View Full Version : Cherokee
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Wobble
  2. Window came off tracks
  3. 1999 Cherokee Left Turn Stall (Full Tank) HELP!!
  4. 1998 grand cherokee limited blinking windshield display
  5. R.i.p
  6. What kind of transmission fluid 1986
  7. 1986 Cherokee, 4wd problems.
  8. 90 Jeep Cherokee Electrical Problem
  9. 99 Jeep Grand Cherokee, stalling
  10. 88 jeep wagoneer wont start
  11. 92 cherokee not shifting
  12. 1978 jeep cherokee
  13. How to fix a "p1694" code?????
  14. 93 cherokee possible fuel injector issue
  15. Engine dies when throttle let go.
  16. how do you fix rear gears?
  17. Connector
  18. cross member
  19. 1995 Jeep Cherokee stalls immediately after ignition released
  20. i need help
  21. 1991 laredo shifting probs on accel.
  22. 99 NSS switch HELP!!!
  23. Check engine light on 89 cherokee
  24. Whats with this my baby
  25. Not running well
  26. how tight
  27. Vibration on accel
  28. gonna take a look at cherokee tomorrow need advice
  29. stuck in 4wd 85 cherokee
  30. CD Player Mode disappeared - Please Help!
  31. i Need to change my tranny mount
  32. bypass air conditioner
  33. Weird Coolant leak
  34. Gas tank siphon question
  35. powerwindow switch pass side works intermittently
  36. 1997 4.0 bucking problems???
  37. 89 Cherokee Laredo fuel system problem?
  38. tps issues
  39. popping noise when i turn steering wheel
  40. don't know what this code means...
  41. 98 4.0 Trans. Trouble
  42. 1995 Grand Cherokee trans cooler line repair
  43. 1995 Grand Cherokee speed sensor o-ring
  44. Wet Floor on Driver's Side of 97 Laredo
  45. 93 5.2L JGC backfires at around 2000 RPM
  46. Shimmy at acceleration
  47. 95 jeep sport no reverse
  48. 97 cherokee wont idel
  49. 88 cherekee inline 6 4.0 L
  50. lean codes
  51. Idle Issues-intermittently
  52. Tilt steering broken
  53. 88 cherekee
  54. will not shift into drive
  55. 99 Jeep cherokee motor fan
  56. Cherokee Sport Won't Turn Over
  57. 98 2 door xj driver seat
  58. 1989 Jeep Cherokee - Hazard relay location?
  59. thrown rod--is it worth it to get new engine?
  60. 99' Laredo sputtering issue
  61. help noise after pressing gas pedal
  62. tranny question
  63. tranny question
  64. spiking engine temp, dropping voltage?
  65. turn signal, winshield wiper knob not working
  66. 96 xj tire size question
  67. Front passenger speaker not working
  68. 99 Grand Cherokee front end noise
  69. Transmission Problems
  70. 99jeep computer interface has no power
  71. Engine Cranks, no start
  72. 1988 Cherokee ticking
  73. auxiliary fan comes on at start up
  74. Cherokee Sport Shutting Off
  75. Tranny Slipping in OD
  76. 99' Grand Cherokee Laredo gas economy?
  77. Battery dies in cold temps
  78. start and then stops
  79. dissapearing heater...
  80. turn signals dont turn
  81. Pardon the dumb question: how do you put a 96 XJ in 4wd?
  82. 96 XJ strong gas fumes
  83. XJ will drive in reverse but not forward!
  84. jeep wont start
  85. 96 Jeep Starts sometimes
  86. Power Brake Problem
  87. Xj Transmission Problem
  88. 98 cherokee overcharging
  89. ccv orifice problem 93 jeep cherokee country
  90. 88 XJ Engine Grinding Noise
  91. cruise control?
  92. 93 jeep cherokee 4.0 HO/running rough
  93. 2000 Cherokee Link Add to No Start XJ
  94. 1995 xj 4.0 pin test
  95. Heater problems
  96. Shop Manual 2000 Cherokee
  97. serpentine belt tension .. broke the adjuster.. 1990 4.0 laredo
  98. oil in coolant 88 cherokee 4.0
  99. 2001 Cherokee Sport Window Problem
  100. 1999 Cherokee Cruise Control problems
  101. bigger gas tank for xj
  102. Keys, please
  103. Locked Wheels on Ice while Sliding and Gear Clicking Sound
  104. Oil level grows 99
  105. 98 Heater Problem
  106. One you don't hear too often
  107. Warranty extension '96-'99 Please read
  108. 97 xj wont stay on
  109. Problem with 4X4 Shifting on Selec-Trac
  110. 2001 Cherokee brake issue
  111. power window switches replacement?
  112. 1998 Jeep Cherokee Serpentine Belt Replacement 4.0 6 Cyl
  113. 1998 Jeep Cherokee Serpentine Belt Replacement 4.0 6 Cyl
  114. 1989 Jeep Ignition Nightmare
  115. Advice on plugs
  116. 231 J Transfer Case Swap
  117. More Flexplate Issues/maybe More
  118. bad cat or engine / sensors ?????? 4.0
  119. 99 Cherokee - Odd Electrical Problems
  120. 1998 Cherokee Running problems
  121. engine problems!
  122. replacement radiator question
  123. 87 Cherokee for parts
  124. 96 Cherokee 4.0 Intermittent idle problem.
