View Full Version : Cherokee
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. belt chirping noise
  2. no power to A/C Compressor
  3. Information Needed 2005 Grand Cherokee Loredo
  4. 87 Cherokee Pioneer Stalls
  5. driving without rear drive shaft
  6. Engine Revving/Transmission Disengaging
  7. Any good links for doing brakes on a 96 xj
  8. 1992 4.0 Jeep Cherokee Won't start in park when parked on inclines?
  9. 1992 4.0 Jeep Cherokee Laredo How to turn of maintenance required light?
  10. what kind of gas mileage do you get?
  11. want to put '97 doors on '96 xj
  12. 90 XJ electrical guru question
  13. 1997 Jeep Cherokee Sport - Won't start
  14. Header install
  15. 96 XJ having major issues
  16. 99 Cherokee Sport 4.0L - All gauges failure
  17. Jeep 2000 GCL, turn signals work intermittently, hazards work fine
  18. 89 xj idle problems
  19. 2001 jeep cherokee
  20. condensation water leaking on passenger floorboard
  21. hard to get into gear from park
  22. Sputters at take off
  23. AC recharge
  24. Transmission change
  25. 1993 Cherokee Ignition Switch
  26. 1999 Cherokee Parking lights stay on
  27. lookin at '96 cherokee, got random Q's
  28. 4.0l Engine block coolant draing plug- how to remove?
  29. 1992 jeep cherokee air conditioning blows out of defrost not vents
  30. No Brake Lights
  31. 89 Jeep Cherokee Idling Problems/gas smell
  32. Few questions about an idea I have... 99 XJ
  33. 99 JGC AC Compressor
  34. Opinion - 1998 Jeep Cherokee Sport Utility SE 4D 4x4 6cyl
  35. 99 Jeep Cherokee starting issue and gauges
  36. 1994 Jeep Cherokee 2.5l starter removal
  37. 01 Cherokee front brakes not releasing
  38. 97 Jeep Cherokee Sport squeeks when braking or turning??
  39. Rear Diff Questions.
  40. Jeep doesn't like starting
  41. need info on 90 xj cold air intake?
  42. Annoying squeeking sound
  43. Bizzare Jeep behavior- Wheel locking up at low speed?
  44. how to get brake rotor off
  45. axle
  46. Where is the radiator drain on a '96 Cherokee 4.0 HO ?
  47. 99 Cherokee 4WD Front Drive Shaft ?Repair?
  48. engine upgrade
  49. 87 Cherokee antenna
  50. Jeep tranny problem
  51. 1997 Jeep Cherokee Sport lost power
  52. Wierd problems.. I need help, please
  53. Electrical gremlin
  54. will an exhaust upgrade mess with TPS,CPS,MAP sensors.
  55. 2001 jeep ch sport tranny dipstick wont seperate
  56. 88 XJ Smoking Under the Hood
  57. 87 4.0 hard start when warm
  58. Brush Guard Problem
  59. Fuel Vapor Ldp Probs
  60. 99 Xj 4wd Engine Cuts Out While Driving,no Warning
  61. need help with TPS,CPS,MAP?
  62. will a dana 44 bolt directly to a 90 xj?
  63. 90 cherokee front axle leak?
  64. 90 xj 4.0L, stumble and hesitation during acceleration.
  65. Death wobble ?
  66. 95 Cherokee-Trans leak
  67. 87 jeep cherokee electrical problem
  68. Problem with Lights
  69. rear clicking
  70. 1990 cherokee 4.0 hard start
  71. 93 Jeep Cherokee Country
  72. 1989 Cherokee Laredo no spark
  73. Front driveshaft keeps aspinning
  74. 1996 Cherokee A/c Removal
  75. Pads, Rotors, and Calipers
  76. 2001 Cherokee fuel guage
  77. 91 jeep cherokee misfire
  78. Rear end
  79. 1989 XJ Idler Pulley Removal
  80. Dana 30 wheel bearing
  81. pugs out
  82. 99 Jeep Classic - Front End Rumble
  83. High Idle? ERB?
  84. O2 sensor wiring?
  85. Smoking squirrels
  86. 87 Cherokee water pump
  87. 4.0 and HO 4.0
  88. 98 cherokee grinding
  89. Center Console Removal
  90. Will a 92 Fuel sending Unit work in a 96
  91. RWD to 4WD
  92. HEad swap
  93. 92 Cherokee new engine runs rough
  94. Jittery Start
  95. 01 cherokee transmission problems
  96. '87 Cherokee L/F Hub stuck in steering knuckle
  97. Tranny Slipping
  98. Old 1984 2.5l Cherokee wont start
  99. grinding problems
  100. Torque sequence?????
  101. My jeep wont start
  102. heres info on troublshooting shorts in 90 cherokee.
  103. 90 jeep cherokee low idle problem
  104. I miss my cherrokee
  105. '94 Jeep Cherokee gas mpg drop
  106. brake light switch in 2000 cherokee sport
  107. Amp draw when accesories are on.
  108. Amp draw when accesories are on.
  109. instrument panel short
  110. Exhuast manifold.
  111. oil pan
  112. Replacing Head Gasket?????
  113. 88 Cherokee with yellowish-white on bottom of oil dipstick
  114. 91 Cherokee Rear Tail Lights Stay On
  115. 1976 Jeep Cherokee wiring diagram
  116. 88 Cherokee-Lash in tilt wheel
  117. Hard to start
  118. 4wd linkage issue.
