View Full Version : Jimmy
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. What's the differance?
  2. Low Engine Temp
  3. Jimmy Digital Dash
  4. I don't have any idea...Idle/Park
  5. Fuel Pump Regulator
  6. Fuel pump wiring harness
  7. Shifter does not work
  8. 2000 GMC Sierra Tranny Problem
  9. '95 Jimmy heater smell
  10. 97 Jimmy front suspension
  11. Fuel Level Sending Unit
  12. cold start engine tick
  13. Jimmys problems..........
  14. 1992 is making a really bad sound...But runs great!
  15. A couple questions: Fuel and Oil Pressure
  16. 2000 jimmy no heat
  17. 4 wheel drive problem Jimmy 1995
  18. 91 Jimmy problems
  19. 1998 Climate Control - LEDs
  20. 2001 Jimmy heater problems
  21. 95 jimmy nut kit installation
  22. 98 jimmy gas guage doesn't work...follow up
  23. Coolant Temp Sensor for gauge
  24. 94 Jimmy 4.3 W coolant flow path?
  25. 1996 jimmy heater housing falling apart
  26. waterpump fastener sealant (white)
  27. rear window washer path
  28. 2001 Gmc Jimmy
  29. fuel system
  30. 93 Jimmy steering lockplate removal?
  31. Thermostat orientation???
  32. heater problem?
  33. 95 Jimmy,An OBD I or OBD II??
  34. 96 Jimmy Tranny and Courtesy Lights
  35. Oil cooler line replacement
  36. Heater problems 2001 Jimmy
  37. 1997 Dies while driving for no reason ???
  38. Oil cooler lines
  39. 95 Jimmy SLT 4x4 O2 sensor code/Passenger side window problem
  40. '95 Jimmy no start - follow up
  41. another 4x4 question
  42. 2001 Jimmy--Will not change from 2hi to 4hi/4lo
  43. 1994 s15 jimmy not runing right
  44. questions on blazer/jimmy
  45. oil gage going crazy????
  46. temp. gage ????
  47. O2 sensor Curcuit High Volts
  48. 98 jimmy heater control vacumn lines
  49. need some advise on changing my bearings
  50. '95 4x4 problem
  51. '97 Jimmy 4x4 problem
  52. erratic idle jimmy 95
  53. fuel problem and hard starting
  54. 96 won't blow hot air
  55. new sound under r/s
  56. Catylitic converter
  57. 2001 jimmy won't start below 30 degrees
  58. 89 jimmy problems Please help!
  59. 2K Jimmy noise changing gears
  60. 99 Jimmy: Whirring noise in the dash?
  61. Who's got the brains to figure this one
  62. Tire Size and Transfer Case
  63. Transmission Fuild
  64. 1991 S15 will crank, but will not start
  65. 2001 Jimmy no start (but tries) good fuel pressure (60psi)
  66. 4wd switch problem
  67. ? Noise under right side floor
  68. 90 Jimmy 4wd problems
  69. 2001 Jimmy PCV Valve location
  70. 94 Jimmy cold weather noise
  71. 1998 battery issues?
  72. gas gauage
  73. Poor brakes
  74. 99 Jimmy: Possible Fuel Leak
  75. 95 Jimmy ABS
  76. Anti-theft Alarm System De-arming
  77. 1997 jimmy questions
  78. 95 Jimmy
  79. 1999 Jimmy Power Seat
  80. 94 Jimmy 4wd Problems
  81. Fuel Pump
  82. 97 Jimmy ignition cuts out/briefly
  83. looking for cd radio
  84. 4wd on jimmy
  85. Need Help Undoing Seat Belt Anchorage
  86. 1999 Jimmy power seat
  87. gmc jimmy rear brakes
  88. pushbutton 4wd not working
  89. Overheating V6 vortec
  90. Auto Climate control not woking-need a good reference manual!
  91. 1998 Climate Control - AC
  92. jimmy tranny prob.
  93. 99 Jimmy: Alternator Replacement
  94. gas gauge doesn't work anymore
  95. 95 jimmy won't stay running
  96. '85 s15 jimmy front diff prob
  97. 1999 Jimmy 4x4 Question
  98. 94 Jimmy stalls in reverse
  99. where position the hose...jimmy vortec cpi
  100. 95 jimmy 4.3 knocking and spuddering
  101. 97 jimmy hard to start cold
  102. 95 jimmy transmission problem
  103. 2001 Jimmy short?
  104. 4 wheel drive blows fuses
  105. 95 Jimmy start problems
  106. Red Neutral Light On
  107. from 2.8 to 350
  108. ign/gau fuse keeps popping
  109. Cruise Control And Rpm Gage Not Working
  110. Wheel Nut Torque
  111. electical problem?
  112. Air Pump-right Or Left Side??
  113. Jimmy 98 stuck on 4HI
  114. 1998 JIMMY front end pop.....>>>>>>
  115. Service engine light - powertrain intake - a little help?
  116. Center Console
  117. 1999 GMC Jimmy, No Start
  118. 1996 Jimmy
  119. need some info.......
  120. Overdrive Vibration
  121. Short Circuit
  122. O2 sensor heater circuit
  123. Front End grinding noise- please help!
  124. clunk?
  125. 93 Jimmy 4.3 Vortec Vin (W) again
  126. Engine Washing
  127. Strange 4WD Problem
  128. 1997 Jimmy SLT Highway power is lacking.
