View Full Version : Grand Prix
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. stocked GTP
  2. piston slap question
  3. 2004 GP: AC intermitant won't turn off
  4. Front Struts '98 GP
  5. problems with cig lighter,fog lights, and horn
  6. 100,000 Miles on 98GT - Any Preventive Maintenance Reccs?
  7. lost my hvac level control 97 3.8
  8. 3800 Series 3 Supercharging Question
  9. Power not transferring from engine to wheels
  10. daytime running lights on 2002gt
  11. 93 Grand Prix Keyless remote programing
  12. Engine Service light On
  13. 97 gt 3.8 radiator drain plug (plastic?)
  14. Cannot shift into Park
  15. 99 Gran Prix 3100 series electrical problems
  16. Heater not hot enough
  17. windows
  18. 97 GTP supercharger rattle?
  19. Car looses power when going uphill
  20. Low Coolant Indicator
  21. $300 intercooler core from ZZP
  22. 91 Gtp
  23. Door Lock
  24. Mass Air Flow Sensor ?
  25. fuel question
  26. 93 grand prix se antenna hook up
  27. Fuel problem... HELP
  28. 2000 GTP Coolant Leak
  29. new heater core
  30. 99 GP ringing like an old phone
  31. Trans Trouble Codes on 2000 Grand Prix SE
  32. 07 Grand prix
  33. 97 grand prix gt cooling system related problems
  34. 99 Grand prix GT problems
  35. Strange whizzing noise 97GT
  36. car seems slower?
  37. Changing SC Pulley
  38. 98 Grand Prix Windshield Problems
  39. stumped and out $115
  40. half boost... supercharger problem...power loss
  41. Code P0141 and P0137
  42. 2000 Grand Prix Intake Gasket Replacement
  43. Fog light bulb part #
  44. Getting a P0302 DTC
  45. need wiring diagrams for DIC (97 gt)
  46. Help - Thin walled socket needed for door panel removal
  47. 1997 gp throttle body
  48. 97 Grand Prix SE - Rear Wheel Bearing Removal
  49. Dual Climate Control
  50. Transmission problems?
  51. 2000 GT Subwoofers?
  52. 1998 Pontiac GTP Various questions
  53. Heater Hoses
  54. Vibrations. Feels unsafe,
  55. 03 Gt red dash brake light is on???
  56. Low coolant light
  57. Seat belt light
  58. Rocker arm installation?
  59. 1997 GT gp
  60. headlight assembly issue
  61. Coolant elbow replacement (where's the little one?)
  62. kinda lost....
  63. Future Mods
  64. DIC (Driver Information Center) Out
  65. 93 GP steering wheel removal w/stereo controls
  66. 94 grand prix se stereo problems
  67. Wheel Stud Removal
  68. led dash lights
  69. 1999 Grand Prix GT
  70. which do you all prefer????
  71. Replacing uim and lim gaskets (coolant Elbows?)
  72. Driver door lights
  73. '99 gtp hud problem
  74. 2001 grand prix ABS/Trac light
  75. lost 4th gear
  76. Diagnosing my car issues(Grand Prix GT 2000)
  77. Part ID! 1994 Grand Prix
  78. turbo or Supercharged?
  79. 01 GTP Compass reset
  80. No heat! 01 GP SE
  81. it was good while it lasted...
  82. Noisy wipers
  83. Another Downpipe issue
  84. Speaker Help!!!!!
  85. Noise under hood
  86. whats the difference?
  87. Tranny Flush or Pan Drop?
  88. Help With EGR!!
  89. cowl seal and wet floor
  90. 2000 Grand Prix GT Changing Tranmission Filter and Oil
  91. Blower Motor
  92. 2001 grand prix flushing radiator
  93. 1997 belt tensioner for gp
  94. Low Coolant Sensor Fix
  95. Aluminum Intake manifold gaskets
  96. vibration in steering wheel
  97. leaky taillights
  98. air in brakes
  99. 97GP GT front seat removal
  100. keep blowing fuse 37 under the hood
  101. 2001 GT Miss under load
  102. 95 SE - Torque Conv?
  103. Anyone know anything about aftermarket decks?
  104. Shifting Question
  105. Installed aftermarket head unit....
  106. Wheel lug nut opinions???
  107. Radio removal '06
  108. AC and Heat
  109. Car wont go into drive!
  110. 2001 grand prix 3.8 n/s PCS solenoid
  111. '99 Grand Prix 3800 V6 Thumping feeling
  112. 93 grand prix hot engine stalls
  113. 2000 Grand Prix front steering problem????
  114. 1997 GTP AC problem
  115. 91 grand prix gtp
  116. 99 GP with odd front end noise
  117. Disappearing Coolant?
  118. Suspect Bad CPS and/or Bad Pulley
  119. 00 Grand Prix GT Bad Miss
  120. 97 pontiac gp front driver side window
  121. Vacuum leak trouble?
  122. Re: 99 Grand Prix - no voltage-
  123. SRS airbag Light
  124. 2006 GP - Speedometer, Tach, Fuel & Temp max out
  125. 98 GP Headlight issue
  126. 2002 SE Starting Issue
  127. will a replaced air bag deploy?
