View Full Version : SC/SL/SW
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14
  1. CLutch Problem
  2. Heater Hose Replacement Question
  3. door panel removal
  4. hey there i need an exhaust manifold for my turbo system
  5. 93 SL2 slight miss
  6. 2002 SC2 - Tensioner pulley - bolt size?
  7. 94 SL1 rear lights and dash lights issuse
  8. O2 Sensor Problem???
  9. 1994 SL1 transmission fluid leak
  10. i need an exhuast manifold
  11. 95 SL2 Brake problem
  12. 1999 Sc2 Saturn
  13. trying to turbo charge my 92 saturn sc
  14. Stalling!
  15. Transmission Issue/ Coincidence???
  16. Brakes on rear driver side making funny sounds
  17. 2000 SW2 alternator
  18. Thinking about buying a '97 SC2
  19. Engine Mechanical problem
  20. is a 1992 sl1 engine interchangable with a 1992 sl2 engine
  21. 2001 SL2 1.9 liter Fuel filter location
  22. 02 - SL-2 Automatic Dies in reverse down hills...
  23. 2002 SL2 No Power
  24. '00-'02 SOHC Intake Manifold Gasket Replacement How-to
  25. CEL on
  26. brake pads and rotors
  27. 98 sl2
  28. ABS light on
  29. NO Reverse!...94sc1 1.9l
  30. 1995 Saturn Sc....In dire need of help
  31. Windsheild Wiper problem
  32. 2001 SC1, how did i do?
  33. High Rev on idle
  34. engine knock/low compression
  35. No Spark out of Coil
  36. 1994 saturn front passenger side axles replace
  37. 2000 sl2 still having problem Please Help!
  38. need a little help
  39. 1995 saturn 5speed 1.9l
  40. 92 sl1 radiator change
  41. 1997 SW1 Fuel Pump Problem
  42. new starter. igniton wont crank .lights but no chime when key in ignition
  43. Timing Belt
  44. Transaxles on the passender side dissconnected
  45. 99 sl2 w/ slow tranny leak
  46. how much is too much?
  47. 2000 sl engine codes 0507(hi idle) and 0301(cyl 1 misfire)
  48. turn signal not working. help please!
  49. Wont start
  50. my 1995 saturn sc2 needs help!!
  51. 1994 saturn front passenger side axles po out of place
  52. 1997 SC2 moves in neutral - automatic transmission
  53. engine codes
  54. 1993 SC2 Speedometer
  55. 1995 SL2 having problems
  56. Strut Mount or Strut Assembly?
  57. Wobbly tire.........causing front brake problem
  58. brakes giving out.......lound squeeie/rubbing.....pedal all the way 2 the floor
  59. 98 SL2 idle/ stall problem???
  60. 1996 Saturn Won't turn over!! Help!!
  61. 99 SL1 automatic trans removal
  62. Brakes rubbing on rotor...WHY?
  63. 98sl2
  64. PPPPPPPPLLLLLLZZZZZZ help
  65. removing a head from a 99 sl2
  66. My 98 SL1 just won't go
  67. 1997 Saturn SL2 Tranny Issue!!
  68. 1994 saturn has starting problem only in cold?
  69. brakes rubbing on rotor is this common with saturn
  70. Can't get any heat????
  71. 96 sc2 wont start
  72. 1995 SL2 wheel choices???
  73. need tranny or car
  74. 1999 saturn sl1
  75. 95 SL1 Instrument Lights!! HELP!!
  76. Radiator
  77. Please helllllp 95 saturn
  78. in need of parts for 1994 saturn ls1
  79. 97 SC1 Repair???
  80. 1993 SL transmission fluid leaking problem
  81. Missing Sl2
  82. 1999 SL Code P 1623
  83. Where is fuel filter located on 1998 SL2?
  84. 99 Saturn SL1 washer fluid behaviour
  85. Just bought a 1998 Saturn SL2/Automatic
  86. Short? Coolant issues
  87. 99 Saturn SL1 washer
  88. 1997 SL2 - Won't Start Sometimes, Security Lock Out?
  89. 1998 saturn SL2 won't start unless the gas pedal is held in
  90. don't wanna do it
  91. 1993 SL2 5 speed manual trans-it pops out of 3rd gear often
  92. 97 sl2 wont start!!!
  93. fuel gauge problem
  94. 1994 Saturn Sedan jerk/punch when ever shifting
  95. 1999 Saturn SL2 Crankshaft Position Sensor Location
  96. There's gotta be a way
  97. car cigarette lighter socket
  98. Cant Remove Negative Battery Terminal Nut
  99. 2001 sl2
  100. Saturn SL code question
  101. 91-92 sc2/sl2 header on 99 sl2
  102. 96 SL1 Alarm Problem
  103. 92 Saturn - Inaccurate O2 Sensor Code
  104. 1998 saturn sl1 seat belt ????
  105. one dead cylinder
  106. new saturns
  107. Gas Mileage Decreasing
  108. hesitation in acceleration
  109. '97 SL2 won't crank, weird...
  110. cylinder 3 misfire
  111. misfiriing SL1
  112. ABS light and Brake light both on
  113. wierd idle problem after ECTS change
  114. 1998 saturn SL2 won't start
  115. 2001 SC2 Help!
