View Full Version : Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. bose system integration adapter
  2. looking to buy maxima
  3. flex pipe needs replacing
  4. Okay, help me here dudes.
  5. ODB II protocol for a 2000 Maxima
  6. 2002 Infiniti I-35 OEM BOSE 6 Disc CD Changer/Radio/Cassette
  7. what is this?
  8. Knock sensor was replaced...
  9. high brake light 1999 I30
  10. 97 Max Air Sound Question???
  11. idle adjustment
  12. 1999 maxima oil pressure guage Q's
  13. sticky throttle/gas pedal
  14. 89-94 maxima parts
  15. Transponder key
  16. Where is Audio Amp Relay for Max 95?
  17. maxima locking problem
  18. 01 maxima foglights
  19. Traction Control Malfunc & SES light on
  20. 92 Maxima SE Auto Need help!!!
  21. NEED 98 I30 FOG AND CORNER LIGHT ASAP Pass-side
  22. cefiro headlights
  23. How's I30?
  24. I30 Rear wiring
  25. tire problem, please help.
  26. coil packs replaceing after 200000KM
  27. Remove radio in Cefiro 1999?
  28. Eec Codes
  29. 96 i30 oil leak
  30. about to buy 91 max SE
  31. Slow!
  32. wtb. 96 or 97 maxima
  33. Emergency Brake problem
  34. any new zealand maxima/cerfiro owners out there ?
  35. Question about Computer numbers.....
  36. 2000 maxima exhaust
  37. 95 maxima starter location?
  38. 95 Maxima Flex plate swap
  39. How to read codes?
  40. 96 Maxima, Fog Lite Kit Installation
  41. 96 maxima timing belt replacement
  42. Brake jam after idle for few hours(2001 I 30)
  43. 2000 Maxima dies when I put it in gear
  44. rims
  45. 2000 Maxima engine service soon light problem
  46. where is Throttle Position Sensor at?
  47. 2000 Rpm
  48. 96 Maxima Cut BCM Harness
  49. Auxiliary Fan Motor Problem - Not Sure
  50. Flowmaster...
  51. acceleration problem please help
  52. i smell gas
  53. FS: Yakima Roof Rack System for '04 Maxima
  54. ECU upgrades
  55. cruise control
  56. Brand new tires 4 sale
  57. start
  58. light bulb change
  59. 2001 Infinity I30 O2 Sensor Bad already?
  60. Computer problems....
  61. Fuel Guage
  62. Car chugging
  63. 1994 Maxima wiring....
  64. 2002 SE 6 spd Problems
  65. 99 Maxima Service Engine Soon
  66. Maxima's..Future Car..How Are They..
  67. Headers for '95 maxima?
  68. problem starting max
  69. just did 60k tune-up, what a difference!
  70. Check list for 94 Maxima
  71. will 2005 maxima rims fit my 98?
  72. g timer 2
  73. Maxima 92 Ti Electical Problem
  74. 93 maxima interior lights bling for 2 minutes on startup
  75. how does one program a car remote
  76. Degree timing change?
  77. 1997 Maxima SE- slow to start
  78. idkle air control
  79. Question About Swapping Factory Radios
  80. 97 I30 Won't start just hear buzz and pops
  81. Need new trunk
  82. Best CAI Filter
  83. 1996 Infiniti I30 won't start
  84. 98' almost stalls in cold weather
  85. engine swap
  86. F/S NEW(never installed) MEVI with cover and install kit.
  87. Exhaust Recommendations
  88. ?'s about 00-04 max's
  89. help! is my shaking 2000 maxima dying?
  90. 95-96 vs 97-99 grille
  91. my new 2004 maxima SL.
  92. 1990 Max mods
  93. tires
  94. 1993 Maxima GL Axle Boot
  95. Side markers and fogs don't work!
  96. Does Tire Size make a Difference? ? ?
  97. nissan cefiro
  98. G-Tech Pro
  99. Bose stereo cuts off
  100. replacing spark plugs
  101. ECU Question
  102. Newbie here! 90 Max won't start!!!! Help! Anyone!
  103. in-cabin microfilter 2001 i30
  104. new code
  105. Cylinder problem, and ground wire.
  106. Power Antenna -98 Maxima Wiring Troubles
  107. Idle Burp - 99 Max
  108. Lifters - possible to only replace 2 or 3?
  109. 1994 Nissan Maxima GXE - Will not go into P
  110. Oil leak
  111. fuse diagram for 1995 maxima
  112. carbon fiber hoods
  113. heater problems
  114. Dead Forum
  115. CA31 Cefiro again
  116. Winter car.
  117. Engine Light
  118. 99 Maxima Fuel Economy
  119. Lowering on 20's
  120. Any good Mechanics(NISSAN) that anyone can recommend in Los Angeles
  121. 95-96 vs 97-99 Body Question
  122. WTB 95-99 SE 5-Speed Atlanta
  123. 91 Max Speedometer/Odometer
  124. -93 J30 Maxima dash lights R&R
  125. Fuel Pump Relay
  126. 20" rims for an i30/maxima/etc for sale cheap
  127. Engine Ticking noise - Lifters? need help!
  128. 2004 Maxima strange noise from dash??