  128. starting issues
  129. 99 pontiac gtp with heat issues
  130. overdrive Transmission
  131. Strut Tower Braces
  132. More Mods or have I reached my limit
  133. Headlights wont turn off!
  134. Help with Transmission
  135. Possible out of Gas
  136. 2000 Grand Prix GTP Black smoke, rough idle and dies
  137. 2004 gtp front end growling noise
  138. 2001 pontiac grand prix gt 3.8 losing oil
  139. 06 Grand Prix... Low Oil level light & Keyless Entry
  140. Concerns about replacing the Factory radio
  141. Big Vibration Blower Motor
  142. !!!!attention All Grand Prix Mechanics And Owners!!!!!
  143. irregular idle..zzp downpipe..help??
  144. '01 Grand Prix Transmission problem
  145. Custom Grilles
  146. Intermittent Radio - Back Speakers
  147. PCM's
  148. A/C not turning on
  149. Day time running lights don't work
  150. Speaker Help
  151. how do you remove the driver airbag?
  152. Alternative's to K&N filter?
  153. Key/Ignition Problem-Intermittant No Start
  154. Lock set Installation
  155. 97 gtp PCM
  156. Smaller Pulley
  157. my gas gauge wont work
  158. Changing Spark Plugs on a 97 GP
  159. Blower Motor
  160. 99 Grand Prix - no voltage
  161. 2004 grand prix blower speeds
  162. 1995 Grand Prix with 3100 trans ?
  163. 98' Grand prix Uprated alternator
  164. 05 grand prix
  165. LIM leaking
  166. 1999 GTP - Rear Main
  167. Front Valve Cover Removal?
  168. Power steering pump replacement
  169. 94 Pontiac Grand Prix Gtp Keyless Entry And Tail Light Problems
  170. 99 GTP - Starting Problem
  171. Brake lights not working
  172. Major Pontiac Grand Prix GT issues-help!
  173. Trouble Codes
  174. 1995 grand prix. problem starting.
  175. Alignment Question
  176. P0401 problem
  177. cooling fans...more problems...great
  178. blower motor?
  179. 99 - Grand prix Starting probelms
  180. side trim
  181. does this make sense
  182. Transmission ?
  183. Possible Gas Problem?
  184. Aftermarket Deck Question
  185. 97 Grand prix leaks water after rain in passenger side floorboard
  186. Help With Error Codes
  187. Bulbs for headlights 97 Grand Prix GT
  188. lower control arm/a frame
  189. Cuttin out!
  190. Air conditioning pump
  191. 99 GTP Blower Motor No Speeds ATC
  192. 98 grand prix gtp rear tail light
  193. Boost
  194. 2000 Gp Gt Dtc
  195. Fuel Filter SEIZED i think
  196. Code Reading Tool
  197. check engine light. code P0171
  198. Check Engine Light?
  199. grand prix gt fuel line heat shield?
  200. Question regarding car tools
  201. Check engine soon lite?
  202. Help please
  203. ABS & Trac lights come on sometimes
  204. Volts Gauge?
  205. Putting a new Radio in My 03 GP GT
  206. Exhaust connection bolt size
  207. low coolant?
  208. Ecm?
  209. problems with my 01 GP after long driving
  210. Case Learn with Aeroforce Interceptor Gauge
  211. Pulley Question!
  212. '04 Grand Prix - Grinding noise when turning & braking
  213. 97 Gp Gt 3800
  214. Agggghhhhh
  215. Aftermarket Pcm
  216. 2000 Grand Prix shakes from 10-25mph
  217. diagram of vacuum lines 97 gp
  218. subframe bolt broke...?
  219. ABS and TRAC lights illuminated GP 98 GT
  220. 1991 dies afer replacing battery
  221. p1137? air fuel metering what does it mean?
  222. Car takes forever to warm up
  223. changing fuel filter
  224. 2002 GP SE Electrical problem?
  225. cranks and nothing
  226. Where's the fuel filter???
  227. Why is it reving up?!?!?
  228. Aftermarket PCM
  229. 2001 grand prix flushing
  230. 1991 grand prix gtp rad question
  231. Strange Radiator leak
  232. 05 starts then dies,press gas and it runs
  233. Transmission slipping at 25-30mph
  234. Crankshaft Position - Variation Learn Procedure
  235. Lost keyless entry remote...car is locked
  236. shifter question
  237. Struts
  238. transmission flush/fill
  239. Scan Tool Guage Mod Idea
  240. Boost Gauge Install
  241. rear speaker wiring
  242. Serpentine Belt and Pulleys
  243. few performance questions...
  244. VATS keys
  245. 1994 gtp wont start
  246. Possible Fuel Pump Problem
  247. 1991 Grand Prix running problem
  248. Driver side door interior light...
  249. Need someone familiar with Magnuson Nose drive and pulley
  250. batteries for grand prix gtp's