  116. 1998 SL2 coolant problem
  117. Re: I am new and I love cars...
  118. Linkage / Transmission??? 94 SL
  119. Losing speed and power
  120. 1996 Saturn SL1 high temp low coolant light
  121. 2002 SL2 won't start
  122. 92 SL power issues
  123. Intake Question
  124. Spark Plugs Choices
  125. 2001 sc1 - would you buy it?
  126. 96 sl2 coolant light
  127. 1997 SL2 Manual transmission leak
  128. misfiring and can't hold an idle
  129. no reverse
  130. replace dohc with sohc
  131. 2001 SC2 Engine :(
  132. What would cause this type of vibration?
  133. 1999 sl saturn transimission leaking w/ high whinning sound
  134. 1999 Saturn SL2 Cranks but Won't Start
  135. gettin' rid of her
  136. 99 SL1 Base Pan
  137. Saturn 2002 SL2 No Start - No Electrical
  138. Lots of oil on 1 spark plug
  139. very high Fuel Consumption
  140. '99 SC2 Brakes
  141. replacing the head gasket tips
  142. Motor Swap (will it work?)
  143. 97 Saturn SC2/Ignition Problem.
  144. side mirrors
  145. 2001 saturn sl1 will not start when hot
  146. 94 SL Growling noise
  147. body panel repair/replace
  148. Ratteling when accelerating?
  149. 94 Saturn SL Idle probs
  150. 97 SC1 over heating
  151. Wipers don't work after new ignition install
  152. 95 SL2 Trans problem!
  153. Power Window problem
  154. weird noise when turning in reverse
  155. 1996 sl1 stalling
  156. Engine Interchange... hmm...
  157. Delayed Speedo Needle
  158. Alternator is fine battery isn’t charging.
  159. '98 SL1 starting problems
  160. 1998 saturn
  161. starting problem...????
  162. 94 SL2 Radio error 01
  163. 97 SL2 Front Door Speaker Grill
  164. Sounds like spark knock then stops!
  165. How do the headlight assem come apart?
  166. Air through vents after A/C is turned off
  167. 99 Saturn SL-parkiing brake
  168. Saturn will stall when gas is released at high speeds.
  169. intermittent start 98 SL2
  170. Shifts slow
  171. 98 SL2 misfire - ignition module?
  172. exhaust flex section needs replacing\ 93 sl 1
  173. 1998 Saturn SL2 P0706 P0731 codes
  174. goofy shifting
  175. 2002 Saturn SL Reverse Lights not working
  176. burning oil
  177. 1992 SL2 intermittent running funny.
  178. help:new tranny in 1995 saturn sc2.
  179. mini me swap
  180. auto tranny issues(long bt detailed post)
  181. 95 Saturn SC2
  182. Worn coil packs, running rich.
  183. fumes!!!
  184. axles
  185. 97 saturn misfire in #1
  186. Smoking
  187. 97 SC2 hesitation shifting/accelerating
  188. 2000 SL tail light/back up light problem
  189. vibration at speed
  190. Possibly gettin rid of the ol' wagon....
  191. Possibly gettin rid of the ol' wagon....
  192. door panel removal
  193. Question about replacing O2 sensor.
  194. Help!!! the car shakes in idle and going up hills
  195. engine oil capacity
  196. No Interior Lights
  197. Interference engines?
  198. Strange auto shift pattern?
  199. High RPMs, clutch problem?
  200. Cold Air Intake System
  201. Weird Problem at Startup...must rev engine '01 SC2
  202. SL1 Ignition Switch
  203. 1997 Saturn SC2 Speed Issues
  204. Question for Saturn Master Tech!!!!
  205. n00b's door won't open
  206. 93 Sohc Sl1 Idle Problems
  207. needs a 74 inch serpentine belt
  208. water pump
  209. Saturn sl2 automatic transmission first gear only
  210. Starter for 99 Saturn SW1 wagon
  211. No Back Up Lights
  212. Question about rebuilding an engine...
  213. Do Eibach Springs give you better handling?
  214. shift knob removal
  215. Major Starting Problems, Please Help!!
  216. '94 Saturn SL2-Lost Keys
  217. Considering buying a used (cheap) S-series Saturn
  218. SL2 Tranny Problem PLEASE HELP
  219. engine missing when hot?
  220. swap problems been down for over a month now!!!!!
  221. Advance Auto Parts OBDII Codes
  222. Dash Break Light coming on
  223. 2001 SL1 Security Light Problems
  224. Wont Start
  225. HELP!Crazy stuff happening with 1997 SL2
  226. Cooling fan won't turn on - even with AC engaged
  227. need 94 sc2 interior parts
  228. 94 sl2 wont start
  229. Alternator help
  230. pcm
  231. sunroof frame rust
  232. 02 sl1 starts, then stalls
  233. *instrument Panel*
  234. Radiator and condenser
  235. SL1 radiator replacement
  236. SES light still
  237. modding a 94 sc 2
  238. 2001 Saturn SL1 Fan Motor
  239. AC repair advice
  240. 95 SC2 power loss with steering wheel rattle
  241. Keyless remote not working
  242. radio doesnt work
  243. 2002 SL2 Exhaust Hangers ?
  244. engine and trans swap
  245. Serious wiring problems [1992 SL2]
  246. PLEASE HELP 94 sc1 wont go into 1st gear
  247. 92 SOHC heads into 95 SOHC
  248. 95 SC2 Anti-Lock brakes Help
  249. 92 Sohc A/t Into 94 Dohc A/t
  250. 92 SL2 DOHC Lots of problems
