View Full Version : Cherokee
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. '97 Cherokee a/c issue
  2. Jeep Cherokee head gasket insight please!
  3. A dealership mess and I’m Looking for opinions on my head gasket.
  4. Desperate for Answers
  5. Secondly fuel filter
  6. Transmission issue?
  7. Jeep cherokee Immo file for viretronics
  8. 2016 Cherokee Tail lights
  9. 2019 Jeep Cherokee Air Condition problems
  10. 1996 Jeep cherokee turn signal hazards and brake light problem
  11. 1995 Cherokee CountryT/Case Switch Wiring
  12. 2019 Cherokee incoming call/text volume
  13. 1989 XJ ECU removal
  14. Fuel injector system not responding
  15. 2019 Cherokee hood loose
  16. 4.0 misfire and running rough
  17. What does this button on the shifter do???
  18. 2015 Cherokee stalls when cold
  19. 2001 Gr Cherokee Jeep Laredo-reverse gear problems
  20. 1996 jeep grand cherokee electrical problem
  21. Damage to jeep Cherokee
  22. 1991 Jeep Cherokee Overheating? Please Help?
  23. 96 xj frame rotting
  24. Jeep Fule problem
  25. 4.0 Inline 6 engine swap with different year
  26. test your knowledge!
  27. 88 jeep wagoneer overheating quickly
  28. Jeep Cuts out while A/C is on
  29. Bad noise IN Front of Jeep Grand Cherokee
  30. 1996 jeep cherokee lighting problem
  31. Replacing ignition with a momentary switch?
  32. New Cat Converter No 02 Port
  33. 1993 Jeep Cherokee Country / Starting problems
  34. Clunking noise front drivers side video link attached
  35. Lighting Lens
  36. 89 jeep cherokee pioneer
  37. Changed out push rods and my 1998 jeep is still making a knock/ticking noise in engine
  38. 95 jeep cherokee sport stuck in 4lo
  39. 1987 evap system
  40. 92 Cherokee won't stay running
  41. power door locks 95 cherokee
  42. 95 Jeep Grand Cherokee shifting problems
  43. '89 Comanche Parking Brake Release Cable Broke !
  44. Will 84 Cherokee master clyinder work with 4 wheel disc?
  45. Cherokee 99 Sport Anti Theft
  46. Smoke from exhaust
  47. 1992 Jeep Cherokee Sport. Jumping, stalling when it heats up.
  48. fuel system
  49. Radiator Fan Clutch Fins - Can you cut them off?
  50. 2014 Cherokee 5 miles and towed.
  51. NP242 rebuild questions
  52. 99' Cherokee Not starting can't figure....
  53. 99 Cherokee-no turn or flashers
  54. New Reman Motor.. Is this normal? video link included
  55. Exhaust header advice
  56. 96 xj 300k low compresion
  57. 99 cherokee v6 no high idle w/cold start
  58. 1995 Cherokee Keyless Fob
  59. Need new CPS but which one?
  60. Low heat 98 Cherokee 4.7L
  61. Transmission/Transfer Case question.
  62. a/c problem...
  63. 2001 XJ brakes not engaging all at the same time
  64. adding pag oil
  65. 2 Wheel Drive
  66. 01jeep grand Cherokee gas tank removal with splash plate?
  67. 96 Xj Odd no start issue ( long story Sorry)
  68. 96 xj track bar issue
  69. 2014 Cherokee..Jeep what have you done to the XJ
  70. Ball joints adjustable or ???
  71. 2001 XJ Highmount Brake Light
  72. 2000 Cherokee needs priest please help!!!
  73. 1986 Jeep Cherokee XJ-Hot air actuator for manifold air
  74. Need Some Advice on Jeeps
  75. No Heat at Idle
  76. Does tpms detect spare tire?
  77. Passenger side brake light won't engage 04 Grand Cherokee.
  78. Exhaust Manifold Gasket Leak - (Fix ?)
  79. How do you disconnect the BUZZER ?
  80. 96 cherokee 30 amp auto shutdown relay fuse
  81. 1996 Jeep Cherokee distributor pickup problems
  82. 96 xj Mystery squeak
  83. jeep longevity 2
  84. 1996 Jeep Cherokee will not start.
