View Full Version : Cherokee
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [ 21]
22
- GAS Mileage?.?
- 91 Cherokee Bucking under smallest load
- 86 Cherokee Tranny needed!
- 1990 jeep missing or stalling???
- turn signal problems
- Auxilliary fan runs for 30 min after parking
- Check Engine Light (MIL) - Need your input
- 2000 Cherokee Cruise Control On/Off Button
- Cherokee vs Blazer
- 4 wheel drive noise
- correct trans fluid for 88 2wd auto
- 98 Cherokee Power Windows
- Full Size spare rack 2001 Cherokee
- 5 speed Cherokee Manual Transmission
- guages,blinkers,heater fan
- 1999 Jeep fuse panel
- 93 sport clattering! HEEELP!
- cherokee tilt steering adjustment
- Radio wiring harness color code
- 94 cherokee sw
- Rear differential noise in reverse
- XJ lift???
- 87 jeep ECM
- 95 Wrangler,clutch question
- Rookie - 94 Cherokee 4wd Questions
- Comatose Jeep!
- 1995 Jeep Cherokee headlight relay
- low heat...
- 95 Cherokee Sport, NO HEAT, Help!
- Help! '98 Cherokee - interior lights staying on!
- front end knocking!?
- 2000 Sport rear sagging, HELP
- 1994 cherokee sport parting out
- 89 cherokee: starter and more.
- 1994 Alternator removal
- 1991 Jeep Cherokee Questions
- Rocker Arm Cover (aka Valve cover)
- 1998 cherkee sport keyless entry
- 1999 Jeep Cruise Control
- 1988 Laredo
- 87 Cherokee Auto Tranny wont Engage??
- OPINION on Clutch Brands
- Custom Wheels for JEEPS
- Tow Hooks
- Like some 93 help on door-locks&pwr windows
- 90 4.0L No power, no rev past 1400 rpm
- To Lift or not to Lift...???
- Won't Start?
- Neutral Safety Switch Location
- Radio Antenna
- 89 Cherokee Chief 4.0 won't start backfires flames from injector
- 92 Cherokee overheating and no heat
- Manual trans removal on 91 2 wheel drive
- Newbie Here needs Help Please
- Complete Wiring Harness
- 1996 cherokee headlight switch
- 1990 Testdrive noise
- hornless xj
- body lift or not
- new speakers 2000 Cherokee Sport
- Power windows wiring problems
- 1990 jeep cherokee
- correct motor mount install
- UPDATE: Missfiring and backfiring on 89 cherokee 4.0
- Abs problems!
- E-brake light
- Turn signal light
- Fuel Regulator 1987 Pioneer
- Help w/Replacing Fuel Pump in 99 Cherokee
- neutral safety switch
- steering problem
- 89 xj idle problem
- '98 4.0 Coolant Color
- Headlight switch
- 1999 won't start, idle air intake problem
- Noise behind dash.
- A couple of questions
- Back-up Light Switch
- Power Windows and the amazing mystery
- 88 Cherokee stalls out sporadically
- 94 cherokee mods
- 96 cherokee no crank, then runs, then no crank
- cup holder for 94 sport
- several questions about 94 cherokee sport
- 89 Jeep Cherokee
- Spark Plugs?? Advice please....
- fuse panel for 90 cherokee
- Airbag Light/Starting/Speakers
- lug diameter
- 1988 Jeep Cherokee Electrical Problem
- question about 4wheel lo / hi
- Electical problem
- Advice Needed: MIL
- xj
- Help 1994 Cherokee Will Crank Won't Start
- Brakes at 20,000 miles?
- differential fluid change/trans fluid change
- Aftermarket jeep parts for sale
- 1996 Cherokee driving me nuts.
- 1995 Cherokee Sport Clutch Problem?
- Brake Lights Won't work...Help!!!
- parting out 89 xj
- Cherokee Problems. Starts, not a key issue, but won't run occasionally.
- coolant cap hiss/coolant dribble from same
- Cherokee Racing!
- '90 Comanche 2.5
- Cherokee model chronology
- 1991 Cooling Problems
- Need help wiring my head unit
- 1995 jeep cherokee sport
- Help!!!jeep Starts But Won't Run
- 1990 Cherokee Electrical Issues - Starting - Charging
- 1996 Cherokee--Reverse lights work when they want to..
- 1988 Jeep Cherokee Pioneer 4WD light on dash display
- Hard first start of day
- 96 XJ Rear Retracting Seatbelt
- 2000 Cherokee Rear Main Seal
- 1989 XJ stalls after warmup suspected fuel pump
- Bump after braking
- headlights
- trouble codes
- Jeep wont start when warm
- 95 Cherokee Sport - leaking Fuel Pump?
