View Full Version : Silhouette
- new engine, no start.
- Removing Entertainment/Climate facia?
- WANTED: hitch for my 03 Montana
- engine removal 93 3.8ltr/auto
- 95 silhouette sliding door
- Thumping Knocking Sound In Reverse
- 95 Keyless Programming HELP!
- Flushing radiator
- A few questions on the 03/04 Silhouette/Montana....
- Switched 12V
- ABS/Brakes/TSC Lights on
- 2000 silhouette
- Tail Light Assembly
- 2000 Glove Box Latch
- 3.4 L rough idle
- strange front end noise with low speed right turns
- Electrical Problems 2000 Silhouette
- the radio question help
- piston slap
- 95 Olds Silohuette EGR Valve
- 1996 pont. transsport
- Wrong Temprature Readings
- Bucking Silhouette
- 1999 olds 3.4 Van
- no start
- Screw Rod in oil filter fell out
- emissions codes
- 03 Cd jammed in cd player, won't come out.
- rear defroster not working
- 2002 Climate control problem
- Air shock problem...
- Mysterious Leak
- heated seats/side airbag
- Service Manual Suggestions?
- I Need Head ... Gasket But Hate Thought Of Doing It Myself
- Intake Gasket Repair Cost update
- inner tie rod removal
- 99 silhouette loose belt broken pulley
- interior woes
- Power Windows driver
- Transmission Maintenance
- 98 Silhouette Electrical Problems
- Resetting Service Engine Soon light....
- Miss
- 2000 Premiere Transmission
- Traction Control System (TCS) intermittently comes on in my '02 Silhouette
- siloetee, engine quits running
- cruse control problems
- Power side-mirror problem
- '98 power sliding door won't unlock
- 2001 Silhouette A/C Problem
- 2002 Silhouette electrical problems?
- 2000 Premiere Driver Side Window
- Service Engine Codes??
- coolant temp sensor
- 2000 silhouette won't start
- 98 Silo. with air bag lite on
- 98 Silhouette air shocks compressor problem
- '94 RPM's up & down
- how do you remove VCP from 00 silhouette?
- silhouette ELC
- 2002 Premiere - Rear vents?
- 95' silo, cost of new engine?
- Alternator replacement for 98 Olds Silhouette
- Multiplay CD not working
- 1998 Olds Silhouette Engines
- 1998 Silhouette rear air shocks problem
- 2001 radiator cooling fans
- Where is the GM trans Pressure Control Solenoid ?
- 2001 silhouette coolant disappears
- mounting floor console
- Wiper motor problem 2001 Sil
- How to Replace Alternator Ground Screw
- DVD Problems
- 98 Silhouette Won't Start
- 97 silhouette A/C question????
- 1998 Silo life expectancy
- Transmission removal
- Day time Running Lights
- BCM 2000 Olds Silhouette
- Terrible AC/Delco sidepost battery
- Replaced Rear Wheel Cylinders, now Brake Warning Light On!
- Olds Silhouette 1995 3.8 Litre Won't Start
- 02 Sillouette random alarm
- Help! ac compressor
- Alternator and Wiper linkage. 2000
- 92 Olds Speedometer pegged/Running ROUGH!
- Cold Air Intake?
- How to replace rear wiper motor
- silhouette value
- front wheel bearing
- 2001 Silhouette
- 2001 Silhouette - trailer hitch wiring
- 1994 Olds Silhouette low rpm engine knock ?
- Important: New and Old Members Please Read
- Oil pressure sensor location
- A/C Clutch making noise
- Belt Tensioner
- What's special about the engine in a 97 Venture?
- 2001 Sil - Passenger airbag sign
- Brake Lights not working
- 97' wiper problem.......?????
- Trans rebuild? 2000 Silhouette
- no fuel past fuel rail
- Air shock problem
- Intake manifold gasket...DIY?
- 99 Old Siluette Problem
- swaping the radiator from a 93 olds Silhouette to a 93 olds 88
- NEWB: Water temp gauge doesnt move !!!
- adding softened water battery
- window
- Wiring harness question
- '93 Silhouette AC, freon trouble
- 1998 Silhouette Check Engine Light
- 1999 Silhouette rear deck lid Wiring.
- best brand of head gasket kit
- Non-shifting Transmission Overdrive Issue
- Oil analysis results, not so good.