  85. jeep longevity
  86. 97 Jeep wont start
  87. 96 XJ tire size issue
  88. Stalling 95 ZJ when brakes are applied.
  89. 96 xj gas gauge issue
  90. 96 Cherokee have run out of ideas to get ur started
  91. 97 Jeep 4l Distributor ticking /shocks if touched also misfire through air intake.
  92. 1987 jeep cherokee fuel and no start problem
  93. jeep cherokee
  94. The CPS fun never ENDS. EMERGENCY!!
  95. New Ignition control switch and key cylinder and still won't crank
  96. 2000 Cherokee Sport Window Control Problem
  97. Need Help with New Distributor
  98. 96 XJ swapping driver/passenger seats
  99. 00 Cherokee A/C Diag
  100. 90 XJ .. front axle shaft & hub .. can you drive without axle shaft? 2 hubs wrecked
  101. 1991 Jeep Grand Cherokee Laredo, worth it?
  102. 99 Jeep Cherokee Limited, Starter issue??
  103. 99 Jeep Cherokee Limited, Misfire or fuel problem?
  104. Cannot start my 94 xj...
  105. 96 xj multiple misfire issue
  106. Help: 96 jeep grand cherokee won't start
  107. 1996 cherokee
  108. Battery/Starting problems
  109. 4WD will not disengage
  110. timing issue 92 Cherokee
  111. Wont start, and when it does there's a chance it will stall
  112. 2001 Cherokee gremlins, Wont start...
  113. 1991 Jeep Cherokee Laredo 4.0L Inline 6 wont start.
  114. Brakes Dragging After New Brake Booster and Master Cylinder
  115. Comanche Dies With Electrical Load
  116. short somewhere?
  117. 92 Cherokee front end noise
  118. 94 Jeep Cherokee Wandering Belt
  119. 91 jeep cherokee laredo inline 6 wont start
  120. 96 jeep wont stay running
  121. 88 Cherokee Project Jeep
  122. Thank You
  123. Intermittent No Start - ignition circuit?
  124. tranny question re: Laredo and Grand
  125. MIDDLE VENTS NOT WORKING... While Outer vents do????
  126. Rough Country Lift advise please....
  127. More with 87 Laredo
  128. 87 Cherokee Larexo 4x4
  129. Cherokee CUT IT OUT!!!
  130. 2001 Jeep Cherokee - Horn dead
  131. ac cuts out @ higher rpm's
  132. ball joint replacement DIY or pay someone
  133. 231 Transfer case question
  134. Blower motor not working at all, 99 cherokee sport
  135. How difficult - changing Thermostat 2001 cherokkee Sport 4 L Straight Six
  136. Sentry Key and rpm's at 55 mph with AT.
  137. AC cold then hot
  138. 96 Xj, Strange AC problem
  139. Knock Knock!!
  140. 99 cherokee wants to stall out...
