View Full Version : Prelude
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12 13 14 15 16 17 18 19 20
- Engine Swap
- 98 prelude auto to manual swap
- Changing Headlights
- Neuspeed short shifter
- How to take off corner lights
- Fast Idle after installing SRI
- ***oil Leaks Everywhere Someone Please Help***
- 92 Prelude leaking oil bad
- new lude
- dc header 2.5" collector vs. smsp header
- Help! O2 Sensor installation...
- Cheapest Website to Buy From??
- Denso Iridium Power Spark Plugs
- head work
- Upgrade Help
- 98 h22 P5M-003 M/T ECU
- Cold Air Intake Help
- hunting idle
- what do you think
- GReddy Header Vs Dc Sports
- Solving Intermittent 4ws on 92+ preludes
- need help with lude
- Type SH vs. Type S
- 92 prelude si has starting/electrical problems, can anyone HELP!
- headlights for lude
- Aceshigh Helpppp
- 5th Gen SH vs Non SH
- Hayame exhaust
- prelude exhaust system
- Some new comparison site for import performance stuff
- occasional cylinder misfire
- Clutch & Flywheel 5th Gen
- Hey, guys what's the CAUSE...
- Syncros going?
- Choke Has Mind Of Its Own
- Prelude F22 to H22 swap help
- Oil Coming from Exhaust??
- Venom 400 Computer Module
- How hard is it?
- Worst Honda Ever
- whats the best NA headers...
- Clutch Installation
- taking off my shiftknob
- Name Brand Vs Ebay Intakes
- clutch question
- Would it be wise to...
- AC wiring harness
- Horsepower!!!!!!!!!!!!!!!!!!!!!!!!!!
- turbo h22 del sol help!!
- h22a wieght?
- REDline
- Please help me!!!!!
- debating whether or not to buy this prelude...NEED INPUT!
- turn signal
- heater problem
- Turbos Turbos Turbos
- Mugen
- honda parts
- Body kit
- Look!!!!!!
- swap problems
- How do I hook up my Autometer Oil gauge?
- How do I drain my tranny?
- Best Performance Catback Exhaust For H23 95 Prelude
- auto-bumps in 4th when throttle pushed
- '96 honda prelude SI --looking to sell
- Found a car but a little sceptical
- Trying to find 92-96 Prelude
- body kit
- Help buying a new Injen filter
- h22 oil pan gasket
- setting the timing
- Short Ram Intake
- actual horse power
- Where can I order a Type-R (SiR) H22A
- clutch question
- Skunk2 Intake Manifold
- Does ECM control A/T shifting?
- H22A TPS Setting, how to!!
- 91 SR engine
- Need help on engine swap please~!!!
- h22
- h22
- 3000gt vs. 4the gen lude
- Bad Shift/power loss
- H23 compression ratio??
- is it my choke, or what?
- 95 lude or a 96..So confused
- i need an answer!
- Loud Engine
- compression and leak down testing?
- Ebay Speed Chips...
- Sylvania Silverstar...NIB...5th gen headlights
- Am i getting ripped off with "camber needed"
- H22A EGR deleted & what works!!
- H22A distributor issue!!
- 4th gen chip
- weird sound comin from engine
- 2000 'lude headlights
- 94 Honda Prelude Si... what can I do
- What 2 Do?
- h22 info
- Skunk 2 manifolds. Any good ?
- Fuel system or pulleys = more power?
- Help need HEADER INSTALL INSTRUCTIONS
- Vafc: worth it?
- so who would win
- 5th gen honda prelude speaker upgrade
- jdm engine question
- Suspension Question
- msd ignition
- Difference in 97 and 98 H22, PLEASE HELP
- Reving Itself when idle
- overheating
- DC Sports Short Shift Adapter Kit
- 94 Prelude Si-VTEC Head
- honda Prelude problem 97
- 5 lugs conversion
- 92 Prelude Si need sum advice
- Stalling!!!
- lifting the car (for mechanical, not appearance)
- paint job cost, cigarette lighter prob, and antenna question
- mugen reverse gauges
- air filter question
- engine swap 87 prelude
- clutches?
