View Full Version : Sonoma | S-15
- 92 brake warning light on
- Coolant change?
- 2001 4WD tranny problem now....
- GMC Problem please Help
- Exhaust Question
- Help on '98 Sonoma door wiring...
- LED and Neon wiring ?s
- 2.2 sonoma will cutout when i accelerate! HELP
- Replacing The computer on my 2.2 sonoma/s-10
- generator lamp L
- Sonoma 2001 gas mileage
- Fast Idle
- Crazy oil leak.....
- A/C problem, help pls
- 99 sonoma torq converter lock up /O.D. ?
- Self Tune Up
- Warning lights troubles
- Multi Fuction Switch replacement
- 91 sonoma looking for a new tailgate
- what else for my engine?
- Timing 2.2L
- Engine help!!!!
- rough engine
- Missing fuses?
- 96 Sonoma Fuel Pump mystery
- «Hiss» coming from the gaz tank
- Rims
- 2002 electrical problem
- 2000 sonoma flex fuel won't start
- Bad Aftermarket Ball Joints
- sonoma engine help
- rough idle
- flushing coolant
- 01 Sonoma low oil pressure at idle and service engine soon light
- tach
- popping noise when turn
- 4X4 problems... all the usual fixes arent working
- 2001 factory alarm: going off by itself
- what shocks for 98'?
- What else should i change?
- 98 sonoma idling problem
- Factory Xtreme body parts. Where to get them?
- Question about flushing break fluid
- '94 Sonoma rebuild differential estimate?
- Surging Sonoma 4.3
- 4X4 problem
- Tail light help
- Sonoma Recall-lower balljoint anyonw know?
- Fuel Filter fuel line
- high idle
- jerking at low RPM
- high idle
- For Sale: Air conditioning knobs
- 2000 sonoma quit while driving it, and won't start
- stalling and bad idle
- 1999 Sonoma Wiper Problem
- Fuel Line Nut Kit
- My 4x4 comes and goes PLEASE HELP!!!!
- 4 Wheel drive not working....
- non-injecting injectors
- 96 4.3 Coolant leak
- clutch problem
- Search Before You Ask Questions!
- bumper conversion
- Stereo system for 2000 extended cab Sonoma?
- 99 Sonoma - Engine dies after 1 second (alarm??)
- Tires For A 96 Sonoma
- Lift-kit
- manual 2000 GMC Sonoma "chuggs" in rainy/foggy weather after warm up its fine
- Under Hood Wiring Harnes Diagram For A 93 Sonoma Vortec Engine
- 2000 Sonoma door speakers...
- 84 Indy 500 Official Truck
- Closed Loop Help
- 4x4 stuck
- Weird Engine noise during cold months
- no floorboard heat, feet are freezing!!!
- needing power
- Anti Freeze Leak
- 2.2 freeze plug locations
- 1998 Sonoma No Electrical at all...
- 2000 Transmission Problems
- sonoma loading up
- 1998 Surges
- 1993 Sonoma 4.3
- Gas Mileage
- '92 Sonoma, dash lights
- oil pressure probs
- any interest in clear corners or clear caddy tails
- 1999 Door Hinges
- Model 2001 -Suddenly loss speed and have a "Hiss" sound
- 2ooo sonoma 4x4
- V8 Conversion
- Push Rods
- 4x4 problem on 2003 sanoma crew cab
- EGR Valve/Thermostat help '94 noma
- grill and headlight swap
- Fueling up problem
- No heat for me
- 91 Somoma 4.3 w/cold start problem
- Miss
- seat adjust lever
- 95 Sonoma intake gasket leak-Now bearing knock!!
- Exhaust
- 20 mph shudder -- any known causes for this?
- F/S Downey SST Tonneau Covers '94 and newer
- 93 windsheild washer pump won't pump
- 1991 Sonoma Ext. Cab 4x4 Pu For Sale!!!!!
- 92 S15 runs rough when low on gas
- dummy lights in dashboard stay on
- Fender Flare needed
- Where Is The Fuel Pressure Regulator??
- 2000 Sonoma won't run
- o2 Cheater, any thoughts???
- 98 sonoma fuel pump
- Wiper Relay Module
- Wiper Problem
- wheels
- lookin for interior
- slow to change gears going uphill
- EGR valve HELP
- Throttle Body Spacer
- Interior Courtesy Lights problem
- 96 Sonoma stalling Electrical Please help!