- 2002 Silhouette purchase
- Air dryer/ air suspension
- oil pressure light
- Heater Blows Cold Air
- Almost giving it away but I have had it, so long GM
- Breaking for spares (UK)
- Intake Manifold "goodwill warranty" Toronto Area
- Water pump
- Thanks Greg A
- BCM Body Control Module location 2001
- cooling fan switch
- 2003 Olds Silouette won't start
- Power Sliding Door Not Working (HELP)
- 1999 Olds 3.4 high temp
- Power Lock Drivers Side Rear Sliding Door
- 1999 Dash Lights
- 2000 Silhouette ABS Idiot Light
- 1993 sil chugs and dies
- 2004 gold pkg-wind noise, seat height, door/radio shut-off
- 2002 Steering
- Brakes/sudden slip
- Windshield Wipers
- sporadic grinding noise from front while turning right?
- 94 Silhouette 3.1 accelerates
- Cylinder Misfire
- 92 olds Silhoutte
- $4200 brakes! Please advise
- 1998 silhouette Heater core?
- codes
- 91 factory service manual
- Rear heating system
- 97 side pass. power door froze shut, now not working.
- how to program 2001 silhouette remote
- jerking when started and on low idle
- 99 Silhouette, van starts, runs rough, then dies
- 1998 Silouette ABS, TCS, Brake light, and Service Engine Light intermittent
- lower intake manifold
- Power Sliding door
- What years will interchange?
- Brake Lights
- Passenger side mirror
- P0753 1-2 Shift Solenoid
- DIY transmission fix
- 95 transmission
- (parking) BRAKE idiot light
- new to forum, quick ?
- 2002 Blower Motor
- Radio Code
- 1975 Omega heater core
- windshield wiper motor
- tourque converter
- Replacing CD Player, Keeping other OEM systems
- What is normal coolant loss?
- 2001 breaks
- surging and dying
- starter
- starter problem
- power door locks
- 98 Silhouette new gaskets, now knocking??
- Brakes
- 1999 Silhouette Drvr window tilts
- ashtray power in 2000 Silhouette
- Drive Belt Pulley Noise
- A/C Questions
- 99 Olds Silhouette code P1483
- Rear Heater controls
- Driver side floor wet
- Replacing Key Fobs
- high mount brake light
- Rear Air Suspension
- heated leather seats again
- replacing head gaskets 3.8 engine
- 2000 Silhouette Key Fob Reciever
- 1999 Transmission/Traction Control System
- Silhouette Transmission Whine
- 93 silhouette 3.8
- Lower Intake Manifold Leak
- 1992 transmission shifting problems
- coolant leak
- Broken cam. Engine Replacement Procedures?
- leather heated seats
- Suggestions on an aftermarket entertainment system
- smoking heater
- Outside Temp Gauge...
- Dash lights replacement
- coolant fans not turning very fast
- 2001 Silhouette VCR Audio
- keyless entry programm procedure for 93 cutlass seria
- not running
- 1994 ignition switch
- 2000 Silhouette Driver Window: Up not Down
- 94 silhouette
- updated head gasket for 3400 V6
- AC problem w/ 93 Silo
- The elusive J38197-2
- chrome peeling off wheels
- heater blower
- 98 silhouette doesnt run
- Coolant change/flush
- my 1995 keyless entry
- 2000 Olds shilouette trans hard shift
- 2001 Silhouette Trans. Problems
- 98 Silhouette dash light/running lights intermittent
- 98 just replace intake manifold gasket, now rough idle/stalling
- Rear wiper arm 2000 Silhouettte
- overhead moniters
- Rough Idle on 1998 Silhouette 3.4
- 1997 Olds Shilouette going crazy! HELP!
- ABS, Trac Off and service traction system lights on on 2003 silhouette
- Auto Transmission check engine light
- Fuse Boxs
- 93 Sil oil pressure
- 1998 Olds Silhouette 3.4 Bogging out
- 93 Sil stalling driving me nuts
- ABS Idiot light
- Keyless Entry Remote programming - 94-96 Silhouette?
- FREE Intake Gasket from dealer, BUT
- Silhouette (1999) battery replacement procedure
- 99 olds silohette chattering
- 93 sil please help no spark
- 2002 Slihouette Driver's Power Window
- 1999 3.4 V6 Rough Running?
- 1998 Olds Silhouette, brakes,TSC, and ABS
- How do I know? Intake gasket
- Help with my entertianment center
- Technical Service Bullitens
- replacing VCR with DVD
- fuse for dome light
- vcr remote