- Update: 89 Cherokee/Poor Mileage
- valve cover gasket replacement/motor mounts
- Select-Trac & ABS
- suspension lift ?
- what is an xj
- 4wd aftermath
- interchagable years
- rear hatch
- Newbie, Help with lift kits.....
- newbie/ jeep cherokee/timing belt change etc
- 94 cherokee 2 button remote programming
- 1986 Jeep Cherokee, Part time Light
- jeep cherokee starter switch ?
- 89 jeep xj still clunking
- A couple of problems....
- Fuel System Problems!! Heeeeellllppp!!!!!
- 2000 6Cyl. Idle Problem
- 84 Cherokee after Stalling Will not start for hours
- Grand Cherokee Service what to do @ 125K miles?
- 1996 Oil Light problems
- '95 Cherokee - "Clunk" Coming From The Rear End
- CHEROKEE WON't START, Details inside, NEED HELP ASAP
- 89 Cherokee won't start
- How do i remove ignition lock from my 1999 Cherokee
- 88 Jeep Cherokee
- Cruise Control-less!
- Alternator
- 89 Cherokee Bad Mileage/Smoking
- High Oil Pressure
- K&N Air Intake Kit
- 1991 Jeep Cherokee Electrical Problem
- transfer case
- 96 Sound System
- Cherokee 4.0 fuel leak
- '88 big water problem
- clunking 4x4???
- 96 XJ Cruise Control
- EGR valve question
- idle problem
- One Leg & HOPPING??How do you put tires on a guitar???
- A couple of problems with my jeep...
- need help from someone with a 98+ Cherokee
- Cherokee Sport Rear End / Differential noise
- One Leg & RIDING!!Yahoo
- A/C Compressor Clutch
- What code is 1-1-5-5????
- Jeep Transmition change?
- 1999 Cherokee Rear Wiper Fluid
- Jeep does not work help!!!
- Heater Gone Cold
- 89 cherokee multiple engine problems
- One Leg & walking, HELP! 94 Cherokee Sport
- help with hooking up linkage
- Some Questions about 96 Jeep Cherokee
- Water pump pulley removal - 1990 Ltd.
- 1992 Rear View Mirrior
- 1999 Jeep Cherokee Electric Fan
- taking out engine
- Discount source for OEM Jeep parts?
- Keyless entry conversion
- 94 Cherokee Sport, stalling, told to check CPS plug for corrosion. Locate?
- slave cylinder
- Door Pannel Problems
- Squealing belt - 2000 Cherokee Sport
- Rear main seal
- Cherokee wont start, see if you can figure it out
- Low beam headlights out on '92 Cherokee
- 95 Cherokee Cabin Fan Fuse
- jeep compatibility
- 90 Clutch / ignition switch
- Stock stereo mod... wierd
- brake switch change out?
- Air Intake for Jeep Cherokee(XJ)?
- 90 jeep cherokee 4.0 fuel pump relay location
- 4wd questions
- electric locks go bezerk
- Buying a Jeep - what problems to look for???
- Cooling Problems2
- Gear noise during braking
- anyone in brooklyn,ny??
- circut breaker for power locks & seats
- water pump or pulley noise?
- 1987, chugging
- Missfiring and backfiring on 89 cherokee 4.0
- where's the drain bolt???
- Cooling Problems
- '90 Cherokee problem starting up
- HELP! Where do I find the crankshaft position sensor
- stalls in left turns
- Cherokee "Bobble" in Steering. Help!!
- Overheating
- 92' power windows wiring
- Best Jeep Cherokee Repair Manual
- Help finding a fuse!
- 1990 - hard start and overheat
- 1989 Cherokee CLutch system trouble shooting
- Help, ASAP
- AM/FM Radio Trouble
- 1985 Transmission Problems
- leaky rear hatch on 89 cherokee
- 2000 Jeep Cherokee SE, 3-speed?
- LARGEST TIRE FOR STOCK 98 Cherokee with 16x7 RIMS
- cracked block i think
- 89 cherokee starts and dies
- 1990 Cherokee ABS problems
- 1990 Cherokee headlight
- 88 Won't Start
- Painting a jeep cherokee chief?
- 1996 A/C problem
- clutch going?
- which relay for auxiliary fan
- No dash lights after radio install?
- Suspension
- New Rebuild won't start . . .
- '95 Cherokee Dash Panel Removal
- Part Time lamp
- 1995 Jeep Cherokee Front Passenger Window Problem
- 1995 Jeep Cherokee Front Door Panel
- Radiator.com...
- transmision Problem
- selling cherokee
- axle ratios
- 1989 cherokee
- 1991 cherokee sport
- Best 3" lift kit
