View Full Version : Maintenance
Pages : 1 2 [3]
  1. Please Help Me
  2. Squeaky wipers......arrrrrrgh!!!
  3. Bucking engine
  4. HELP!!!!! Head Lamp Removal
  5. slipping fifth gear
  6. buzzing noise in the dash
  7. stupid G20 won't start
  8. Confused
  9. Grinding Noise at Cold Start - Bulletin
  10. anti lock brakes my @$$
  11. Radio Anntena
  12. willn't start
  13. Power Windows (Driver side)
  14. Dropping Resistor?
  15. Cruise Control kaboomo.
  16. ECU Location
  17. OK guys o2 sensor again!
  18. AHHHHH 6months old and check engine light???
  19. Radiator Fans
  20. earthing?
  21. Best sealant, anti-seize, etc to use on switch??
  22. Eureka!!!!!! O2 sensor...
  23. G20 Radio Antenna
  24. air conditioner
  25. burning smell
  26. when to change o2 sensor
  27. broken boot
  28. Reliable shop in San Diego?
  29. OBDI or OBDII?
  30. I need a motor mount
  31. Bosch O2 Sensor
  32. G20 Service Manual
  33. Oil Pressure
  34. P10 Oil Pressure Switch Upgrade Info - A must read!
  35. P10 G20 Sensor..
  36. G20 Dashboard lights not working
  37. Check Engine light - 1994 G20
  38. Stalling Primera
  39. EGR and Emergency Brake Light
  40. NGK Plugs.../rough idle
  41. A couple of problems with my P10
  42. Auto Tranny
  43. Anyone else getting 18 mpg? ('93)
  44. Ghost in the machine
  45. Hoowdee!
  46. input please
  47. Transmission Noise Woes
  48. 95/G20t LSD/Axle Rare Specimen/Help!
  49. Transmission Whistle/siren noise
  50. Noisy Axle...
  51. O2 sensor or not?
  52. Noise at start-up when cold???
  53. Tail Light removal.
  54. Headlight harness
  55. Help: Rear Brake Calipers
  56. m
  57. Changing Brake Pads
  58. Oil Switch Part # (for dummy light)
  59. OIL on Spark Plugs. Its that bad?
  60. Transmission swap
  61. 91 G20 Good Buy?
  62. Idles rough in reverse gear
  63. Lighting Harness For P10
  64. Intermittent power loss- HELP!
  65. Clutch woes...
  66. Transmission noise
  67. need a clutch,,,go to nissan or infiniti
  68. Emission System Warning light, help :(
  69. Service Engine lights up again!
  70. How much oil is needed?
  71. Oil???
  72. My gearstick is still limp! and hanging to the right
  73. High Idle Speed
  74. ZMax for G20?
  75. Low Idling, but no stall
  76. how to: take off brake light off rear deck
  77. Cap and Rotor
  78. SE-r the same ad G20
  79. Monkey brakes !
  80. Please Help!!
  81. Low Rev Problem
  82. slllloooowww start
  83. Reverse pop-out!?
  84. P10 having getting access to shifter...
  85. clutch woes
  86. tune-up
  87. G-20 reliability...
  88. Chamber
  89. Do "oil leak" additives work?
  90. High Idling & Stalling PROBLEM!!!
  91. 5th gear slippage...
  92. Bad steering problem!
  93. squeaky rear brakes
  94. front engine mount leaking.
  95. Repair Manual
  96. tire wear
  97. My G20 is dieing
  98. steering wheel during breaking
  99. Exhaust Installation
  100. squeeking brakes
  101. got the frekkin dash bug!
  102. poor mpg. what's wrong?
  103. brake pads
  104. clutch - how to?
  105. window problems in cold weather
  106. lighting replacement
  107. Poping noise during low speed braking...
  108. Where is the sunroof fuse?
  109. .
  110. Winter Tires Help
  111. Checking for melting wires....
  112. TBS's on instrument panel rattle? P11
  113. POS Car
  114. steering wheel shakes @ high speeds
  115. HELP! Interior Lighting...
  116. My Tach is Dying
  117. Swapping to DET
  118. Clutch does not grab quickly
  119. compter problem
  120. OBD Scan Tool and Oxygen Sensor Location
  121. Driveshaft replacement how to...
  122. Something in my dashboard....scaring me..:(
  123. stiff cluch
  124. Anti-lock brakes have mind of their own!!
  125. Knock Knock...
  126. Wheel stud is broken!
  127. Burning Oil...
  128. Anyone had this problem?
  129. no sulfer smell, better milage?!