- Rattling sound from wheel arch area. 92 Prelude!
- 89 Prelude Electrical wackiness - help!
- hid conversion
- How to tell the diff. from JDM type S H22?
- 91 lude
- Prelude Overhaul
- Only CLICK sound from starter.
- for sale 96 prelude si
- Can I keep my intake resonator in? will it affect anything?
- 94 si bright gauge lights?
- carbon fiber hood
- Suggestions for mods
- Additon of AWD
- Should I go back to Prelude??
- New Clutch-need help!
- No clue.
- 02 Sensor??
- Dome Light, 92 Prelude
- 16's or 17's
- for sale prelude 93 vtec
- 95 Si front seats for sale
- Check Engine Light??!!
- built h23 without balance shafts???
- H23 vtec horsepower?
- for sale: prelude 93 vtec $4000
- 2.2L exhaust help
- Digital Display When Ignition On??!!
- wheel size and tires
- type s lip
- 1995 Prelude For Sale
- JDM b20a and USDM b20a5
- evo2 exhaust system
- Temperature Gauge rises to H
- fs: 2000 crystal metallic blue prelude
- turbo 98 lude
- This prelude worth getting?
- wtb 1996 vtec ecu
- h23 to h22 swap; AXLES
- ABS Light????
- Elusive oil leak
- little help with an injured prelude?
- Door/rear speakers
- prelude conversions
- is this a good deal?
- spoilers on FWD cars?
- 1985 prelude ecm
- stock amp
- new deck
- Hard starting
- MAP problems (code 3 reading)
- which ecu is right for the h22?
- Brake Pads
- H22 motor w/ h23 trans||h23 wired for vtec? ||h23 2 h22 any ac problems?||H23 axles o
- 88-89 motor parts for sale
- clear bumper lenses
- Thermal R&D Exhausts
- 4th gen internals help!
- 1985 prelude stereo and equalizer
- drive your 92 - 96 jdm vtec please (:
- H23A transmission gear ratios?
- Painting Questions
- Buying a prelude help plz!
- Quietest Exhaust
- Funny smell coming from the car...:{
- widebody prelude
- Prelude Owners: Help!!!!
- H22 Swap Guide
- SUSPENTION for a BODY KIT.
- HID Lights
- big brake upgrades
- Help prelude weight reduction
- Clicking Noise from Fuel Pump
- 92 Prelude Si cuts out at full throttle??
- Type S engine components
- Let's geedum, guys...
- 85 PGM FI Problem!!!!
- 350hp goal
- carbon hood
- clutch makes squeeky noises
- 1995 prelude si
- 5 lug suspension
- JDM h23 engine troubles
- FS: 92 Prelude Gauge Cluster
- Voltage Output Issues
- prelude/crx engine swap
- Lean Racing True Short Shifter
- headers
- rear speakers
- how much horse will i get
- k20a2 engine swap
- h22a rods and pistons
- how do i change my profile name
- Oxygen sensor
- Wiring?? HELP!!
- Anyone know any good sites to find lip kits?
- bottom-end buildup for turbo
- rear wheel conversion?
- Help!!!!
- prelude engine
- Newbie needs advise on buying a 1991 Prelude SI
- how much does it cost to get a lip kit painted?
- Oil light issue
- Honda prelude 97 ..WHat the!? Help.
- How much horsepowere increase from...
- HELP! VTEC doesn't work at all anymore
- 2nd f***ed Radiator Hose
- what's wrong with my car???
- '91 with ALB/SR question
- Obdii-obdi Cel
- World Sport 1 or 2?
- Honda Prelude Big Problem
- turbo/psi quetion
- No Spark on '97 Prelude
- engine swap
- vertical engine conversion
- Stock Rims for SALE!!!!
- Supra engine!?!?!?
- which supercharger is best?
- 94 prelude S-what you all think?
- what gen is my lude?
- engine types?
- Camshaft break in lubricant?
- Coilover/stock height
- Can you burn out your VTEC???