  129. Tires
  130. "Sensor" Warning Light '87
  131. 1995 Maxima SE VS. 1994 Toyota Camry
  132. Parting 86 Nissan Maxima
  133. Braking Problem
  134. 2005 Maxima vibrating problems
  135. headlight removal
  136. 94 Nissan Maxima Tranny problems.....
  137. 2000 A33 Maxima Transmission problem
  138. 1999 Infiniti I30 keyless entry
  139. Engine Swap
  140. Rusty rotors, what to do?
  141. 04 max y pipe
  142. hyundau
  143. (98 max auto) VS (98 Accord V6 Auto coupe)
  144. 1992 Maxima J30/VG30E not starting when warm
  145. engine oil
  146. stalling in reverse
  147. Sellin my rims
  148. Help with purchase:99-01 Maxima
  149. Want to Trade my 98 Eclipse for 5spd Maxima!
  150. please help
  151. headlights
  152. Loss of power!? 93 automatic se
  153. Keyless entry remote question
  154. Hesistation caused by fuel injectors?
  155. VTC Gear
  156. air bag light on
  157. Wanted: 95-98 Max Standard Cd player unit
  158. interiors for sale
  159. Newbie Looking For Maxima Resources
  160. Oil on alternator
  161. Engine (transmission?) Mounts
  162. 97 Maxima 3.0 auto trans Question
  163. Potions for a new deck
  164. Reliability of VQ30
  165. Wanting to trade 95-99 Maxima rims
  166. 2000 Maxima front rotor removal
  167. problems
  168. maxima vs. legend coupe
  169. door lock problem
  170. Compression Ratio
  171. Looking for a '99 Maxima
  172. maxima motor
  173. Rims and Wheels?
  174. 300zx rotors and calipers
  175. 04 transmission in an 03
  176. Metal Nun-chucks! Guys check this out.
  177. 2001 maxima 20th an. ed. vs. 2002 civic si, who would win?
  178. 91 Maxima Intake????
  179. my steering wheel has the shakes
  180. maxima for sale
  181. Whats all this whining noise??
  182. 1993 Maxima Error code 21? HELP!
  183. stalling
  184. Maximas = premium fuel only?
  185. 1995 - 2000 Max engine??
  186. 1995 Maxima 4 dr for parts... (NJ) rust free
  187. How to get to rear exhaust manf bolts on '99?
  188. pcv valve & fuel filter
  189. Non Maxima Owner Question 04
  190. Ignition wires.
  191. 01 maxima se 20th an. ed. vs. 01 eclipse
  192. Maxima cutting out
  193. 300zx
  194. Long 2nd gear in 2k maxima?
  195. ?'s about painting my altezzas like a skyline
  196. automatic '85 maxima gear problem
  197. Nissan brake rotor life span?
  198. Bank 1 & Bank 2
  199. Dropped Maxima!! Camber Kit???
  200. 2003 High beams wrong color
  201. fitting 3.5 Altima SE rims question
  202. wires questions for CD player head unit
  203. Will 97 maxima se 16inch rims fit my 96 max?
  204. snow tires
  205. Nissan Maxima 1996 Whining noise
  206. all season tires
  207. 1998 Maxima SE electrical problems
  208. Need a photoshop
  209. Different Chassis???
  210. possible parts car (90 maxima)
  211. 96 maxima GXE vehicle speed sensor/ SMOG check w engine light on??
  212. HELP... Maxima RPM guage needle got stuck
  213. Crank but no Start
  214. Im Buying A Maxima But What Year Should I Get????
  215. 2005 maxima
  216. would these rims fit?
  217. Recommended Brake Pads/Rotors
  218. Rough Idle/Hesitation/Weakness (1999 Max SE Limited 5-spd)
  219. Sponsor
  220. Looking for 95-99 Parts car!!
  221. Help!
  222. cd player install on 95 maxima
  223. Steering Wheel Stereo Controls
  224. having problems w/ my '91 Maxima
  225. OIL LEAK in 96 MAX
  226. ECU 0505 code?
  227. Cleaning of '98 Maxima Headlight Lenses
  228. temp gauge - '90 Maxima - help
  229. need help cefiro RB26Dett!!
  230. Your advice re: Weak spots: 96-97 Maximas
  231. Rough running 1993 SE
  232. Programming a 2002 Nissan Maxima Keyless Entry Remote
  233. 18 inch enkei rims for sale cheap
  234. I might take ownership of late model I30.
  235. SRS light Blinking all the time
  236. battery light
  237. Intermittent high beam
  238. Old maxima (help)
  239. 2K1 I30 Bose Stereo Questions...
  240. Who will win?
  241. G6 or same old tricks
  242. CEL with PO420 code
  243. Bosch Oxygen Sensors
  244. Reverse problem when cold
  245. Tranny, Buy Or Rebuild... Help!
  246. cefiro headlight bulbs and grille?
  247. 95 maxima gxe for sale
  248. Projector headlamps for Maxima '99. Anyone saw it? Does it exist? :)
  249. electrical problems
  250. will these rims fit?