  130. 60,000 Tune Up
  131. Another problem solved
  132. Running without fender liners?
  133. How to check ecu code on a 95 G20?
  134. Seatbelt light
  135. breaking in and gas mileage
  136. Reliablity over 100,000 miles?
  137. ok this is frikken weird :0
  138. Symptoms leading to starter failure
  139. ABS light
  140. Coolant and Transmision Fluid Question!
  141. Problems in reverse
  142. My gearsticks gone limp!
  143. RPM/ engine rev.
  144. Getting serviced in SoCal
  145. Oxygen Censors
  146. oil burned too fast?
  147. MAD electrical problems, all at once!
  148. Crackling noice in engine + ServiceEngine Soon came on
  149. Starter ...
  150. Air Temp Sensor
  151. Engine rattle/knock
  152. synthetic or regular oil?
  153. how HOT are they supposed to get?
  154. Anomaly of the week
  155. Stupid trunk
  156. vibration above 60mph
  157. It's to hot!
  158. cruise control fuse???
  159. steering wheel leather fading
  160. sunroof
  161. Weird problem
  162. dirty dirty upholstery
  163. worn out leather seats
  164. P10 Central Locking Problem
  165. Stalling p-10?
  166. leather seats
  167. 1st gear..........rough
  168. air conditonor
  169. Wipers Stopped
  170. GearBox Oil
  171. REPLACING OIL PAN GASKET...please help
  172. EngineService Soon lamp came on
  173. Coolant loss
  174. It happened!
  175. Minimum Octane
  176. Tach
  177. Simple Green
  178. armor all
  179. brake system bleed! how?
  180. G20 Scheduled Maintenance vs Dealer 'Check Up'
  181. Third Brake Light Replacement
  182. HOW TO: Converting your P10 G to 5 speed from auto Part 1
  183. Radiator flush/maintenance
  184. Power Antenna problems
  185. Recall list for 2000 G20 (includes:Infiniti Vehicle Squeak and Rattle Materials)
  186. steering wheel lock
  187. Stay tuned : I will be performing another auto to manual conversion within next 48 hr
  188. 95 G20 Headlight Bulbs
  189. OBD-I or OBD-II ??
  190. Rattling Instrument Panel P11
  191. For all of you who asked: Japan Motor Import
  192. Left headlight
  193. Had a little scare...now what???
  194. 99 g20t sunroof
  195. engine stall problem
  196. Brakes Squeaking
  197. ECU codes
  198. headlight washers
  199. disconnect ABS?
  200. drive cam
  201. Does dirty oil bring down mpg?
  202. torque wrenches...
  203. I Got A Question...........
  204. Hard Acceleration takes a lot of fuel
  205. Found a few mysteries in the trunk of my P10...
  206. How to get windshield wipers off?
  207. Gas Pedal 95 G20
  208. Trans. Making a squeel nd slipping!
  209. Sunroof leak
  210. Brake Dust
  211. How do i take the rear rotor off?
  212. Rattling from under the hood
  213. Brake Pad replacement Problems
  214. Fog Light Bulb s
  215. power antenna for p10? Cheap?
  216. funky noise
  217. EGR VALVE
  218. Rattling problem
  219. Squeek! HELP!
  220. What Clutch Should I get?
  221. Clutch cable
  222. Egine chek light is on.. T.T
  223. ABS light????
  224. Post back some answers !!!
  225. Time for a Clutch Change
  226. Sputtering
  227. To soft power stering
  228. Not Starting!!
  229. Fog lights pre-wiring: WTF?
  230. anoying sweaking noise --what is it?
  231. knocking noise at idle
  232. Frozen shifter!! Help!
  233. funky smell...
  234. Taking out the headlights
  235. My driver side window doesnt work anymore
  236. Fog Lights
  237. Service Department
  238. G20 Accessories
  239. higher than normal idle
  240. Oil Pressure gauge, possible problem?
  241. P10 front seat question, and possibly problem
  242. Car stalls
  243. anyone know how to get tether hook, part #?
  244. left lights keep blowing out
