View Full Version : Eighty Eight
Pages :
1 2 3 4 5 6 [ 7]
8
- FYI - Sudden & Severe 92 Olds 88 Engine Oil Leak
- Ongoing mystery problem, anyone care to help?(long!)
- rear drum brake adjustment
- Drifting is teh fun
- 1992 88 stalls
- 1988 Olds 88 starting problems
- 93 olds 88
- Heater doesn't always blow warm air?
- Engine doesn't turn over, but there's power there?
- Starting Problems 4 fuel pumps
- hvac control panel doesn't work
- slow wiper speed
- Auto Trunk Release
- radio
- Coolant Level Low
- in need
- heat shield
- fuel filter on 92 eighty eight royale
- 350 bearing slap
- Pass code starter relay Q
- Did I blow a head gasket?
- OBD 1994 Olds 88
- 94 Olds Air
- 95 Eighty-Eight Won't Start
- Rear struts on my '97
- 1992 88 stalling
- Hissing sound when running
- Just bought 1997 Oldsmobile 88
- Olds 88 Royale electrical gremlins
- Delta 88 charging system problem
- 84 Delta 88 Fuel Filter Location
- blower fan in 1993
- AC Unit
- AC Blower just quit?
- 1987 Olds w/newer engine--stalls
- My 1998 88 LS has problems
- 97 Olds 88
- trany problems
- Problem Starting
- Just got teh Eighty Eight...some probs
- 1990 Delta 88 Royale Won't start
- Wheel Question.
- what a coincidence
- 92 Olds 88 Stalls - Fuel Pump?
- hood ornament
- MaxiFuse / Relay Panel (1997 88 LS)
- I'm lovin' it
- 93' 88 Royale Timing
- MasterCylinder Wiring
- a/C VACCUUM LOCATION OR DRAWING
- Short in the wiring?
- Hesitation and Check Engine light
- Help...massive oil leak!
- 95 Olds 88 Supercharger
- 94 88 strting problems
- location of chime module
- 94 Eighty Eight Hot Weather Stalling
- Parking Brake Light & Chime Always On
- Air Conditioning
- 1972 Delta 88 Royale Conv. Restoration
- New To 88's. I Very Badly Need Advice.
- Abs
- 1988 Olds 88
- What kind of people are you?
- Stalling 1991 Eighty-Eight
- 90' Eighty eight specs question
- 93 Olds 88 overdrive rumble / vibration solved
- delta 88 wont start when hot
- 1990 Olds 88 Questions
- Cause of fire in trunk
- catalytic converter mods/removal?
- This Dumb Power Drain
- For Sale 1984 delta 88 Royale
- Horn
- Code 41 cam sensor
- Air/heat blower fan wont shut off
- Check Oil
- Location of flasher on a 1993 Olds Eighty-Eight
- Royale Brougham 1989 Headlights
- Lucky me.
- 1985 Delta 88 Royale Largest Engine
- trouble with cooling system
- Catalytic converter, how long do they last?
- 92Olds88 A/C
- Lower Intake Manifold
- New trans or Fix old
- Stripped bolt
- Full Bench Seat
- How to lift my 1983 delta 88 to fit 22/23 inch rims?
- help i'm losing it.
- looking for '95 88 royale
- 86 Olds rough Idle and
- 93 olds 88 Ignition problems
- Intermittent AC (and heat) failure in '93 88
- 3.8 L engine link?
- '94 Delta 88 Oil Filter location
- fuel filter?
- olds delta 88 quad driver module circuit
- 97 Olds 88 - PLEASE Help!!!
- 88 Olds running problem
- Transmission oil leak...
- directional air flow for A/C 94 olds delta 88
- I lose Overdrive on long trips
- Rebuilt engine
- Car stalls while driving & idles rough
- ECM data link error prob 54
- engine light
- 1992 Royale 88 3.8 engine crankshaft sensor
- 93 Olds Eighty-Eight LS
- 86' Delta 88 Trans shifting problems
- FS: 1988 Delta Royale Br Coupe
- smoke comming out steering column
- What are my Compatible brake parts for a 1989 Delta 88?
- Compatible brake parts for a 1989 Delta 88
- 93 88 AC diode
- 86 delta 88
- cant pull up trouble codes
- Rpm's
- 93 olds 88 ac system
- wiring diagram
- Front Spindles Needed
- convertible
- MAT Sensor
- starting 94 olds 88 after rain
- Adding OEM Keyless Entry, to a 1992 Olds 88
- crappy start olds 88
- Horespower for 95' 88 LSS
- New 88
- Fan dont work in high position
- Finicky Start Problem >> Different Symptom
- '72 Olds 455 engine miss from 35 to 45 mph
- 95 LSS Radio controls on Steering wheel
- 93' Olds 88 bad ground?
