Honda
> Prelude
View Full Version :
Prelude
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
Help! How to prep my JDM mirrors
My Car doesn't PULL!!
'84 Prelude Project
89 honda prelude prodject help wanted.
wheel bearing
My car wont start
OEM body kit
94 prelude - cold air intake help!!
h22 auto to manual
I need lights for my 1 piece JDM's
f22a to h22a engine swap
Is it Posible???
Pics of my '01 Prelude - Look
new shift knob
Just a story (Kinda long)
Camshaft Knowledge
turning coilover sleeve upside down?
h22 transmissions
need an inner fender
AEM or Injen CAI?
Noise when turning?
Help please!!!!
3rd gen Mods?
brake light/abs light
nice thread by the way....
PSPEC, forbidden, adaptor, whatever..
Ford 302 In A Prelude!
92 gauge cluster to 94-96 cluster
Quarter Panel Rust
84 Prelude specs
1993 Prelude Si
JDM Headligh Conversion
New Lude
**important**what Cat Do You Use For Your Lude?
time for a new clutch!
FIRE! H22 motor?
need new tires for my 4th gen si rims
flex pipe needed on a 4th gen vtec
coilovers
G/f's 92 lude losing oil like crazy
Need Advice
anyone have a ViS Evo Style CF hood?
Gas Mileage?
Atts Problem!!!!!
ebay turbo kit, take a look, whatcha think?
86 carburated?
AEM v2 Intake
Used prelude had some issues.. Any suggestions?
Prelude PArts for sale
h23 head weight?
88 Prelude Si Frakenstein swap????
timing belt price
My 89's repair estimate
Prelude h23 parts
H23 vtec
17 Inch Tires on a 1997 Prelude
Putting a b20a into an '83 Lude????
1995 Prelude Vtec vs CRX (K20 engine)
Questions
maybe someone could be of some assistance!
ideal compression ratio
1996 Prelude Turbo Help
Prelude vs. S2000 [56k beware]
help finding parts
2nd Generation Preludes rock
Help!!!! Big Problem!!! Confused!!!
Rust!
1995 300HP Prelude
Going to look at a 5th gen Prelude any suggestions of what to look for?
**Help please!** Big bore for 87 Lude
91 Tails 88 Lude
93 Prelude dash & gauge conv.
how do i take off the h23 head>?
Mileage Hint
Road Trip
Need a Tranny / miscellaneous
Selling 95 Prelude w/V-Tech 5-speed
Fuel problem diagnosis
Which engine swap is easier?
Axils And Engine Mounts
Parts
skunk2
Timing questions!!!!
whats the difference in the 86 prelude and 86 prelude si?
VTEC Solenoid
camshaft question
Oil in a turbo lude
4th gen JDM foglight install
my buy
Loud CLunk Sound! 3rd Gen.
jdm swap problem
Buying an Prelude
Replacing Valve Keepers
whats the best fuel pressure
trim
h22 swap
buying a head online
Noise from my 3rd gens rear driver side
Question regarding fuel pump
Cleaning out the head
Repair Manuel
Timing ?
92 Honda Prelude
What are the Differences?
4th gen hp issue
90 prelude si sometimes doesnt want to start
Brake Light Problem
Back Deck rattling
Sensor Question
1993 SI for sale
98 prelude sh for sale
5th gen lude rear seat room
Swapping a H22 trans with a H23 in the H22A1
info for 4th gen 5-lug conversion?
stuborn lude
blown engine?
Engine swap from October still not working PLEASE HELP
h22a/h23a hybrid
are their any differences?
blacktrax.net
few questions
new car looking for advice
Wanting to buy need some advice
Need Engine H22 H23?
92-93 console -> 94+ conversion
'93 Prelude Door Buzzer
VIN Numbers??
Help! Clunk Sound! 88 3rd Gen Lude!
tranny heading south??
obd1-2conv auto?
1988 lude..ignition module?????
5th Gen Prelude Colors
best clutch?
S2000 digital cluster swap...
performance chip
Revs go up and down will cold!!
h22 engine not running right
Installing a V-afc on my 93 lude
clutch installation
how do i host pics?
i need some help plz - tranny
Oil Leaks
will PIAA 9007 fit 4th gen prelude?
97 Type SH problems
Engine Question?
conversion on a 1992 prelude si F22B engine
h23 distributor on h22a...
18's for prelude?
93 runs rough when warm
Anyone want to get the JDM Hiro kit
Best place to buy engine
pick one
automatic fuel cut-off
increase maximum mph
profromance upgrades for a 1988 honda prelude
Crankshaft Pulley
Fuel Supply System
What are 2001 Honda Preludes worth?
Accident
will h22 turbo kit work
Knock Sensor
Vote on Taillights
Ecu fuse blowing
92 gen 4 body......
4th & 5th GEN tranny's
Door hinges welded...mom helping son with door alignment! YIKES!
timing belt change.. opportunity to upgrade cam gears?
So Pissed
Quaife and Kaaz LSD
Supercharged WHP
Hemi in Prelude?
i need a prelude
h22 swap or h23 turbo
88 2.0 si prelude won't start in cold
88 prelude 2.0 si wont start when its cold
OEM Rear bumper
Need help finding 4th gen prelude
wideband oxygen sensor
has this happen yet
is this true
is this true
'91 Prelude Si Brake Swap
whats better
Arrghh!!
SMSP headers vs Mugen headers
SMSP headers?
did i do the smart thing
finding ignition coil wire under the dash board
94 clutch swap
s tranny in a si
Best header for H22A?
RPM gage
Supercharge a prelude
is this all I need for a working turbo?
at what RPM do you guys drop the clutch?
4th gen springs vs. 5th gen springs
A'PEX Super Ground: Worth It?
Jdm H22a With P28 Ecu
5th Gen Prelude FIRING SEQUENCE
electric supercharger/the turbonator
Draining coolant in 1995 Si
what RPM do u SHIFT??
whinning noise from buddies prelude
need seat brackets for prelude seats!
HELP my 90 2.0 si won't go above 4200 rpm
I need help BAD
turbine trim question
setting amount of boost
h22 swap
help
4.27 to 4.06 ratio..how bad?
Hondata
Hondata s200
Misfires in 3 cylinders.
Preludes
Which Boost Controller Is Best?
Port and polish
APexi VAFC vs Hondata
Hey
Auto Transmission
prelude ignition timing
which turbo is best
Anyone who has used valve spring compressor on Prelude
Prelude Si and Prelude Vtec?
Prelude faster takeoff
CRX vs Lude
Management system HELP!!!!
daytime running lights 1990 sr
thinking of buying a 91 prelude 3.4 liter man tranny is it worth 1500.?
what do you think of this
Prelude DC Sports stainless steel header problems
What make of rims are these..??
lude vs. rsx
Prelude burning oil problem
how to get the bleed the clutch?
Lock mechanism failed
93*prelude*h23 -vs- 04/05*scion*tC
Thinking about getting a 99 Prelude SH
h22 swap/eg
87 Prelude SI - 2 problems
Cam guidence needed
FORUM RULES AND GUIDELINES - MUST READ!!!
slight knocking in h23
clank sound in reverse
venom module
90 Prelude Lossing compression in Cyld 1
quarter mile times!!!
wont go into gear in
new fuel injector