  119. 1987 jeep pioneer-battery keeps going dead
  120. 91 wiper,radio,lighter,blower,turn signals
  121. need help! 1999 jeep Cher. When shifting into 4h or 4l the light on the dash does n
  122. something's not right
  123. 96 Cherokee Rich smelling exhaust
  124. Fias Idle?
  125. Cooling system problems 01 Cherokee
  126. Stupid but easy question
  127. HELP!!! 89 XJ wont start
  128. EGR VAlve missing.
  129. 91 Jeep Cherokee Limited Electrical Problems
  130. '86 jeep carb vacuum lines...Im lost!
  131. Knock After H/G Repair
  132. 4.o Knock after H/ G Repair
  133. front axle qs?
  134. 1989 models
  135. Temp sensor short?
  136. brake question
  137. Please help alternator covered w/ tranny fliud
  138. 93 cherokee elctrical brake/hazards out
  139. 1990 selec trac question
  140. 88 Cherokee Pioneer Ignition/Idle issue
  141. jeep
  142. Cut n fold rear bumper
  143. Help heated seats not working
  144. 88 Cherokee 4WD Transfer Case rebuild or replace?
  145. '89 Cherokee problems.
  146. Need Help!
  147. 1990 Cherokee No Start
  148. I'm stumped
  149. Body Part Question
  150. cant start my 86 cherokee 2.5l
  151. 1998 cherokee limited heater
  152. changing cherokee serpentine belt
  153. Axle bearings-2000 Cherokee Sport
  154. Connector location?
  155. What year ?
  156. 4WD instructions
  157. I think I bit off more than I could chew!
  158. Weird Tranny Problems
  159. 96 cherokee sputtering backfire
  160. Clutch Fluid Leaking Out !
  161. Help!!! Overheating
  162. Best 4 WHD driff for a 88 Cherokee Pioneer
  163. Major oil leak, any ideas?
  164. Need 2 Put A 88 Intake On A 96 Motor
  165. Security alarm problem with a 91 Jeep Cherokee?
  166. 89 4.0 jeep cherokee runs rough help!!!
  167. what are the extra gears for?
  168. Vacuum Actuator 4WD Front Axle ?
  169. How hard is it.....?
  170. Will it work?!
  171. electrical fan won't shut off
  172. '87 Floating steering?
  173. help i cant have fun!!!!!!!!
  174. Starter Wheezing!??
  175. 91 Cherokee Trans problem or electrical???
  176. jeep will not start in cold unless ign held in start pos!
  177. Small question
  178. fourwheel drive jeep cherokee
  179. No 4x4 light or 4x4 front axle
  180. Steering in 4wd?????
  181. Electrical help please
  182. 95 Cherokee really wierd starting
  183. Grinding Sound
  184. Heater Problems
  185. Being proactive?????
  186. Rpm"s
  187. 94 Cherokee Rather Wierd Problem
  188. Wrong Fluid!
  189. 97 cherokee heater issue
  190. Street legality between XJ and YJ/TJ/CJ's
  191. Can a 97 Cherokee be timed?
  192. Miss on "tip in" (accelerating)
  193. Light Switch????????
  194. Electrical problem w/94 cherokee sport, HELP!!!
  195. cherokee 2000 speed problem
  196. 97 Cherokee AX-15 tranny stuck in reverse
  197. xj 90 Fire+Fuel - Start Idle problem
  198. 2001 Cherokee - no heat & it's cold outside
  199. 88 Jeep CHerokee Pioneer MSD Q's?
  200. '92 XJ Cherokee--is it time to say goodbye?
  201. 1990 cherokee cruise control
  202. 95 cherokee wont start
  203. what should my temp be
  204. 1994 Jeep Cherokee 4X4 Front Axle Vacuum Line Question
  205. '87 Cherokee extended crank when cold
  206. serpentine belt ?
  207. 96 Jeep Cherokee Country 4.0 Squeek!
  208. 92 jeep cherokee stereo wire harness
  209. 1991 Cherokee 4x4 front windshield wipers.
  210. 97 Cherokee will not turn on anything
  211. Digg!?
  212. Want To Buy Audio System
  213. New Purchase Advise Please.
  214. lock problems
  215. 96 Cherokee - Missing, backfire only on initial start
  216. 94 jeep cherokee sport electrical ghost
  217. Crap... Death Wobble.
  218. coolant loss
  219. 95 Cherokee AT problem
  220. Testing an '01 Alternator
  221. 1994 Cherokee,headlight relay location
  222. Waterproofing idea
  223. No power mirrors/window locks in '97 Cherokee
  224. Im exhausted :)
  225. Blowing fuses after battery change
  226. 87 pioneer
  227. Cranking problem
  228. A/C problem
  229. 1991 Jeep Cherokee Laredo drop in gas mileage
  230. it broke!!
  231. 1990 xj tumbler
  232. 95 Cherokee..4.0..........No Start
  233. Merry Christmas to me!
  234. Serpentine belt tension 4.0 cherokee
  235. Post 4WD Steering weirdness
  236. some times wont start
  237. Steering issues.....
  238. how to loosen harmonic balancer bolt ? (crankshaft pulley)
  239. stalling issue
  240. 1993 Jeep Cherokee whistling...
  241. 1987 jeep pioneer
  242. 90 cherokee laredo 4.0 water pump .. noises
  243. 99 Cherokee Sport....LUV it
  244. Front caliper bolt??????????
  245. starting problem
  246. 91 4x4 sometimes works? no part-time light
  247. getting loose
  248. Door latches
  249. 87 Cherokee Laredo 4WD Manual 4.0L cranks, but won't fire.
  250. Tires? Wheel beraings? HELP!!