- what exhaust to get?
- 2000 Sonoma 4 SALE
- Sonoma 98 3rd door handle broken
- heater core problems?
- Fender Flare rubber
- twin turbo engine
- 1998 s-15 back disc brake convertion
- 96 Sonoma Front end upgrade HELP
- outside temperature reading
- GMC Sonoma SLX for sale
- overhead console problems
- 1995 Sonoma
- electrical
- 2000 Sonoma Heater problem
- 2000 Sonoma Highrider Brake Shaking
- FS GMC Sonoma truck for cheap on EBAY So Cal
- 2.2 to 4.3 swap
- 4.3 Vortec for sale
- 3rd door handle replacement
- Side Panel Rattle
- Big Heat Problem
- Pre-Runner 'Noma Drifter?
- someone help?
- 89 r700 shifting
- sonoma
- digital instrument cluster
- 4.3 Vortec For Sale
- Coolant all over passenger side floor...
- 00 Noma rear window 4 sale
- Blown Head Gasket
- 96 GMC Somoma
- Broken Serpentine belt and siezed pulley
- Flareside tailgate, Taillights, Bumper, and both step sides For SALE!!
- 97 sonoma bucks/surges badly, tach incorrect
- A/C Problem
- V8, V6, or Syclone
- 01 sonoma spark plugs
- bumper issues
- FS:98 Sonoma Extended Cab in GA
- 92 Sonoma 4.3L
- Worn clutch?
- Problem with dash lights
- 96 Sonoma Stalling out
- Brake Dust & oil pressure on new 04 Sonoma
- Shop manual
- door handle
- Which 4.3 power rating??
- 1996 Standard Shift clutch pedal pressure
- 2001 GMC Sonoma Keyless Entry Programming
- v8 questions
- Starting problems
- Power window and vent problems
- steering columns??
- 1994 sonoma sle for sale
- Distributor Cap setting for a 96 noma
- FS GMC Sonoma truck 98 in so cal
- Signal light lever
- '87 cam gear problem
- 92 best..but no go
- 91 Digital Inst Panel & Brakes
- V8 engine Swap into Sonoma / S-10
- P1870 Trouble Code; "Transmission Componet Slippage"
- Power Power Power
- Help with pcv valve
- Help with dash lights and instrument panel
- GMC Sonoma alarm
- New Motor Wont Start
- 03 Sonoma with S.yclone drivetrain
- 94 and newer sonoma
- LOw Oil Pressure when Ideling
- ahh help help help 2 piece drive shaft
- Disc Brakes Dragging
- 1991 Hesitation...?
- replacing rear end, stuck on removing it on a 97 2.2
- Non-protruding cd deck?
- New Engine
- In need of info
- 1/4 mile
- Reset Service Engine Light 2002 Sononma
- 2000 GMC Jimmy/Sonoma Supercharger Application
- engine swap
- underhood pictures wiring harness
- broken hood release cable
- 2001 GMC Sonoma Remote Programing
- Sonoma Cruise Control
- bad vibration
- 1989 S15 Speaker Size
- 96 Sonoma 2.2 to 4.3 vortec
- Help
- 1996 GMC Sonoma
- Flowmasters
- transmission
- wanted GMC sonoma
- body kits
- Shift knob removal
- more power in the noma
- Vehicle bucks/hesitates
- 4.3L sonoma performance parts for sale
- OEM manuals
- Interior Noise
- FS 1999 lowriding sonoma
- "We love 'Noma's!"
- oil cooler lines
- Need 95 Sonoma rear bumper extensions
- Transmission problems '93 Sonoma
- Timing a 93 sonoma
- tapping sound in engine
- missing parts
- Sonoma problems
- Serpentine Belt
- gas gauge
- 1997 Front end swap with 98-03
- headlight replace on 2000 gmc sonoma
- Intake swap
- 1998 gmc sonoma for sale!
- 92 Sonoma 4.3 running ZEX wet kit
- Exhaust for a 96 Sonoma
- Wanted - sonoma/S10
- 89 S15 Windshield Washer
- FS - 92 GMC Typhoon
- GM power.....please read and if possible hlp.
- Performance mods on a 92 sonoma
- 2 Link pics???
- 93 4.3 Tbi Water Pump Gaskets Blowing
- Looking for replacement part
- 98 Sonoma
- re: alarm
