guages,blinkers,heater fan
jeepthing
02-01-2004, 03:25 PM
I have a 1991 Jeep Cherokee, On the guage cluster the temp, oil, and speedometer will not work, also eveyonce and awhile my blinkers and my heater (blower) fan will stop working for a few min, but my hazards will work. ANY IDEAS?
MagicRat
02-01-2004, 07:01 PM
Gauge cluster problems may be a bad ground to the cluster itself. The other problems could be poor connections????? No specific problem area comes to mind.
flurpo
03-18-2004, 06:51 PM
Not sure about the cluster electrical issues. The intermitent blinkers, heater and fan point to the ignition switch at the base of the steering column. Test the fuse box for power on these items when the car is on and you see the problem. Good Luck.... :iceslolan
