cruise control
dp62273
01-11-2005, 08:20 PM
i need to know where the cruise control is at in a 97 maxima and how it hooks up. is it vacuum or computer controled
Nahkapohjola
01-11-2005, 11:09 PM
Vacuum pump powered, intel inside cabin... hooks up to the throttle; follow its actuator wire under the hood...
Firts check the pump tube for cracks.
Maintenance Manual Online:
http://www1.autozone.com/servlet/Ui...&Parameters=004
Technical Service Bulletins; Nissan TSB's:
http://maxima.theowensfamily.com/tsb
infinman
01-12-2005, 10:44 AM
Both.The ASCD {automatic speed control device}computer controls the actuator which creates it's own vacuum via a vacumm pump inside the actuator.A very high cause of Nissan ASCD failure is the brake light/ASCD cancel switch.Or the actuator was not reconnected after a headlamp repair.