  129. turn signal switch
  130. 94 Jimmy - Cranks but won't start
  131. Body Damage!!
  132. taking steering coloum off
  133. ecs and oil line adapter
  134. So Screwed...
  135. getting frustrated,,94 jimmy
  136. 98 Jimmy 4x4 issues
  137. Crank But No Start!!!!! Help
  138. Inside Door Panel
  139. smoke coming from tailpipe
  140. Frnt/Rear Wipers and my Power Retainment
  141. Interior Lights
  142. 95 & 02 Jimmy compatability
  143. 1997 GMC Jimmy stuck in 4 high.
  144. Hard starting, very rough idle and foul exhaust smell on 93 Jimmy
  145. 1995 Jimmy SLE Keyless Entry Wiring --------HELP ---- LOOK AT THIS ONE!!!
  146. Jimmy acceleration problems
  147. automatic locks
  148. Keyless Entry System
  149. fuel pump fuse
  150. 95 Jimmy vaccum leak ????
  151. Starting Problems & Traction Question
  152. P1870 Transmission Component Slipping
  153. Grille
  154. Tapping sound from 4.3L engine in cold weather
  155. s15 jimmy transmission
  156. Stock Offset?
  157. 4hi dash button not working on 97 Jimmy
  158. antifreeze leaking from engine
  159. tires
  160. engines
  161. Tilt Stearing 1991 Jimmy
  162. 1992 s15 jimmy and abs
  163. 4 wheel high
  164. 2000 jimmy hinge pin replacement?
  165. Catalytic Converter
  166. 4x4 jimmy selector lights flash
  167. OIL CHANGE in 4.3L GMC
  168. QUICK!! Blazer and Jimmy Diamond Edition compatablility ?'s QUICK!
  169. 4X4 attempting to engage with not in 4X4 mode
  170. grinding noise from engine on '99 Jimmy
  171. 87' Jimmy engine swap
  172. rear hatch window trouble
  173. V8 upgrade
  174. Programming Keyless Entry Fob for 1998 GMC Jimmy
  175. Constant Front End Problem Fix
  176. how does the brake handle come off??? HELP!
  177. 2000 jimmy oil leak
  178. 2001 GMC Jimmy Stalls
  179. Need CPI??? Screw eBay!
  180. acceleration flat spot
  181. EGR gasket w/screen upgrade
  182. 97 Jimmy Tail shaft
  183. 1999 jimmy brakes
  184. Does it matter which water pump is used?
  185. 95 slt heater core
  186. 94' Jimmy Heater Control
  187. 94' Jimmy 4-Wheel Drive Help
  188. plug wire problems
  189. 96 GMC Jimmy P0108
  190. 92' Jimmy Won't Start!
  191. 96 Jimmy airbag light
  192. TRansmision control
  193. Jimmy repair project
  194. 1990 Jimmy Electrical
  195. 93 Jimmy stalls out after getting warm
  196. '90 S15 Jimmy - O-ring replacement, oil filter lines
  197. 1999 Piece of crap.
  198. V6 4.3L plenum gasket?
  199. Sensor 1, Bank 1.
  200. Clearing CEL codes and Tranny Problem
  201. Strange problem w/93 Jimmy 4x4
  202. 97 transmission - not impressed
  203. 93 Jimmy Tailgate/hatch handle/lock
  204. Compressor kit
  205. Can't open hood
  206. exhaust questions
  207. Brake light always on, help?!?!
  208. Front axle seal replacement
  209. 2001 Jimmy Rear Axle Torque
  210. Air Conditioning
  211. 1995 GMC Jimmy Idles Rough
  212. Dome lights stay on.
  213. Brake lights 50% working.
  214. Heating problem
  215. Transmissions Wont shift?!
  216. lift?
  217. 99 jimmy no 4wd lock-in
  218. 9 Jimmy And Passenger Seat
  219. 1998 4wd 4dr off-roading
  220. 1998 Jimmy heat blending door
  221. What would you want to do if you were given this Jimmy for free?
  222. Gears
  223. 93 Jimmy
  224. Coolant system rusted
  225. 1992 s-15 Jimmy floods with gas when it reaches operating temp
  226. keyless entry remote part number
  227. 2000 GMC Jimmy front/shock or bushing makes noise when warm
  228. Scorching hot blowing air
  229. Spark plug vs steering column
  230. 95 Exhaust manifold removal
  231. 98 jimmy heater core
  232. 1992-1995 Vin W CPI Injector Leak Photo
  233. Considering Buying 1992 GMC Jimmy
  234. 98 jimmy
  235. 98 jimmy
  236. 95 Jimmy S15 Fuel Problem
  237. 2000 GMC Jimmy transmission
  238. air bags?
  239. Message to GMMerlin--need your advise!
  240. 95 jimmy test
  241. good susp. lift for 97 2wd?
  242. Transmission or not transmission...that is the question
  243. Transfer Case?
  244. Gas pedal hard to push
  245. replacing 1990 GMC Jimmy Oxygen Sensor
  246. Oil drain location - 2001 4x4
  247. Replacement Shock Absorber Advice Please
  248. Oil pressure normal operating range
  249. 96 Jimmy, Hard Starting
  250. 96 4.3 haunted
