View Full Version : Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20
  1. Questions
  2. h23/vtec conversion?
  3. Prelude Power Potential
  4. Prostart Car Starter
  5. fuel gauge
  6. FS/FT | 92 Prelude SI | $1500 | GA
  7. Speedo says no speedos
  8. Lots of smoke out of the muffler
  9. '92 Prelude Si Rear Wing for SALE!
  10. still learning manual...help!!!
  11. Dual exhaust vs. Big tailpipe
  12. Steering on 5th gen
  13. sequence order
  14. Shift knob replacement
  15. 4th squeeky suspention
  16. JDM Type-S Strut Bar Install
  17. 1994 vs 1995
  18. finally got one!!
  19. HELP!!!! V-tch swap with Cali Emissions
  20. Engine Swap info
  21. performance starters???
  22. an outraged discovery on my tranny!
  23. can't tell if mine is an sh
  24. Taco / Speedometer for me
  25. Rearveiw mirror help
  26. my eninge into a civic
  27. Guys please visit my Web-Page...thankxxx
  28. Flex pipe length?
  29. Thermal R&D Exhaust for 97 Prelude?
  30. Does anyone know where i can find sound clips for 5 gen preludes?
  31. RPM's Problem???
  32. Door Speakers
  33. I need a new engine on my 92 LUDE
  34. Cold Run
  35. General Prelude questions
  36. taking out 98 SH tranny..
  37. price to fix 2nd?
  38. 1998 honda prelude SH for sale..
  39. antenna problem
  40. SKUNK2 Programmed ECU
  41. Power Help??
  42. 87 Prelude what engines can I swap in?
  43. exedy clutches
  44. Jumpy idle.
  45. Failed rebuilt prelude axles.
  46. Dashboard Clock
  47. Factory 6 disc changer
  48. 3g prelude
  49. NEW Picture Thread
  50. Prelude Body Kit
  51. 92-96 Body Kit For Sale
  52. Why did they stop making the Prelude?
  53. FS: BB6 Type S pistons\new and in the OEM Honda box
  54. gauge lights
  55. build up vs. engine swap
  56. leather seats
  57. Cost
  58. Engine Specs ect.
  59. Parting out 92 Prelude
  60. Help me out here...
  61. crank pulley
  62. Spring comperssor or not?????
  63. Best ecu for the h22a???
  64. wanted: 92-01 Prelude, or Del Sol
  65. Speedo drops to 0 once it hits 35MPH..WTF?!?!
  66. Help with tranny oil change
  67. New a-pillar gauges!
  68. 87 prelude 2.0 si (fuel injected) ECU
  69. Merry christmas!!
  70. 87 Prelude SI Idle is surging
  71. Floor mats?
  72. Water spots... causing insanity
  73. Prelude hard to start in cold
  74. 97-01 Prelude OEM Lip Kit
  75. 3rd gen si h22a or b18c swap???
  76. prelude brake upgrades?
  77. 1991 prelude cylinder 1 not firing
  78. Need an answer quick... please! =)
  79. Maaco paint?
  80. my SH
  81. national prelude meet
  82. Idle hi/lo when started after timing belt change
  83. f20/h22 motor
  84. is there a v8?
  85. glove box
  86. Looking to buy a 'Lude si H23A1 4ws question
  87. will a jdm engine fit/work in my car 97 prelude
  88. chips, 94 vtir
  89. turbo
  90. Vitek LSD
  91. question
  92. v-tech engine
  93. Ecu
  94. Wack tail lights
  95. feeling the vtec!
  96. Stereo Install 97 Lude
  97. REQUIRED VOTE: what to do with the pictures thread
  98. crazy idleing
  99. Would this fit?
  100. H22 Swap questions?
  101. Prelude
  102. which type of nitrous
  103. What wheel size to get? 17's or 18's?
  104. Loud squeaking noise, front driver side
  105. 4 gen eyelids
  106. Spacer ?
  107. 1995 prelude rear speakers.
  108. extra throttle body tube hole
  109. Where is main fuel relay(93 prelude)?
  110. Taillights anyone know?
  111. 92 lude for sale....blown engine
  112. New tires
  113. Cams Cams Cams
  114. Suspension Help
  115. Prospective 96 Prelude Owner- Need Help
  116. punched block?
  117. Custom center console
  118. What's the lowest possible drop?
  119. Auto to Manual
  120. tranny crazy
  121. Prelude euro tails
  122. what is the difference between a h22 and h23 tranny?
  123. which one???
  124. tuning the screw for idle rpm
  125. possible (very expensive) mod?
  126. Glue problems. Help.
  127. 93 V-Tec Prelude w/ stage 2 clutch... what next???