  125. 89 Jeep Cherokee
  126. 2000XJ - Turn Signals
  127. 1990 jeep cherokee sport heater blower?
  128. 1990 jeep cherokee sport heater blower?
  129. Bad Squeaking When Thottled
  130. slow start and high idle(couple seconds) when cold
  131. Dashboard lights
  132. '96 Jeep Cherokee
  133. engine swap
  134. weather drop=dramatic mpg drop-is it normal with cherokees???
  135. clunking noise when turning with 87 Cherokee
  136. Driveline wined up? Clunk, bang sound.
  137. Mystery shifting problem, big mpg drop, out of ideas.
  138. Engine wiring harness. 96 4.0 4x4
  139. Starter Relay
  140. 01 Jeep Cherokee Transfer Case issue
  141. bad alternator ?
  142. factory shocks and lift???
  143. Heater/AC fan control issue
  144. Running and Shifting Issue. Help Guys!!!
  145. xj fuel tank swap 98 to 89 -will it fit???
  146. fuse
  147. Brake line
  148. Need Help Stranded 88 Cherekee
  149. 88 XJ - Tranny slipping when cold outside
  150. How important are wheel weights?
  151. Question from a new Jeep owner.
  152. Flushing closed system and fan sensor help
  153. Bottoming out!
  154. mild 3" lift but...
  155. Ignition mystery
  156. 1990 Jeep Ignition Inigma
  157. High Flow H2O pump vs. louvers?
  158. Airbag light?
  159. heater hose pipe name?
  160. 89 xj runs, then.... it quits?!?!?!
  161. 95 Cherokee. Need Help! Stranded!!
  162. 89 cherokee fuel pump
  163. gas guage not working on 93 grand cherokee
  164. parting my 1993 jeep grand cherokee laredo
  165. Manual Transmission
  166. 1998 Jeep Cherokee
  167. pulled ABS fuses now brakes don't work
  168. rear main tourqe
  169. Command Trac & Select Trac
  170. Fender Flare Brackets
  171. Still no Mirrors
  172. Transfer case question
  173. 97 Jeep cherokee Clanking/Rattling sound on startup and idle
  174. need help on 1989 Cherokee Laredo
  175. need help on 1989 Cherokee Laredo
  176. transmission leak on a '98 ZJ 4x4
  177. 1988 Jeep cherokee 6cyl man. tran. clutch wont engage!
  178. auto to manual?
  179. jeep over heated and wont start
  180. Reman Head
  181. fault code 54?
  182. 1990 XJ "Neutral Slips"
  183. Why won't it work?
  184. keyless remote entry question
  185. keyless remote question
  186. Help
  187. clicking sound when accelerating in 2wd & 4wd
  188. No brake lights or hazzards
  189. Starter problems
  190. great beater
  191. limp mode
  192. Feil odor coming from engine
  193. '94 sport stumble
  194. child car seat/ cherokee2.5 diesel 60th anniversary edition
  195. 95 cherokee OEM cruise control
  196. 1997 Jeep Cherokee Country P700 Code
  197. 2000 Cherokee Sport Electrical Gremlin
  198. blowing fuses.
  199. electric fan & clutch fan
  200. Hard Brake Pedal 89 Cherokee
  201. textured grip oil filter!?
  202. Cherokee Cooling Issues
  203. 98 Cherokee Cruise Control issue
  204. HELP!!! Please its my bday
  205. 96 Cherokee. Tranny fuild boiled over.
  206. Love at first sight, now kicking the dang thing
  207. cherokee wheel spacers
  208. 93 cherokee ax-15 compatibility question.
  209. 2000 Speedometer & Tach Quit "no bus"
  210. 1988 Jeep Cherokee Air Intake Hose
  211. Need help! #16 Fuse doesnt work at all!
  212. 1998 jeep cherokee sport problem
  213. what are these parts??
  214. 88 XJ Stalling
  215. 94 sport rattling
  216. Idling High in everything but drive and reverse.
  217. Another hot jeep question
  218. How many Electric fans?
  219. 01 cherokee a/c compresser clutch replacement
  220. tranny flush Yes Or no?
  221. FS: 1989 Jeep Cherokee XJ
  222. ABS Trouble? I think
  223. Tried everything, still nothing
  224. 1999 cherokee fuel problem
  225. 88 4.0 Vacuum Diagram
  226. Windshield wiper motor on 89 Cherokee Laredo
  227. 88 cherokee has clicking sound
  228. truth about cleaning engine compartment
  229. Engine knocking like a p'd off woodpecker
  230. Clutch & brake pedal assembly question
  231. tire wobbles
  232. funny sound comming out of engine compartment
  233. 91 Cherokee hesitation and low idle
  234. 1994 Jeep Cherokee Rear Wheel Bearings
  235. 2000 Jeep Cherokee grinding problem
  236. which fuel pump to purchase?
  237. Wont Start Please Help
  238. Air Conditioning
  239. "Cheap" upgrades?
  240. What tire size for 15x10's with 3.5 in backspace for Cherokee Sport
  241. 90 xj 4.0 engine light on when in 4wd
  242. temp. gage broken
  243. 96 cherokee sport. Miss after HG change.
  244. replace transmission mount
  245. Cherokee serpentine belt
  246. drop in voltage when blower fan on?
  247. 97 Cherokee gauges tach radio not working
  248. high pitched squeeling
  249. Food for thought!
  250. help me with my clutch?