- Cruise Control
- Light Problems
- Cold Weather Woes
- Door Speaker
- Black smoke '86 wagon 5.0L
- Help! 91' Olds 88 Royale Brougham - Breaks??
- 1994 Eighty Eight Intermittent Start Problem
- 1980 88 turn signals and flashers quit on me
- 1995 Olds '88 LSS Finicky starting
- buyin'an '82 88 Royal, what am i gettin into
- Spoiler for a 94 '88 Royale
- Car makes a loud grinding noise and won't pick up when it rains.
- 1994 lss ignition problems
- Delta 88 won't start
- Any of you had this problem?
- 89 eighty eight camshaft sensor probs
- Dual mufflers
- 1987 Delta 88 idle problem
- Just won't start !!
- Body Part Question
- newguy fixing up a '67 delta88
- '83 Olds Delta 88 transmission
- Pcm
- '88 delta VIN C - ignition control module
- Bad Day
- 89' Delta 88: When it rains, car runs badly...
- '93 olds 88 won't slow down
- New Headliner Needed
- 92 olds 88 stalling
- keyless entry BCM swap
- 1982 Olds '88 407-V8 wont start!
- ABS/traction control problem.
- 93 Delta 88 Royal with a washboard rumble in the Transmission.
- 3.8 to 3800 swap
- 98 hard to shift out of park in cold weather
- Factory Radio Problem
- Engine Problem, '95 88 LSS
- Camshaft position sensor/ magnet
- sepentine belt
- I've got a question..
- '94 Royale CV shaft vibration at Tranny
- Intermittent Starting Problem -1993 Olds
- 1999 Oldsmobile Eighty-Eight
- !!!!!!!!!Parts!!!!!!
- 99 oldsmobile 88 - defroster fan is intermittented and car stalls when going slow
- transmission in 99 88
- Tools for brakes...
- 3.8 head gasket
- 1987 ignition problem
- fuse box on a 92 olds 88 royale
- :: Problem, Any Help Appriciated ::
- 1992 Old 88 Royal Over Drive trouble
- Engine Block Heater
- Can not remove key from ignition
- Olds 88 royale won't start / car alarm
- 1990 olds royal 88 stalls & has short
- 89 olds delta 88 cam position magnet
- Hey Happy New Year! I'm new!
- Fuel Pump question
- 1995 olds 88 - dies anytime
- 1993 old 88 royale, can't get spark
- Performance Parts
- 90 Oldsmobile 88 royal starting problems
- Help with buying 1997 88LS
- 1987 Delta 88 Wiring Diagrams
- 97 olds 88 ck eng lt
- Sequential 3.8L V6 - Firing Order Not Working
- Trans problem
- Speed cluster not working
- intake manifold
- flasher
- master cylinder problem
- 1991 Royale has accelration and idle problems
- Lt1
- Heater works few minutes then stops. Display
- Roof Problems
- So is this insane
- p.o.s.
- just replaced tranny, still has problems getting into gear
- Need some help!
- Oil Problems
- '95 olds delta '88 engine leak
- Bodykit for 86' delta 88?
- Sunroof wiring?
- 1989 royale heater core?
- 1997 88 Royale Keyless Entry Programning
- 1990 Olds still missing
- 89 Oldsmobile Eighty Eight Royal Stalling
- Motor & Transmission Mounts?
- Strut Question?
- A/C Question?
- Newbie here, just would like to say Hello.
- 80 Olds driveability problem
- delta 88 horsepower
- my dads car
- check engine light comes on
- Engine performance modifcations?
- Stalling and jerking problems
- crankshaft sensor
- 1986 88 ignition problem
- tranny hesitating
- 86 oldsmobile Delta 88
- '90 eighty eight STALLING
- '83 rotor sizes and calipers ?
- 88 Royale Value
- Delta 88 Royale
- Stuck 88 door
- Any '89 Delta 88 Royale Sedan Drivers?
- 1996 Oldsmobile 88 Keyless Remote Programing
- cigarette lighter
- Ball Joints? / Air Condtioner
- 88 Hasn't been started in 8 months, how do I get her on the road again
- 1985 Delta 88 engine specs and Carburetor Question
- Delta 88
- 1994 Olds 88 specications?
- Loosing power