  128. Bolt On Mods To Beat A 5.0 Mustange GT?
  129. Have my gear ratio's been changed?
  130. I hate Christmas..
  131. Intake & Header Options `90 Si ALB
  132. ever heard of a prelude SSR?
  133. Burning Oil
  134. are there any 5th Gen aftermarket headlights?
  135. jdm prelude wiring diagrams
  136. A ?
  137. S2000 seats in a 5th gen?
  138. buying a 5th gen prelude, need some advice
  139. jdm headlights
  140. Headlight Conversion
  141. rear right suspension noise....???
  142. new rims/ speedo question
  143. 5th gen
  144. Modifying steps...
  145. H22 Swap
  146. Remote car starters for manual??
  147. Prelude type s
  148. Springs
  149. Would MSD 6al get ur vtec stronger?
  150. Would MSD 6al get ur vtec stronger?
  151. Gutted cat and no EGR, will it cause a CEL?
  152. Vehicle noise
  153. Problem with '92 VTEC JDM H22A
  154. p28 running an h22??
  155. more protential hp?????
  156. ATTS in the winter
  157. anybody else have heated seats fuse
  158. B20A5 w/ Vtec ????
  159. A fresh 5th gen... Mugen? need input!
  160. H22: Ideal Custom Turbocharger
  161. Which body kit?
  162. Engine Problems
  163. Prelude Si Tire Size
  164. ATTS light
  165. Dash Lighting
  166. '87 prelude
  167. Question about the h22 dual butterfly...
  168. Need some 89 Si help
  169. tranny
  170. Possible Prelude owner in next 5 months
  171. body fat
  172. 87 prelude engine info and swap
  173. Newbie has 89 Prelude 4ws blown head
  174. Timing belt/tensioner
  175. iridium vs. Bosch Platinum +4 plugs
  176. how to reset Maintenace light 97
  177. Rear view mirror
  178. transmission problem
  179. New sound after resonator is removed
  180. Heated seats
  181. 4th Prelude Intake help
  182. Engine swap 2.0...2.1
  183. V-tech and Springs
  184. H23 parts?
  185. 5th gen axles
  186. Vtec controller?
  187. i have a question
  188. Good deal on 1995 VTEC Lude?
  189. Help on 91 engine sizes
  190. Springs??
  191. idle erratic
  192. Haynes Manual for 92 Prelude??
  193. cat converter\h22, h23 which is better
  194. 92 SI... VTEC SWAP vs Turbo vs Internals upgraded
  195. Stock speaker sizes?
  196. My turbo project
  197. HELP~! My clock keeps changing
  198. Blown head...bottom end contition???
  199. 1993 Prelude?
  200. engine swap h22a1 into 95 prelude se
  201. '92 H22A wont rev past 3500RPM...?
  202. Super nOOb Questions !!!
  203. JDM Tranny Codes
  204. I Need A Quick Reply!!!!
  205. new update on JDM swap into a 98 SH...
  206. What does this mean?
  207. Weird bolt question
  208. headwork
  209. is there a bigger motor that wil fit in my 88 s.
  210. 89 prelude engine swap h22a
  211. vtec point
  212. Engine/transmission Knock "clunk"
  213. Timing Belt
  214. Please keep on-topic
  215. heated seats?
  216. 4th Gen riding low in the rear
  217. Fuel gauge
  218. Pgm-fi
  219. I Want To Buy A Prelude
  220. 2.5 grand to spend
  221. v-afc
  222. Offset Problem
  223. Quick...Where could i get performance distributor cap and rotor for a gen 4
  224. SH exhaust
  225. For Sale: H22 Head
  226. Aem V2
  227. angel eye headlights?
  228. prelude rear seat, need one, help!!
  229. 95 mph and everything dies
  230. Anyone have a clutch for sell???
  231. 92' JDM Honda Prelude Show Car f/s
  232. Prelude Trunk SpRing BroKeN - HelP
  233. Post pix of your BODY KIT
  234. Do the type of spark plug wires you use matter as long as u go performance...
  235. I Need Help !!!!!
  236. headlights askew
  237. louder sr intake
  238. Cd Player 4V, Amplifier 2v. Help
  239. am i just being anal?
  240. Anyway to clear the orange in 94 prelude tails?
  241. Whats the deepest dual exhaust out there for a 97?
  242. Frankenstein!!!!!
  243. Newbie Question
  244. Good deal on this prelude???
  245. ECU question
  246. indecisive mind...
  247. si vetc and vtec
  248. My Prelude ?
  249. How much for a prelude
  250. what to do...supercharger or twin turbo?