  141. 1999 Cherokee 4.0L Limited Won't Turn Over
  142. 1991 Jeep Cherokee Engine Removal
  143. Vibrating as I brake
  144. Anyone else have problems opening the back doors?
  145. 96 XJ power windows locks Wiring help
  146. 98 Jeep Cherokee/First Post
  147. Brake Rotors question
  148. jeep cherokee 1989
  149. New Cherokee Owner
  150. 98 Jeep Cherokee Sport Alternator
  151. Jeep Cherokee 99'
  152. Window motor replacement 1988 Grand Wagoneer (Cherokee)
  153. Overheating problem on a 1988 cherokee with a 4.0 inline v-6
  154. Please, I need help determining a broken part.
  155. Jeep Cherokee Dashboard Lights issue
  156. Random Misfire, Rough Idle I-6 4.0L
  157. Headlights flash after driving a while.
  158. differential oil question
  159. Rockers
  160. Tdc
  161. runs hot FAST
  162. Keyless Entry Security System
  163. High RPMs on start
  164. Steering issues
  165. 1996 Jeep Cherokee won't start
  166. '96 Jeep Cherokee Sport: Starter clicks but doesn't start
  167. Cruise Control on 99 Cherokee
  168. 89 rear end troubles
  169. 1994 Multi elec. problems
  170. Cooling system overhaul
  171. 96 xj power steering pump freezes up
  172. Not sure if it's the alternator, battery, terminals, or ground to chassis.
  173. New radiator install .. a cpl questions, that sensor for 1
  174. 2001 Jeep Cherokee A/C
  175. No fuel,89 cherokee
  176. Emergency Cooling System Fix .. Best $6 ever .. PERMATEX Thermostat Gasket RTV
  177. 90 Jeep Cherokee 4X4
  178. 2001 XJ brakes question
  179. cherokee will not take 4 wheel drive
  180. 2000 Cherokee Sport Lift Kit ?
  181. Immobilizer
  182. Spark Plug Wireset Recommendation ?
  183. 1992 jeep cherakee
  184. where is back up switch?
  185. How to put in 4 wheel drive??
  186. 86 jeep cherokee 4.0 4x4
  187. Inline Heater Valve question .. had to cut it off, emergency fix
  188. Replaced brakes (rotors and drums) and they are dragging.
  189. no speedometer , tachometer or fuel gauge 94 cherokee sport
  190. can you put JK seats in 2001 Cherokee?
  191. 98 cherokee 4.0L Won't Run - HELP NEEDED
  192. Heater problems
  193. 1988 Jeep Cherokee Erratic Idle and oil problem
  194. rubber plug in rear diferential?
  195. The myth about changing and not changing transmission fluid
  196. 89 Cherokee 2.5 engine quit unexpectedly, start intermittently and again died unexpectedly
  197. 01 jeep rf blinks fast rr has no voltage at all
  198. Broke brake line.
  199. Belt squeal?
  200. New to 4X4ing
  201. 2000 Jeep Cherokee
  202. Oil Pressure
  203. 96 Xj Pitman Arm
  204. New To ATL... Jeep mechanics?
  205. 1995 jeep GC stereo problems
  206. Spedometer issues
  207. 1987 cherokee steering column replacement
  208. Part Time indication
  209. 1987 cherokee steering wheel nut
  210. Dash and tail lights dont work
  211. 4x4 full time wont engage, grinds when shifting out of
  212. What is this hose that is about to break on my car?
  213. 88 Cherokee stalls sometimes
  214. Grinding Noise in Engine
  215. 1999 cherokee 4.0 running hot....sorta
  216. Jeep Grand Cherokee has fast idle cold then stalls when warm.
  217. Dead Instrument Cluster
  218. where should rotor point at tdc?
  219. different flywheels on 4.0L?
  220. 98 XJ grinding when turning left
  221. Jeep wants to stall when turning into parking space
  222. 1996 XJ just quit while driving
  223. HVAC air distribution problem
  224. Wheel cylinder, leaks but doesn't?
  225. can I bypass auto shutdown relay?
  226. no spark no spark NO SPARK!!!!!!!!!!
  227. Jeep will start but wont run
  228. 98 Cherokee Sport Engine Swap?
  229. starter works without starter relay?
  230. auto shutdown relay?
  231. 96 Jeep Cherokee sticky window
  232. swapping instrument panels
  233. over fueling
  234. Think I need to change steering knuckle
  235. oil filter adapter--different bolts
  236. Bought new radiator. Plastic cracked. Is this okay?
  237. rear seal--ARE YOU KIDDING ME !!!!!!!!!!!
  238. 4.0 lifter
  239. 96 xj powerwindow/locks problem
  240. 93 XJ Random Start Issue
  241. should track bar bushing wear out in 2 years???
  242. Should I bother with valves?
  243. 99 Hood wont latch
  244. What not to buy ?
  245. Oil Filter Adapter Gasket
  246. 1998 weird overheat issue
  247. 92 Jeep Cherokee leaking coolant
  248. How to replace an ignition swith on 89 Cherokee 4cyl. 2.5 litre
  249. horn relay location 93 sport?
  250. '89 Cherokee won't start in the heat
