 cavy owners?
  166. 94 RS Roller Valves.
  167. cd player install?????
  168. newbie needs help
  169. 03-05 3 piece euro style tail light set...
  170. Pic Help Please
  171. Shifter...
  172. Resonator
  173. Anyway to improve acceleration for 96 automatic?
  174. Any updates/reviews for the Venom 400?
  175. little power??
  176. Timing belt or chain?
  177. Replaced Starter now the care dont Start
  178. 1997 Sunfire Non-Shifting Transmission
  179. 1999 key less remote
  180. Black tube
  181. Anyone with Carbon Fiber... Check this post... and some new CRJ updates!
  182. Shakes after 90?
  183. 93 Cavalier Bad Vibration -- Motor Mounts?
  184. 94 Cavalier - Replaced Head Gasket - Need Advice
  185. RkSport Type-J bodykit & 00 headlight conversion?
  186. Spit and Spudder
  187. Shifter Bushing Kit
  188. 4:2:1 OR 4:1 header ???
  189. Gauge Lights
  190. dual exhaust
  191. 94,95 cavalier 2.2
  192. timing belt replacement
  193. Tranny Fluid
  194. 97 Cavalier running hot??
  195. 2001 anti-theft light on hard to start
  196. 99 dim odometer
  197. 96 Cav, Ignition & Door locks
  198. Short Shifter question
  199. PRoblem with tranny?
  200. Spark Plugs
  201. idle surge
  202. Post pics of your Cavaliers
  203. temperature gauge goes up & down
  204. Clueless about cars, I'm sorry.
  205. Coolant Temp Sensor Location
  206. Component help
  207. change serpentine belt 2202 Cav Eco
  208. Chassis Number- Where to find it
  209. Lightweight Pulley
  210. Fuel Gauge Problem
  211. CarDomain.com
  212. 96 to 97 cavalier engine swap
  213. Rack & Pinion install/removal HELP please....
  214. Interior light on except when moving!
  215. 93 3.1L Stalls and won't start when warm.
  216. Coolant problem as always
  217. cavalier 2002 rpms go up
  218. Need some answers
  219. Clunking from rear, exhaust area?
  220. anyone!!!!!
  221. Engine Change
  222. Help! Coolant boiling...overheating
  223. Battery alternator power problems HELP!!
  224. Z24 Power Window
  225. Removing plastic peices in the rear seat area
  226. HELP!!!! 95 cavalier dies when I brake
  227. Heater Blower motor quitting...
  228. windows inside cav icing?
  229. help!!!!!
  230. 2003 Cavalier, remove the heat shield
  231. Intercooler without Turbo?
  232. engine swap
  233. Your opinion...?
  234. EGR Valve--whats make it tick?!!
  235. Need help with motor mount
  236. Windshield washer jug leak
  237. Windshieldwasher jug leak
  238. 94 cavalier RS trans filter.
  239. Hooking up a Tach to Measure RPM's
  240. about to buy a 2000
  241. Rough Idle When Sitting Still
  242. help
  243. For Sale : 2000 Cavalier Z24 BCM (Body Control Module)
  244. 04 Cavalier,Im changing the oil (not a filter question)
  245. 2003 Cavalier LS Sport Coupe (Road Noise)
  246. intermittent overheat
  247. Seafoam question
  248. Another pic of my car
  249. 95 CAVY, 2.2, STILL SKIPPINGl--HELP!!!!!!
  250. is there interest in custom angel eyes?
